Question about Apex Computer Technology TX-381 Micro ATX Mid-Tower Case
I built a system in this case and I went to turn it on and nothing happened... except the power light flashes. Any suggestions?
    Sergeant:
  • 183 Answers
You have troubleshoot all that devices. first of all, make sure that all the power button connector correctly attached. After that look that processor is properly attached or not. Then check SMPS, that's OK or not.
Posted on Oct 23, 2010
Wont power up
there is may be 2 problems
1. check your CMOS battery. may be that battery is discharge. if yes you have to replace it.
2. may be your processor is not seance by your motherboard. in that condition you have to repair your motherboard.
Jan 03, 2013 | HEWLETT-PACKARD HP G72261US Notebook
Nothing happens
Hello download the manual here:
http://www.msi.com/product/mb/890FXA-GD70.html#/?div=Manual
And check the front panel connections again.
You might have connected this the wrong way.
Good luck
Oct 11, 2012 | Intel Motherboard
My computer will not turn on
many, not all, psu's will internally tripo after this happens. how to reset:
1 if it has an on/off button turn off for 1 min and turn on.
2 if it has no button but has a 110/220 switch, unplug it then switch to 220 then back to 110 (also this may be 115/230 or even 120/240)
3 if it has neither of these, unplug it for 10 mins, then replug it and start up.
also when you opened the case did you smell anything funny? if so i would say that the mobo and/or cpu are done for. i doubt this tho because you had them on a surge, but it is possible.
1 more thing when you opened the case did you by chance knock a wire loose from the mobo?(motherboard)
after re reading your post i question whether the surge strip is good, because you said it was tripped and yet you had the posu light on. or did you mean a light inside the case of the computer itself?
if none of these suggestions help you please re post with answers to the questions i asked thanx and hope i have helped.
Jun 08, 2010 | Hi-Pro PSU HIPRO|HP-E3509 300W OEM...
ASpire one Acer wont turn on.
Pretty new system, so try on just AC power (remove battery) failing that, get in touch with Acer for repair under warranty
Jun 29, 2009 | Acer Aspire 5100 Notebook
Front light flashing
Solution to the problem:
Discovered that the dishwasher was covered by our household insurance policy. Phoned and arranged for it to be repaired or replaced (no charge). Engineer coming on Friday.
Jun 10, 2009 | Whirlpool 24 in. ADG6340 Built-in...
Vizio P50HDM No Picture/No Sound
this is most likely the sustainer board(s) problem. Replacing the sustainer boards should correct this problem for you. you can get the parts at vancebaldwin.com
May 29, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
replace the sustainer boards should correct this problem. New sustainer boards may cause red and green pixilation. If this happen, replace control board and TV is as good as new.
Apr 05, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Nothing happened when installed new computer - Please help
since the components are new,it must be other problem...I think that the problem is at the motherboard's jumpers...the power button, the restart button have wires that connect them with the motherboard so, u must not mess up the jumpers...i suggest u should download your motherboard manual and see exactly how the new components should be installed...
HERE, HOPE IT HELPS...
http://users.iafrica.com/g/gl/glynhall/hohweb/manuals.htm
Nov 26, 2007 | MSI K8D Master -FT For AMD Dual Opteron...
System Error (OeO1)
With a system error there is actually no way to fix this problem at home, it will need to be sent in for service. A system error is internal in the camera and usually is a software issue. The service center's number for Casio is 1-800-706-2534, then option 1.
Jul 14, 2007 | Casio Exilim EX-Z57 Digital Camera
Power light flashing/ no picture
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
Jul 11, 2007 | Toshiba 56H80 56" Rear Projection...
Apex Computer Technology TX-381 Micro ATX Mid-Tower Case Logo
Top Apex Computer Technology Computers & Internet Experts
David Payne
David Payne
Are you an Apex Computer Technology Computer and Internet Expert? Answer questions, earn points and help others
