Question about KitchenAid S-Series 24" Tall Tub Built-In Dishwasher - Stainless-Steel
I have dishwasher kudko1ilbs6 and it will not start. I know there is a code to restart it because i've had this problem one other time. Will you please,please,please help me
  • 1 more comment
  • Jana Lawson Oct 16, 2010
    This solution did'nt work. If you have more ideas please send them. Thank you!
    This did not seem to be the fix. Any other ideas? Thank you so much.
  • Jana Lawson Oct 19, 2010
    The solution yoy gave me is not working. Please send me any other solutions you might have. Thank you! Jana
  • 10,865 Answers
Hello. Here is the code. Write it down and save it for future reference
Thanks for using FixYa. To resolve this you will have to reset the console, press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
4 thumbs up please. Thank you. Joe
Posted on Oct 16, 2010
  • KitchenAid Master
  • 3,247 Answers
Try this one first
Air Dry/No Heat Dry/Energy Saver Dry option key for 4 seconds
If it does not work, don't be disappointed. There are other options which I will have to dig out for you. Sometimes the problem is also linked to the door switch not working. Keep me posted.
Posted on Oct 15, 2010
  • Sam Oct 19, 2010
    Try this sequence within 5-6 secs - High Temp Wash, Air Dry, High Temp Wash, Air Dry
    If nothing happens, it is likely the thermal fuse or door switch are playing up.
    Refer to the door panel assembly diagram for location and availabillity of the parts.
    Please rate the solution if you found it useful, otherwise post a comment.
Frigidaire dishwasher Model #fghd2433kf1 flashing light with Error 'S'. Dishwasher will not start. I was able to restart it last time this happen by disconnecting power and then pres
Thank you for your post, Cathie Sanchez!
I understand that your Frigidaire dishwasher is displaying error code "S" and will not restart. The error code "S" usually stands for sanitize, this could also be a miscommunication within the control panel. I would recommend performing a reset on your dishwasher and you can do that by disconnecting power from your dishwasher for roughly ten minutes. If you continue to experience issues with the error code I would suggest having a professional technician out for proper diagnosis and repair. Hope this is helpful. -Matt
Jan 07, 2015 | Frigidaire Dishwashers
Error code 125
Hello Lou,
I see that your Frigidaire dishwasher will not start. I would recommend giving the appliance a hard reset. You will do this by switching the circuit breaker off that the dishwasher is attached to. When you do this you will want to leave it off for 20-30 minutes. Once the 20-30 minutes has elapsed, bring power back to the dishwasher and try to restart it. If you are still receiving a 125 error code and the dishwasher is not starting, I would suggest contacting your local authorized technician to diagnose and see why you keep receiving this error code.
-Best Regards-
Jan 22, 2014 | Frigidaire PLD4555RFC Dishwasher
Need manual for EX500 dishwasher
Having ploblem in starting , I press the start button but doesn't respond. I turn off the machine from the switch, then restart it and a code number comes up as PF. Don't know what that means, have no manual?
Dec 15, 2013 | Electrolux Dishwashers
Dishwasher contuallycuts out through entire run cycle
Hi Andrew - Try resetting the unit by either unplugging it or flipping the household circuit breaker to the off position. Wait roughly ten minutes and turn on the dishwasher. Confirm that the door is properly latched and try selecting a cycle. If resetting the power does not correct the issue, it could potentially mean a number of things: wiring failure, damaged cord, faulty door latch assembly or control board. I would personally contact a professional to accurately diagnose the washer to determine the root cause to reduce the risk of unnecessary parts.
Jun 01, 2013 | Electrolux 23 in. ESL624 Built-in...
Hard start on hot restart
Try to check your fuel pump pressure, or replace the fuel pump
May 30, 2013 | 2002 Honda Accord
My electrolux dishwasher is throwing an E32 error
Hello Heber Allred - Are you certain that the error code is E32? This manufacturer does not have an E32 error code for any dishwasher. They do have E02 or E12. Is the hum noise more like a grinding noise? If so, then I recommend contacting a professional to move forward accurately. The unit may be experiencing an issue with a faulty drain motor.
Dec 11, 2012 | Dishwashers
I have a LG dishwasher, and from the word go I've had problems, I try not to use it any more. it started with flashing LE and bing bing bing all the time, now it flashes HE, I think its time to throw...
the le code is motor code the motor is not turning the he code is heater code if the motor is locked it will also bring up the he code because the over stat on the heater will cut out because the water cannot circulate
Oct 25, 2011 | Dishwashers
We have just installed GE Model GLDL560NSS. It fills with water and it emptys the water but it doesn't actually wash or rinse. The water just sits at the bottom of the dishwasher tub
I had the same problem running the dishwasher the second time. The first time worked perfectly. I thought the problem was from the sensor not reading enough water to actually start the wash cycle. It sure uses less than any dishwasher I've had before. When I tried to restart it the machine drained the water that was in it. I later found out it does this automatically when you push the restart button. I poured water from a bucket into the dishwasher and tried this a few times and found that on the fourth try it ran fine and haven't had a problem since. I didn't know how much to put in and did overfill it once. Maybe the sensor float or whatever was stuck and overfilling it helped.???
Jul 23, 2008 | GE Dishwashers
Lg dishwasher trouble codes how to clear
my LG dishwasher error code TE and won't start- can you tell me what the problem is?
Jun 30, 2008 | Dishwashers
KitchenAid S-Series 24" Tall Tub Built-In Dishwasher - Stainless-Steel Logo
199 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
