Question about Zoom G1x Guitar Multi Effects Pedal with EXpression Pedal
I have a zoom 505ii guitar pedal. The sound cuts out and "A1" flashes on the screen. I have checked the ac adapter and there doesn't appear to be a problem with the power,
4 Suggested Answers
bolinlamar
  • 157 Answers
SOURCE: my zoom 505 2 distortion pedal for my guitar will
I have had this same problem with mine, since the adapter jack is loose it's probably broken loose from the circuit board inside. I had to carefully dis-assemble and re-solder the adapter jack back to the circuit board. This is un-fortunately a weak point on some of Zoom's pedals, when you or if you get someone who is good at soldering to do it for you ask them to beef the solder joints up a little to help keep it from coming loose again. I re-did mine and I've never had another problem with it.
Posted on Aug 28, 2009
  • 1137 Answers
SOURCE: how to reset my Zoom G1 Guitar multi effects pedal
Here is a link:http://s3.amazonaws.com/samsontech/related_docs/G1_G1X.pdf Pay attention to page 25 Restoring Factory Defaults.
Posted on Jul 26, 2010
SOURCE: I have a Zoom 9000
I'm a Zoom 9000 owner (since '93, I think) Did you try batteries only? Are you plugging the guitar into the "in / power" jack and not mistakenly using another jack? When you plug in the guitar, in to the Zoom 9000 does the window come on with the settings shown? Sorry, I know some of these are obvious but always the chance of us being human. If all that seems fine, then I would read though a manual to see if maybe it is a setting problem, i.e., sound somehow got inadvertently turned off. If you don't have one, an internet search will lead you to one. Sorry, wish I knew more.
Posted on Oct 17, 2010
Noise
This seems to be a battery problem unless you use an AC adapter. If it does it on AC, I would check my guitar cord and power supply. The wrong power supply could do that and a bad guitar cord can as well. If you use a speaker cable as an instrument cable, it could do the same.
Mar 26, 2014 | Zoom G2 MultiEffects Guitar Pedal
It blinks with "be" and turns off
It may be "but" that you're seeing, which indicates the batteries are low. Use the AC adapter made just for this model only, and the guitar needs to be plugged in to turn the unit on. A full manual for this Zoom model can be found here:
https://www.zoom-na.com/sites/default/files/products/downloads/pdfs/E_G1_G1X_3.pdf
Dec 01, 2013 | Zoom Samson Technology Zoom G1XN Multi...
No power or display when I turn on the gadget, even using battery, it will display sometimes but a blink oh "be" letter appears on the screen
My zoom g1x displays BT even though i don't use any batteries for it
You need to replace the power resistor R54:
http://gisywall.blogspot.it/2016/01/zoom-g1xn-continuously-shows-bt-on.html
Sep 28, 2012 | Samson ZOOM G1x Guitar Effects Pedal
My DD3 pedal doesn't work. Checked the battery and the adapter. The light won't go on it will only light momentarily when I click through the modes. Any help would be appreciated. Greg
Check all connections including the battery clip if you use a battery, and the adapter jack if you use the AC adapter. Also check you guitar cable connections as the pedal turns itself off if the guitar plugs have a loose connection. Make sure the guitar jacks on the sides are tight and don't need tightening. Any of those issues could cause the pedal to operate sporadically or not at all.
It could also be and IC problem internally on the pedal's circuit board, but before you open anything, check all the connections non electrical issues can occur more often on pedals.
Feb 19, 2011 | BOSS AUDIO SYSTEMS Boss Dd-3 Digital Delay...
The zoom g1x is dead. no power. tried adapter from my other zoom pedal but nothing. opened it up and everything seems in tact. was working fine saturday, dead sunday. only one month old.
The first thing i would check is the ac adapter .Make sure you are getting the correct voltage from the adapter.If you know how to use a voltmeter or know someone that has a volt meter,check it with it unplugged from the guitar pedal,most of these have a voltage range from 9 to 12 volts dc.you could also take it to your local radio shack or local repair shop and they will be glad to check it for you for free.after you confirm the adapter and it is ok then the next thing you will check is the input jack assy on the pedal,input jack assy are soldered onto the board at the factory,these jacks ,no matter what it is are famous for cracked solder joints where the pins of the jack go into the board because of stress delivered to it during plug ins and plug outs.if you dont know how to use a sldering gun or dont want to you will have to take it it to your local repair shop-cost should be around 15.00, 20.00 tops,make sure that your guitar cables are good,check the 9volt battery inside the unit if it takes one,if its dead that could be your problem,if all above fails i would send it back to the factory or wherever you bought it.,good luck been playing for about 30 years myself,rock on
Jan 24, 2011 | Zoom G1x Guitar Multi Effects Pedal with...
Hi.why my zoom g1x has no power.im using a universal adator...i am in phillpines.power volts here..220 volts.how is the setting of my adaptor then?
I have a ZOOM GX1XN and it doesn't like universal adapters much. Using one with the wrong voltage or polarity may permanently damage your pedal. Try to obtain a proper ZOOM AC adapter (part number AD-0006 or AD-16) if possible. These are dual voltage and will work equally well with both 220 and 110 volts. Failing that you need an adapter that will give a DC (direct current) output of 9 volts at 0.5amps - maximum 4.5 watts. The outer contact (sleeve) of the adapter needs to be positive (+ve) and the inside contact negative (-ve). Lots of universal adapters are the other way around with the sleeve being negative - but some have a multi-connector on the end with both positive and negative sleeves.
Jan 08, 2011 | Zoom G1x Guitar Multi Effects Pedal with...
I have a Zoom 9000 Guitar effects processor, and although I have its original adapter, and although its red light flashes and power is on after plugging in everything, I could not get any sound from my...
Oct 14, 2010 | Zoom A2 Acoustic Effects Pedal
My zoom 505 2 distortion pedal for my guitar will not function with batteries and the ac adapter slot is loose in the back, please help
Mar 09, 2009 | Zoom Music
Zoom G1x Guitar Multi Effects Pedal with EXpression Pedal Logo
375 people viewed this question
Top Zoom Music Experts
Barry Webster
Level 1 Expert
patonplace
Level 1 Expert
Are you a Zoom Music Expert? Answer questions, earn points and help others
