Question about Garden
I'm a wife with a do-it-yourself knack. I recently purchased a Ryobi 10 in. BTS211 table saw. I find the manual complicated as far as how to actually use the device. Can you recommend where I can get guidance (online videos, how-to DVD's, etc.) on how to use the table saw safely and effectively? I learn so much better when I can see examples with descriptions. Thanks for your help! Dawn
I am a retired contractor.
I have a shop with a 10" table saw.
And I have opinions about safe operation.
For safety, turn saw off when making adjustments.
1) Raise blade:
There is a handle you turn to raise the blade.
If you are cutting 1/2" plywood, then set your blade at 3/4" or a bit more.
Keep blade low and away from hands.
Keep hands high and away from blade.
For 1-1/2" thick 2x4, I usually set the saw at 1" and run the board through, and then flip the board over and run it through again, taking 2 passes to make really thick cuts.
2) Blade angle
There is a second handle you turn to set blade at an angle up to 45 degrees
Angle cannot be set if saw blade is fully raised >> lower blade to half way or less and experiment.
Angle cuts are difficult if wood is not perfectly flat and square, or too long or too short (boy is that helpful ... but cutting angles takes some experimentation)
3) Table Guide
You stand behind power saw to operate
The saw table guide is on left side of blade and clamps across the table
The guide markings show inches >>> these are usually approximate
To set guide for accuracy, measure distance from blade to saw guide, and then clamp guide down.
4) Push sticks push sticks push sticks and other safety stuff
Let me emphasize safety first last and always
A table saw will chop your fingers off in a blink
On the plus side, I hear it doesn't hurt. But OMG.
There is a very strong human instinct to reach in with your hand when working on stuff
Train your mind >> if the saw is running, do not lean or reach into the saw
If a board is stuck >>> turn off the saw and wait for full stop
If you wear baggy clothes of a loose shirt, the saw will grab you and pull you in too fast for you to react
Keep your clothes tight and your arms bare
Always use push sticks or push boards::
Notice the saw blade is set low
Two push sticks are used to assist when cutting short board > one stick holds down the board ahead of blade, the other stick is pushing board through saw.
Keep your hands away from the blade no matter what.
The person stands behind and to the side of the board being cut.
The cut wood is supported by a catch table (in this case there are rollers)
Where to stand
Obviously you stand behind the saw to cut wood, and sometimes with long pieces, you can move in front and pull them through, and sometimes with large plywood you stand kinda back and to the side.
Why not stand directly behind a saw? Because saws throw stuff back.
When 'ripping' a board lengthwise as shown in photo above, if the saw catches the board just right, it will throw it backwards like a spear.
If a board 'binds' the saw causing saw blade to stop, then turn off saw, back up the board, and cut again.
Crosscut guide
The saw comes with a T-shaped guide that fits into a groove.
This is a 'push stick' >>> you use it to cross cut a board, and it lets you stand to the side of the saw blade so things wont flip back on you
When using the cross cut guide, remove the table guide that clamps across the saw, or push the table guide WAY back so pieces don't get caught in a bind and the blade flips up the piece and hits you in the face
Remember, the saw throws everything backwards
The saw is strong and fast, and you are best when traveling slow and without rush around your strong friend.
Posted on Oct 16, 2010
  • Anonymous Oct 16, 2010
    Oops, the table guide is on RIGHT side of blade >>> not left
How do you replace a broken bevel locking lever on a Ryobi RTS10 table saw?
buy the part and fit it or take it for repair.
parts
Ryobi RTS10 10 Table Saw Parts
parts, better schematic
Ryobi RTS10
your saw
RYOBI Tools
service centres
RYOBI Tools
Jun 04, 2017 | Ryobi Saws
My Ryobi table saw won't start, any ideas?
There is an overload protection breaker on the bottom left. Check it and the power switch with a meter to make sure they work.
Sep 29, 2015 | Ryobi Bts10 Table Saws
I am looking for a part for my 10" Ryobi table
http://www.ereplacementparts.com/ryobi-table-saw-parts-c-7931_7954.html
http://www.searspartsdirect.com/
Probably other places too.
Here are the results of a google search for you.
http://www.google.com/search?source=ig&hl=en&rlz=&q=ryobi+table+saw+parts&aq=1&aqi=g10&aql=&oq=ryobi+tabl
Hope this helps!
May 09, 2011 | Saws
We just purchased a previously owned Ryobi table
Try the internet Quite often can find pdf downloadable manuals for most things
Oct 22, 2009 | Saws
I have Ryobi 10
Your can download a fresh copy by clicking RIGHT HERE. Just click the "get manual " button and you'll get a fresh pdf copy. an adobe acrobat file.
Sep 02, 2009 | Saws
Ryobi bt 3000 table saw belt installation diagram
The BT3000 actually has TWO v-belts! Here's a link at the end of this solution to an exploded diagram. Basically you have a major disassembly, but it really isnt that complicated.
More great info on the BT3000 is available from the web site http://bt3000.com/
I have a BT3100 saw, and it is a good tool, but does require attention in maintenance procedures, but Ryobi did outline the necessary steps in their manuals. The above website also has the owner manual if you need one.
  1. Unplug saw
  2. Remove the blade
  3. Lower mechanism all the way to the bottom
  4. Flip over saw and lay on it's top
  5. Remove the blade guard panel opposite the motor
  6. Unbolt the motor assembly and remove the belt cover
  7. Replace the broken belts
  8. Re-assemble (be careful not to cross-thread the bolts in the aluminum housings!)
http://bt3000.com/Manuals/BT3000-Parts-Manual.pdf
Mar 18, 2009 | Saws
Garden Logo
193 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
