Question about AXYZ Computers & Internet
My z-axis has ceased all function. I was given an "Error 11" code and cannot find a solution.
3 digit code for axis remote x-405, for a dynex tv
If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://homenol.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; to which you want set-up codes; in the "Search box at the top right of the display window" to get gathered related posts.
Jul 16, 2017 | Dynex Televison & Video
When we star the treadmill E02 is apper
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Precor Error E2, Lift Error Probable Cause Error would occur if the incline is unable to move or if the incline position potentiometer is not functioning. When this error occurs, all lift motor and drive motor motion is ceased and the display will go blank except for the error displayed.
Corrective Action Troubleshoot as errors 40 and 42.
Precor Error Code E2
Oct 15, 2015 | Exercise & Fitness
81 01 error
Paper-Axis shutdown - usually a paper-jam caused by a blockage of the
Paper-axis System.
Action- Try the following= If this error code was caused by a paper-jam, unplug the power cable from the printer and clear the blockage. Plug in the power cable again and check if the Error Code has disappeared
-If this error code appeared but was NOT caused by a paper jam,
replace the Paper-Axis Motor Drive Assembly
Jan 14, 2014 | HP DesignJet 500ps (42 in.) InkJet Printer
SEVER EROR 0X9010001
Was the error preceded by 81:01 or 81:11? That is the format for the actual error on a 500 series plotter.
If so then you have a Paper-Axis shutdown.
Corrective Action: If this error code appeared but was NOT caused by a paper jam, then try the following:
Carriage Belt if it is frayed or worn out, if it is good then
Replace the Encoder Disk Assembly.
Sep 22, 2013 | HP DesignJet 500ps InkJet Printer
We have a Eaton Leonard EL2000 Tube bender Model KAC2P24T-1. The control has eight function codes that can be used to control the order or progression of movements of the machine. We do not have a copy of...
function 3 on y axis...y clear, func 4 / y...pressure die open...func 3 b axis reverse b. just for starters....many are sequence of axis operations and unique to individual part configurations.
Jun 03, 2011 | Computers & Internet
Need help with rate of change and direct variation
No need for a claculator to understand these concepts.
A linear function is a function of the form y=ax+b. It contains an independent variable,x, a dependent variable, y, and two constants, a and b,
The value of the constant a is the measure of the rate of change of the function, The value of the constant b is the ordinate (value along the y-axis) where the straight line cuts the y-axis. It is called the y-intercept, or the initial value.
If the value of b=0, the straight line passes through the origin O(0,0). The purists call this type of variation, a direct variation. If b is not equal to 0, it is called a partial variation or some other name.
If you have the graph drawn, b is read off the y-axis: You look at the graph and try to estimate the ordinate of the point where the line cuts (intersects) the y-axis.
To get the rate of change a, you select two points on the line. Let 1st point have coordinates (x1,y1) and the 2nd point have coordinates (x2,y2).
The rate of change is given by the ratio (y2-y1)/(x2-x1). You can also use a= (y1-y2)/(x1-x2). Respect the order in the two expression or you will get the negative value of the rate of change.
May 10, 2011 | Texas Instruments TI-83 Plus Calculator
Error code showing on my HP 1050c plotter
The error stands for : 24V source test failure.
And i'm sorry to say but the service manual then tells you to try the following:
- Replace the scan-axis motor assembly.
- Replace the paper-axis motor assembly.
- Replace the service station assembly.
- Replace the main pca.
- Replace the ISS pca.
- Replace the power supply unit.
- Replace the electronics module.
(only replace one component at a time)
Yeah then you have to guess which part to start with.
Maybe anybody else on this forum knows more about the error and has a better idee about the part you should start with.
Just take a good look at the machine, and check which sections of the start up works before the error is prompted.
e.g. If the carriage moves then you could say that the scan-axis motor is probably ok.
Good luck....
Sep 07, 2009 | HP DesignJet 1050c plus InkJet Printer
Xerox Workcentre c2424 Error Code "37,030.48"
Hi Ian_a_nicol:
error code # 37,030.48 means X-axis motor disconnect. The X-axis motor (second phase) is not drawing the expected power from the power supply. you can do the following to determin if the X-axis motor is bad.
1. Run the X-axis Drive test and if it passes
replace the electronics module, if not see #2.
2. Check the X-axis motor wiring for damage
or replace X-axis motor.
3. Call Xerox to have them come out and run the test and determin if it is the electronics module or the X-axis motor, but is one or the other.
pdouglasss
Oct 24, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
SQL Invalid cursor number 135 error
The error is being generated because you are trying to order on a value not in your selected fields e.g EFFECTIVE_DATE
You only have TRANSACTION_TYPE in your select statement
Sep 24, 2008 | Gupta Team Developer for PC
Actionscript
using fs command you can make your flash presentation fullscreen the code is given bellow this.fullscreen_btn.onRelease = function() { fscommand("fullscreen", true); }; this.unfullscreen_btn.onRelease = function() { fscommand("fullscreen", false); };
Sep 01, 2007 | Macromedia Flash MX
Computers & Internet Logo
41 people viewed this question
Top AXYZ Computers & Internet Experts
David Payne
David Payne
Are you an AXYZ Computer and Internet Expert? Answer questions, earn points and help others
