Question about D-Link Computers & Internet
Instruction manual for my D-Link 2 Router DSL- 5027
  • 135 Answers
SOURCE: router setup help
You need to connect the cable that you used to connect to your PC, to the WAN port on the router (it might say internet). Then, you need to connect one of the computers to one of the LAN ports (might have numbers, so you connect it to 1). You then need to login to the router through your browser (generally the address is http://192.168.1.1/ but you should check the documentation) and ask your ISP for the PPPoE information so you can setup your router to dialup for you (otherwise you could use the dialer you've had on your PC, but that doesn't work as well because you might have to share the internet connection).
Posted on Jan 06, 2008
  • 221 Answers
SOURCE: WAN
The wan port is what you hook your modem to. Wan stands for Wide Area Network, which in your case is the internet. Your house with your 2 pc's and networking equipment would be considered a Lan, local area network.
The 4 ports on the router are switch ports, when you hook the modem up to the switch instead of the wan port the modem will only allow traffic from one physical, (MAC) address to pass through, this is why only one of your pc's can access the internet. The wan port on the router has its own MAC address, so the modem will associate with the wan port and trust all traffic that comes from that port.
Finally, after you have connected the modem to the wan port, pull the power cord on the modem then plug it back in to reset it, this will force the modem to orient with the wan port.
Posted on Jun 01, 2008
  • 67 Answers
SOURCE: Connecting 2 routers (ASUS WL-500W and D-Link DSL-G604T Wireless)
This will give you a "Double NAT" setup. Meaning, Your D-Link router is connected to the external internet address assigned to you by your internet service provider. More than likely this is a DHCP address you do not control. Your D-Link router is then translating the address to the 192.168.1.x network. This is the first NAT translation. You are then connecting the ASUS router to DLINK, causing a second NAT translation. (Internet ADSL --> D-Link WAN Port --> D-Link Lan Port --> ASUS WAN Port --> ASUS Lan Port to computer/server/etc. ) If both of your routers are giving out DHCP addresses, then this is all that is required.
Posted on Dec 10, 2008
2Gigs
  • 141 Answers
SOURCE: setting linksys WRT54GX Ver2 with D-Link DSL-2450T ADSL2+router
Your router needs to be configured. Call Linksys Technical Support. If they cannot help you try this http://technicalsupport.blog.friendster.com
Posted on Feb 15, 2009
SOURCE: I can't connect our belkin
HI! I bliv u are having some issue setting up ur router.. I will be more than glad to assist u. here are the steps u need to do:
1. press the reset button on the back of the router for 20sec..while pressing the reset button, unplug the power plug and after 2secs while pressing the reset button plug it back in and press for 30secs after that unplug the router for 15secs then plug it back in..once all the lights are solid and ok
2. connect the ethernet cable to port1 of the router and the other end to the lan port of your computer..
3. pull up ur browser then type at the url:192.168.1.1.or 192.168.0.1 or u can check the routers default gateway by right clicking the network icon on the lower right of your task bar and click on status and it will show the ip address of the computer, subnetmask and default gateway, the default gateway is the routers ip address, once u type in to the url, it will ask u the username and password, by default the username is admin and the password is 1234 or just leave it blank
4. it will show the setup page of the router. u can set the router on the specific internet setup that u have.
a. if ur isp is a cable company, normaly u need to do a mac clone on the router setup page by cloning the computer that is reg to the cable company, how to determine it. ex. the computer that is reg to the cable company is a desktop or laptop, if this computer is connected to the modem directly and u can access internet.
b. once u determined it u need to connect this computer directly to the router and do a mac clone and set ur internet settings to auto-dhcp..then save the settings and after that, unplug to the power of the modem and router, plug in 1st the power of the modem then once all lights lit, plug in the router, then once all lights lit, try to pull up a browser that ur computer is connected directly to the router.. ur cable connection shud be, cable from the modem will go to the WAN port of the router and connect ethernet cable on port1 going to the lan port of the computer..once u can access the internet, u can now access again the setup page of the router by typing at the url:192.168.1.1 and u can setup the wireless settings, u need to create a ssid or wireless name and a security..
5. If ur isp is a dsl normaly they give u a username and password to connect to the internet, ur settings on the router should be PPPoe
6. If ur isp gives u a static ip address settings, u need to set the router to isp setup.
a. how to check the isp of the isp given to u..
1. click on start
2. run
3. type cmd
4. it will show a dos prompt
5. from the dos prompt type ipconfig/all
6. it will list the ip address, subnet, default gateway, dns server
this settings should be type in to the settings on the router for static ip addressing..
if you have any querry pls feel free to get in touch.. good luck
Posted on Aug 31, 2009
I cant log in to my d-link router
Here is a link to the manual, it should explain how to change the settings:
http://www.dlink.com/-/media/Consumer_Products/DSL/DSL%20G604T/Manual/DSL_G604T_Manual_EN_UK.pdf
Apr 13, 2014 | D-Link DSL-G604T Wireless Router
INET light is on not able to connect to internet
Checked the instruction manual online. There's no INET light indicated. There's Power, Status, WAN, WLAN, and LAN LEDs. The WAN LED only indicates that the WAN port is connected to another device, e.g., cable or DSL modem. Check on your cable or DSL modem to see if the Internet light is on. If so, then you'll need to log into your router and go through the configuration/setup per the manual for your type of connection.
Oct 18, 2013 | D-Link 802.11g Wireless Router WBR-1310...
I forgot my wireless DLinks G604T passwords. I open the Dlink admin but can not find where the PW section is. Please help
You can download the manual from this WEB site.
ftp://files.dlink.com.au/products/DSL-G604T/REV_A/QuickInstallGuide/DSL-G604T_QIG_v1.00.pdf
Page 8 gives you instruction on changing the password.
Feb 23, 2011 | D-Link DSL-G604T Wireless Router
D-link adsl router driver model no dsl-502t
Click on the link below to download the d-link DSL-502T driver, after you download and install it, restart your computer for the changes to take effect:
http://members.driverguide.com/driver/detail.php?driverid=741867
Feb 15, 2011 | Computers & Internet
Changed from DSL, to cable no router connection
1. You need to make sure that you have a "straight through" cable and not a "crossover".
2. the yellow cable that your cable company provided is the cable that goes from the rj45 wall connector to the "WLAN" connector in the back of the router.
If you go to router manufacturers site you will find the instruction how to to connect your router to the cable modem.
3. check also the firmware updates for your router at this site and download.
4.Use your setup disk and follow the instruction set for cable also. This should walk you through the proper setup .
YOu didn't provide the model number of your router, I would have given you the setup site for your particular router.
You can go to D-Link's site and download the PDF instruction also.
May 15, 2010 | D-Link AirPlus Xtreme G DI-624 Wireless...
Looking for updates for belkin G54,802.11g
You can go to this link and download the updated firmware for this router http://www.belkin.com/support/article/?lid=en&aid=5027
Hope that helps..........
Oct 10, 2008 | Belkin (F5D7230-4) Router (587009)
Lan connection
Device your needing:
1. Modem
2. Router
3. Hub / Switch
4. UTP cable
5. RJ45
I'm sure you have a modem, right? First you need to have a router. The manual on your router will teach you how to connect to LAN, you just follow the instruction.
For cabling instruction and other info. just e-mail me ragutz2002@yahoo.com
I can't put all the details here..
Nov 10, 2007 | D-Link SWT DSL-504T ADSL MODEM with 4...
Convert from DSL to cable
I think wat ya need to do is completely set it all up again, right from the start.. I enclose a link for a manual & the other one is for the "Driver". http://www.retrevo.com/s/D-link-DI-514-Routers- review-manual/id/420ci364/t/1-2/ www.opendrivers.com/driver/232575/d-link-di-514- wireless-router-firmware-1.03-free-download.html Your "Provider" will have a different setup and address etc... indeed maybe they will have setup software and logon details on their web site, I suggest ya check that.
Sep 06, 2007 | D-Link DI 514 Wireless Router (DI-514)
Computers & Internet Logo
161 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
