Question about Dishwashers
I found the upper spray arm laying in the top rack of my dishwasher. Do I just pop it back on ?
  • Dishwashers Master
  • 43,501 Answers
Yes you can probably pop it on.... but it will not stay...
replace it..
That is not that hard to fix and you can easily buy the partsyourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Oct 16, 2010
Why is the upper sray arm is not working in kitchenaid model KUDR01TJ
There are 2 spray arms for the top rack. A small one on the dishwasher top and a bigger one attached to the bottom of the upper rack. Both get water feed from a flat tube that runs up the back wall of the dishwasher. Not much to the very top little arm--just check the spray holes for any food blockage and try to clean with a brush or tooth pick. The bigger arm on the bottom of the top rack gets its water feed through a hole about half way up the flat tube on the back wall. When you push the rack all the way in, it has to plug itself into that hole in the back wall. Check that plug in area and make sure nothing broke off that would keep it from making a good seal with the rack all the way in. All check all the holes in the spray arm for food blockages. On the very end of all spray arms is a main hole that is the drive hole to spin the spray arm. The water shoots out that hole and acts like a jet engine to push the arm around. Make sure those holes are clear.
Mar 24, 2015 | KitchenAid Dishwashers
Why doesn't my Bosch SHU43 c06uc dishwasher have any cleaning force?
With your dishwasher empty, roll out the bottom rack. The feed line for the upper spray arm runs from a pump outlet directly behind the lower spray arm spindle. This tube runs up the back wall of the dishwasher and mates with the upper rack when it is pushed in.
This feed tube simply snaps into place in the bottom of the machine. It is a high pressure line that makes an immediade 90-degree bend towards the rear of the unit. They have a tendency to pop out. When and if it does pop out you get almost no water coming out of the upper arm and you lose effective pressure in the lower arm, too. The cure is to push that feed tube back down firmly into the port until you hear it snap into place. While you have the lowere rack out it is a good idea to clean the intake screen out and check for any debris in the intake well.
May 24, 2014 | Bosch Dishwashers
My dishwasher is not cleaning the dishes on the top rack. there seems to be water dripping from the top inside of the dishwasher but the dishes are not being cleaned. I am making sure the funnel on the top...
There is a pipe/tube that runs up the back of the inside of your dishwasher. This provides water for the top spray arm. The spray arm has a feeder tube that covers the pipe in the back. If for some reason the feeder tube has come dislodged, the water just drips back down into the dishwasher, never touching your upper shelf. My kids used to jam cutting boards and other large items into the lower shelf and in so doing, would dislodge the upper spray arm feeder tube. Just pull out the upper shelf and check to see that the tube is in the correct position. This should solve the problem.
If not, then the spray arm may have debris in it that keeps the water from being forced through the jets. You'll need to flush the arm with the spray attachment on your kitchen sink. I sometimes use tweezers or a toothpick to dislodge bits of peelings, paper, or bone that manage to get into the sprayer arm.
I hope one of these tips helps. If it does,please come back to fixya and rate my answer.
Jul 03, 2011 | Frigidaire FDB949GF Dishwasher
Top rack - glasses etc... not getting clean - bottom rack and utensils seem fine?
Jul 02, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Kitchenaid KUDP02CRB - top rack dishes are not getting clean
maybe not... if unit is incorporating more than one spray arm,chances are the upper spray arm is not getting water.pull top rack forward,gaze under top rack near rear manifold.slowly push rack back in.notice if manifold inserts into upper wash feed.if so,possible motor issue. if not,bingo was his name-o!
Nov 13, 2009 | KitchenAid Dishwashers
Very low pressure getting to spray arms
I removed the lower spray arm, and then the filter. I found that there was a lot of buildup under the filter area. I scraped the buildup off. I found that it was restricting the input of water flow to the pump
Aug 01, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
How do you fit the upper spray arm to the back of the dishwasher
The upper spray arm does not fit on the back of the dishwasher. There is a separate "Extra Tall Item Sprinkler" piece (about a 3-4" round gray piece that looks like a shower head) that mounts in the back of the dw.
Note that this option is only to be used with the top rack removed (i.e., for washing tall items in the lower rack). Refer to page 37 of the Use & Care Manual that came with your dishwasher.
Jun 23, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
Bosch dishwasher - top row of dishes do not get clean
There is a screen that you can remove from the sump of the dishwasher to clean. Just twist it to the left and pull it out. I have some tips that you might want to check out if this does not resolve your problem.
<a href="http://tclaundryrepair.com/">St Paul Appliance Repair</a>
Feb 25, 2009 | Bosch 24 in. SHU66C05 Stainless Steel...
Top arm not spinning
only the top rack isnt getting clean?
there is a little plastic circle in the middle of the bottom of the upper spray arm. turn it counter clock wise to pull the upper spray arm from the upper rack. make sure that isnt clogged and the spray holes are not clogged. otherwise....
the piece that the bottem spray arm plugs into and runs along the back wall of the tank to the top is called a feed tube. pull the bottom spray arm out. now you can see the part of the feed tube that feeds the upper spray arm water. does it pop out freely and easily? if so then you need a new feed tube, if not then its most likely your not achieving the right water level or your impeller connected to your circulation pump(motor) is clogged not supplying enough water pressure to travel up the feed tube to spin the upper spray arm.
Jul 13, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Upper spray arm is not turning round even though water is coming through. We have checked the internal system for blockages and the machine is filling / draining as normal. When a full programme is run,...
I found the problem to be neither blockages of the upper arm or roof spray arm or the upper basket arm hitting the the back of the dishwasher. the problem was that the pump inlet where the food scraps are macerated was blocked with all manner of gunge including small chicken bones plastic and other detritus. Removal of the macerator housing under the upper filter housing using 2 different sizes of torx driver easily fixed the problem. Probably why the upper dish rack cleaning degraded overtime, Directly proportional to the amount of detritus blocking the intake screen behind the macerator.17a8801.jpgb9e8fa8.jpg789f2b8.jpgfb7a626.jpgator. See pics
Jul 13, 2008 | Dishwashers
Dishwashers Logo
42 people viewed this question
Top Dishwashers Experts
Owen Barnes
