Question about Epson Stylus Photo R320 InkJet Printer
Error message saying parts are at service limit and will not do anything. Can I reset it to get it printing? I dont have the time to get serviced at this time. HELP!!!!
    Scholar:
  • 192 Answers
One option is to unplug it and take out the ink, wait 20 minutes for the chip to reset and then plug it in, but in this order. plug to power, then usb to computer, then put in ink, all slowly as to let the printer think it is being set up for the first time, I know sounds silly, but even inadamant objects can be fooled.... Let me know if nothing, I can call my friend the GuruTom..... Guy :)
Posted on Oct 16, 2010
Toshiba studio 181 error c44
This error indicates that the print count has gone above the limit and it requires service. But, this is not necessarily true. Try the following to reset the count:
Solution:
  1. Switch off the printer first.
  2. Now Power the Printer by pressing 0 and 8 keys (keep pressing).
  3. Then a test mode comes up.
  4. Now Type 400.
  5. Press START (!)(You will get a counter and now you need to reset this).
  6. Type 0.
  7. Press Enter(start)
  8. Switch off the Printer now and restart and check again with first steps till typing 0 (You need not type 0).
  9. Now switch off the printer and on it normally.
  10. You should see printer working normally
Resource: Clear Toshiba eStudio printer error message Error C44 call service
Jul 23, 2014 | Toshiba Computers & Internet
Service code interrupt
Error type T11 [Pressure-control motor lock]
T11-***
!!System Error!!
Press Reset Key
If Recovery has Failed, Call Service
Reset method Jam reset or switch on power again
Error point Error conditions
600
Timeout error for reducing pressure (OFF -> ON) during print-pressure home
positioning.
601
Timeout error for increasing pressure (ON -> OFF) during print-pressure home
positioning.
602 The print-pressure limit sensor does not change during print-pressure operation.
620 Print-pressure operation was called with the print-pressure motor locked.
621
Incorrect print-pressure operation timing (print-pressure operation command was
received when the print-pressure should not change).
622 Sensor A is ON and sensor B is OFF during movement from area A to area D.
623 Either sensor A or sensor B is ON during movement from area D to area A.
624 The current area data is undefined.
625 The target area data is undefined.
626 Timeout during relative print-pressure movement.
Error type T12 [Master-disposal-section motor lock]
T12-***
!!System Error!!
Press Reset Key
305
The master compression sensor does not go ON within 6.5 s after the master
compression motor operates in the return direction.
306
Master compression sensor does not go OFF within 2 s after the master
compression motor operates in the compress direction.
307
compression motor operates in the compress direction, and the mastercompression-
motor limit sensor cannot count up until the compression-limit
position.
309
The master-compression-motor limit sensor does not change within 200 ms
during compression operation.
hope to be of help
Sep 27, 2013 | Riso RP 3700
Service life expired
How long have you been using your printer? and how many pages have you printed and the quality of it?
The reason am asking is that it could be that your printer has reached a certain limit of its parts based on the no. of pages it has printer. Please take note that each part of your printer, especially the mechanical parts has certain limits based on the no. of pages it has printed. Based on my experience with epson printers is that, first to reach its limit is the porous pad, if it reach it limits it will disable your printer from printing further to protect it from further damage. Everytime you print some ink goes to waste and goes to the porous pad which means it could get full. Please bring you printer to an authorized epson service center to have the pad remove or whatever parts the limits reach first. After parts replacement the technician will use a software tool to reset the counter and voila :) Your printer should be working fine until it reach another limit. Note: All printer brands uses counter to protect their unit.
Jul 29, 2010 | Epson Office Equipment & Supplies
I'm getting a message all of a sudden that "the type of print head is incorrect. Install the correct print head." I have not doen anything to the printer to change the print head that has been working...
It means the print head temperature is too high. The only was to resolve this error is either replace the print head or replace the logic board. The print head is available, part number QY6-0061 but you will struggle to find a logic board. The only other thing you can try is resetting the EEPROM on the logic board, this sometimes clears the error. A service manual will show you how to do this: http://www.tradebit.com/filedetail.php/4546483-canon-pixma-mp830-printer-service-manual
May 19, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Canon PIXMA iP1000 - Service Error 5100
It means that the waste ink absorbers are filled and you will need to replace them and take the machine to a service center.. Well thats what Canon says,, then when you get there they say buy a new one..
Any way forget them try this..
1.) unplug machine (power cable from back of printer.
2.) hold the power button down and plug cable back in.the printer light will stay on ,,
3.) still holding power,, press the paper feed button.. light will change to orange
4.) press paper feed button again.. It will turn to green
5.) release power button and enjoy..
Depend on the the firmware skip step 4...
That will bypass canons firmware and reset the counters.. Print as you will now..
Mar 23, 2010 | Office Equipment & Supplies
Printer not printing. Error message reads see your documentation may need service
Counter reach its preconfigured limit it is just, you have to reset the counter back to zero count. This feature could be attributed not to overflow the waste bin.
In your web browser search bar, key in " epson reset software" the uppermost link is the one. Read the tutorial before doing so.
Hope you get it easily.
May 29, 2009 | Epson Stylus CX6400 All-In-One InkJet...
Want print
Had this many moons ago and wrote a guide (which I update recently with pictures) on how to resolve it...
http://www.octoink.co.uk/store/pages/Epson-C86.html
The reset utility to fix it is linked to from the bottom of the article but you may need to use this utility instead if that doesn't work (see bottom of article).
It's not the easiest printer in the world to get into but if you can find a deep well of patience and a couple of hours to tackle this you should find it's more than possible and well worth the effort.
Good luck..
Martin
Mar 12, 2009 | Epson Stylus C86 InkJet Printer
Error - printer part are at the end of service life, see printing
I have had a R300 for a while now and had a few cartridges in it. Recently a message came up on the screen 'parts inside your printer are at the end of their life' and the printer refused to work!
After searching the web it appears to be a waste ink counter, but I could not find any info on resetting it.
So I tried pressing different combinations of buttons on the printer and success.
Press and hold 'stop' 'maintenance' and 'power' buttons for about 10 seconds, a message will come on the screen saying counter is reset and to turn off.
Thats it turned my printer back on and all works fine again.
I hope this helps R300 owners out!
Feb 02, 2009 | Epson Stylus Photo R300 InkJet Printer
Service required error
try replacing the cart. again with factory ink cart.
Dec 06, 2007 | Epson Stylus Photo RX700 All-In-One InkJet...
Printer stopped printing. Error message
Thjis is indication the Waste in collector pades need changing eventually.- but no now. you have plenty of warning
Reset Epson R300/200
press three buttons to reset the counters
The buttons are "STOP" "Maintenance" and "POWER"
or down load the epson utility www.ssclg.com and use the reset counter feature
The printer will sound like its going to blow up, but thats normal.
You can do this about 5 times before your printer starts to piss out ink over the table because the Waste Ink Ink Pad is full
To avoid eventual flooding go to rear of the machine- remove the little door and rake around for a small plastic pipe buried under some padding under the left side.
Fix to this a thin piece of ploythene tube[Fish tank air supply], extend it to our side the machine and place in a suitable container to collect the waste ink..
Nov 21, 2007 | Epson Stylus Photo R300 InkJet Printer
Epson Stylus Photo R320 InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
