I have an Actiontec PK5000 which I successfully use via a cable on the DSL network. I now have a Dell Laptop with wireless capability and want to know how to activate the wireless option on my PK 5000. I am not totally computer illiterate but need detailed info. Thanks.
To turn on your wireless on the PK 5000.
If the PK5000 was setup with the default settings follow these steps to turn on the wireless.
1.) Open up an internet browser such as Internet Explorer or Firefox.
2.) Delete the info in the address bar at the top where it has your homepage the http://www.myhomepage.com, then type in the numbers 192.168.0.1 then press enter. This should take you to the modem configuration page. If not, you may have another address for your modem such as 192.168.1.1
3.) On the Modem Configuration page there are 5 options. Choose the Wireless Setup option.
4.) In the middle of the page there are 4 steps.
5.) On step one turn the wireless to On by selecting the small circle button next to On.
6.) On step two this is your wireless name that will appear when connect from your laptop, you can change this name to something you would like or you can keep the default name.
7.) On step three it is already selected the default passphrase/password that will be required when you attempt to connect to the wireless network from your laptop. The default password is in green. I recommend keeping the default Key/passphrase: you will notice the default key/passphrase is also on the modem itself near the barcode under key/passphrase so if you ever forget it you can look on the modem.
8.) On step 5 click on apply, your PK 5000 will reboot itself and the light on the modem next to wireless will turn green when the power light is a steady green.
9.) On your laptop search for wireless networks then select the network name you chose, then enter the key/passphrase from the back of the modem next to key/passphrase.
10.) That should do it, good luck.
Posted on Oct 29, 2010
Hello. I bought this modem with wi fi ,dsl router. How to set it to use this modem as a router.I want to connect my pc with lan cord & use wifi connection with my laptop and phones.
Turn DSL-router off.
Turn Actiontec off.
Turn computer off.
Connect:
* telephone-port in wall <--- 4-pin telephone wire --> DSL router
* Ethernet port on DSL-router <-- Ethernet cable --> WAN port on router
* One of the LAN ports on router <-- Ethernet cable --> network-port on your computer.
Turn DSL-router on, and wait for it to fully load, i.e., pattern of lamps becomes repeatable.
Turn Actiontec on, and wait for it to fully load, i.e., pattern of lamps becomes repeatable.
Turn computer on, and boot it.
Click Start
Click Run
Type CMD
Press Enter
Type IPCONFIG
Press Enter
Look for output like: Default Gateway....192.168.123.456
Start Internet Explorer
Type http://192.168.123.456 (or whatever numbers you saw)
Login to your router
Configure the wireless adapter inside the router
(enter an SSID, choose 'WPA' encryption, enter a password)
Disconnect the Ethernet cable from your computer
Click "View Available Wireless Networks",
and select the SSID that you provided.
Enter the password that you provided.
Oct 21, 2010 | Actiontec GT701WG Router (actiongt701wg)
Kodak ESP 7 WIFI problems
The ACTIONTEC GT124, M1000 and PK5000 Routers are not compatible with wireless-enabled all-in-one printers. These routers cannot connect to your all-in-one printer because they do not support the multicast protocol. Contact your router supplier for additional assistance and to determine if your router will be able to support the muticast protocol in the future.
Feb 26, 2010 | Kodak ESP9 All-in-One w/USB Cable & 4x6...
Got Qwest DSL internet and now PS3 can't connect to internet. "Access Point Was Not Detected" What do I do? Modem is Actiontec PK5000. Wireless internet works fine.
I found out that the ps3 is case senitive for the password so it there is caps in the password use caps..the qwest guy gave me a password like fff3093fhfhjh3r and I had to use FFF3093FHFH blah blah
Oct 26, 2009 | Actiontec Computers & Internet
CAN I USE THE ACTIONTEC GT704 FOR MY LAPTOP? its the dsl gateway. it doesnt have anything more than gt704.
yes you can use it to access internet on your laptop wireless as gt704 is a routed modem with wireless capability
Sep 28, 2009 | Actiontec (GT704WG) Router
Wireless Connection Problems between an Dell Laptop and Actiontec
Have you got permission to connect into her Internet using her wireless router?
If so you need to get the WPA encryption key from her to configure your wireless card's encryption to get access.
Jun 28, 2009 | Dell Inspiron E1505 Notebook
How to connect ActionTec T704WG (old router working with 2 other laptops) to new Toshiba Laptop
go to the wireless option in that given the view avialbe networks just find your networks and connect it disable the friewall and antivirus
Apr 02, 2009 | Actiontec Electronics (GT724WGR) Retail...
Unable to Access GT704WG Router with Laptop
normally there is a small hole for reset to factory default, just put a pin inside...
Other than that, u can also connect using network cable and access the router configuration, inside, u can edit the wireless security keys
Feb 27, 2009 | Actiontec (GT704WG) Router
Actiontec GT701-WG won't operate wirelessly
In looking on the internet the unit is a DSL gateway. Trying to use it on cable internet is not a real good way to set up your network because I believe the router is waiting for a DSL sync before the services turn on. I would spend the money and pick up a Linksys or Netgear G router, there around $50.
Jun 01, 2008 | Actiontec (GT704WG) Router
Apple user attempting to fix dad's dell laptop windows xp home edition
I'm confused because you say your trying to make a lan connection on the dell laptop but your connecting it via firewire into a DSL modem. doing this method would be a WAN connection and not a LAN connection. To make a lan connection you need to connect the laptop via network cable (or wireless connection) to a router that is connected to your actiontek dsl modem.
I can help you connect the laptop to the internet but 1st i need to know if your trying to connect it to a router or did you want to do a wan connection from the dsl modem.
Thanks,
Brad Nelson
Mar 15, 2008 | Actiontec (GT701WG) Wireless Router
Computers & Internet Logo
2,050 people viewed this question
David Payne
David Payne
