Computer cannot read camera
Whether on my desk to {wit the dock} or on my laptop, when I connect the camera, both computers give the same warning:
"can not read the device"
I tried a new USB, contacted Kodak and followed their seven pages instructions, to no avail.
I have XP and the camera is a Kodak EasyShare Z612.
Can you please help?
Thank you.
Helyett
helyett1@yahoo.com
    Sergeant:
  • 284 Answers
You might have a USB registry error, you have to clean the registry. or you can try to use another port on the laptop. if none if this work and youve tried it on other compauters and same results, then your webcam is defective. time for a replacement.
Posted on Jun 03, 2008
Problem with Western Digital 1.0TB WD10EALX hard drive.
Having looked at the dock, if it's not appearing in the windows disk management I'm afraid you'll have to try another i/o method to test whether the drive is ok. The easiest option is to find someone with a computer which has a spare sata slot and partition it with that (assuming it sees it) or try a different device like a sata to usb converter. Alternatively you could make a linux or other bootable usb stick with formatting/partitioning utility and put the drive in your laptop, boot from the stick and partition it that way. I don't think there are any user settings in the dock you have and no jumpers on the drive so you're scuppered. Let us know how you get on?
Of course having partitioned it it might just not be compatible with your dock, although
Just one more thing if you haven't, try connecting the power to the dock before you plug it into the laptop and try each of your usb ports
May 16, 2014 | Western Digital Computers & Internet
Will not let me upload pics says camera not connected to usb port
The error indicates that the computer is not getting an understandable signal from the camera (or dock if you are using one). The solution will be in discovering why the signal isn't getting through, or deciding that the camera or dock is defective.
Verify that the camera battery is charged. Then turn all devices (computer, dock and camera) off. Remove every cable and wire between computer and camera. Unplug power to the dock.
Examine each connection carefully. Look for dirt, bent pins, loose connections, or anything "strange". Look at the bottom of camera too, where it sits on the dock.
Reconnect the wires and cables, power everything up and see if any improvement.
If no improvement and you have WinXP or Vista, Do a System Restore back to a date when the camera connection was working. Restart and check for improvement.
If no improvement, check computer update history. Have any Microsoft updates been applied since the last time the camera connection worked? If so back them off and check for improvement.
If no improvement or no MS updates, decide that the camera or dock are defective and return them. Unfortunately, electronics sometimes fail. If you like the camera, give a replacement a chance.
Take the memory card out of the camera and copy the pics through a card reader.
Good Luck
Nov 03, 2011 | Cameras
Sometimes when I try and open my web camera, I get a Warning pop up on my desk top saying, "WARNING. YouCam cannot connect to your webcam (HP Webcam -101). Try selecting another capture device within...
Hi and welcome to Fixya!
If you're using a Lenovo laptop, you may inadvertently switch off the camera. Try to switch on (or off) the webcam by pressing the Fn key and the Esc key and then release both at the same time. An icon will appear indicating whether the camera is turned on of off.
Hope this helps!
Takasashi
Jul 19, 2011 | Computers & Internet
I have an EasyShare Z760 Digital Camera w/ the dock. My camera was working fine yesterday however I tried to transfer pictures today w/ no luck. I plug the dock into my computer (same computer I used...
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa.
Organize edit and share your photos
Jun 17, 2011 | Kodak EasyShare Z760 Digital Camera
I want to download program ti install pictures from my camera wit a usb cable
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Whether you use the USB connection or a card reader, you can also use any photo cataloging program, such as the free Picasa ( http://picasa.google.com ).
Aug 06, 2010 | Samsung Digimax A503 Digital Camera
I plugged my exilim camera to computer and it wont charge
hi brianne,
have you tried connecting this on another computer? perhaps one that has few USB devices? there is a possibility that the port may not be giving out enough power for the camera to charge
regards,
voodoo
Jun 05, 2009 | Casio Exilim EX-S880 Digital Camera
I have an HP zv5000 Pavilion with HP original Docking station. I it large and doesn't allow me enough length of connection to move my laptop out of the dock. Because of this docking station the monitor...
At this point, you can't find any such cable, since it is outdated. The only thing I could suggest is try to disassemble the dock to remove the cable, the only problem is you would now need desk space to hold the computer...
Nov 25, 2008 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
No ethernet with docking station
It could be the connector on the bottom of your laptop that's creating the problem. Does any other ports work on the docking station when docked?
Jan 14, 2008 | IBM ThinkPad T43 Notebook
Photo colors are not true on my new Kodak....something wrong?
The Kodak CX4310 is the same as the CX4300 but the 4310 is a Wal-Mart special color. The camera feature that controls color balance is called "white balance" and on the 4310, it is totally automatic. Which means you have no control. If your color is not correct, return the camera. There are not many cameras that use a dock to recharge the camera batteries and connect to the computer. So you will not have many choices if you are looking for a different camera. One camera (without a dock) you should look at, is the Olympus Stylus 300. It is a better choice than the Kodak. It uses rechargeable batteries and the charger is included.
Aug 30, 2005 | Kodak EasyShare CX4310 Digital Camera
Computers & Internet Logo
David Payne
David Payne
