Question about Holland Grill Tradition (NG)
Installing new igniter kit especially where does the electrode locate
Why does my car not start after it rains.
some corrosion is occuring in ignition area--du a complete tuneup--replace plugs and cables--test coil and ignition module--take off distributer cap and look inside for worn electrodes--clean w sandpaper or buy nu one
Sep 01, 2014 | Cars & Trucks
No spark. My HSU75NG MR. Heater (Big Maxx) will not start on its own. It purges fine ,calls for heat fine, gas flows fine; BUT there is no spark from the Electrode Igniter. Which I have replaced. The
The capacitor in that unit is for starting the motor that drives the blower fan. It has no impact on the ignition of the gas burner. On the control board, there is a light that should be flashing, can you tell us how many times it is flashing?
Feb 18, 2014 | Mr. Heater Natural Gas Garage Heater -...
Spark plug settings honda jazz 1.4 2006
Inspect the electrodes and ceramic insulator.
  • Burned or worn electrodes may be caused by:
    • Advanced ignition timing
    • Loose spark plug
    • Plug heat range too hot
    • Insufficient cooling
  • Fouled plug may be caused by:
    • Retarded ignition timing
    • Oil in combustion chamber
    • Incorrect spark plug gap
    • Plug heat range too cold
    • Excessive idling/low speed running
    • Clogged air cleaner element
    • Deteriorated ignition coils
2.
Check the electrode gap (A). If the gap is over the standard, adjust the gap with suitable gapping tool.
Electrode Gap
Standard (New):
1.0-1.1 mm (0.039-0.043 in.)
3.
Replace the plug at the specified interval, or if the center electrode is rounded (A). Use only the spark plugs as listed.
Spark Plugs
NGK:
ZFR6K-11
DENSO:
KJ20DR-M11
Apr 09, 2012 | Honda Jazz Cars & Trucks
No fire in box
Do the new electrodes emit an ignition spark? Just becuase they are new doesn't mean that the system that energizes them is functional. Have you tried a new igniter module?
Dec 15, 2011 | Heating & Cooling
Rotisserie burner won't light
It could be a dirty or inop spark electrode. Also could be weak batteries in the spark igniter.
Before you start you should make sure that the ignition system has fresh batteries. The batteries are usually located within the igniter button but not always. Some BBQs will have a battery pack located somewhere on the BBQ and others you can remove the igniter button by turning it left to reveal the battery.
First verify that the rotisserie burner can be lit manually. Take a BBQ lighter or long stick match and then put the flame right at the base of the burner where the electrode is and then slowly turn on the burner valve. It should light within four seconds. If it does not then shut the burner off and check for any restrictions in the gas line for the burner.
If it does light with a match then the spark electrode could be dirty, out of position or simply the wire for the ignition system is loose. Press the igniter button and watch the electrode for a good bright spark at the burner. If you do not see any spark you can verify that the igniter wire has not come loose and also gently adjust the position of the electrode end a little bit closer to the burner using a pair of needle nose pliers(It should not be touching the burner). It does not need to touch the burner but have a really small gap.You can use a small wire brush to gently clean the electrode of any debris that might be causing a weak or no spark
If you are unable to remedy the non-spark issue all is not lost. You can still use the manual lighting procedure I described to light the burner. And remember to be careful when trying these procedures. I do not want you to get injured from delayed gas ignition. Be careful and have a safe holiday.
Jul 04, 2010 | Ducane 30400042 (LP)
I recently had a flat battery and tried to jump start my car. Since this day, the Sony Ericsson HCB-300 Bluetooth kit hasn't worked, and I cannot locate the in line fuse. There is not light or power going...
The main question is about the power supply and especially with the 12 volt dc and the 12 volt ignition.
Maybe the car kit has been installed without taking account of the 12 volt ignition which is important to unpowered the kit and preserve the product more longer.
Sometimes no ignition on the key.
I do not know what sign on the sony, but in some vehicle on the market you have to inverse fuses to make it working longer.
Some of the car kit can work during a certain time, but a day to an other will not working any more.
Feb 01, 2010 | Sony -Ericsson OEM HCB-300 Bluetooth...
How to replace sparl plugs on a Jeep Cherokee?
Hello, I hope this info helps...(subytech1)...REMOVAL
In this engine, each individual spark plug is located under each ignition coil.
  1. Prior to removing spark plug, spray compressed air around base ofignition coil at cylinder head. This will help prevent foreign materialfrom entering combustion chamber.
  2. On this engine each individual ignition coil must be removedto gain access to each spark plug. Refer to Ignition CoilRemoval/Installation.
  3. Check condition of coil O-ring and replace as necessary.
  1. Inspect spark plug condition. Refer to Spark Plug Conditions.
CLEANING
Theplugs may be cleaned using commercially available spark plug cleaningequipment. After cleaning, file center electrode flat with a smallpoint file or jewelers file before adjusting gap.
CAUTION: Never use a motorized wire wheel brush to clean sparkplugs. Metallic deposits will remain on spark plug insulator and willcause plug misfire.
ADJUSTMENT
Setting Spark Plug Gap - Typical
Check spark plug gap with a gap gauge tool. If the gap is not correct,adjust it by bending ground electrode. Never attempt to adjust gap bybending center electrode.
INSTALLATION
CAUTION: This engine is equipped with copper core groundelectrode spark plugs. They must be replaced with the same type/numberspark plug as the original. If another spark plug is substituted,pre-ignition will result.
Special care should be taken when installing spark plugs into cylinderhead spark plug wells. Be sure plugs do not drop into plug wells asground straps may be bent resulting in a change in plug gap, orelectrodes can be damaged.
Always tighten spark plugs to specified torque. Over tightening cancause distortion resulting in a change in spark plug gap or a crackedporcelain insulator.
  1. Start spark plug into cylinder head by hand to avoid cross threading.
  2. Tighten spark plugs to 27 Nm (20 ft. lbs.) torque.
  3. Before installing coil(s), check condition of coil O-ring andreplace as necessary. To aid in coil installation, apply silicone tocoil O-ring.
  4. Install ignition coil(s). Refer to Ignition Coil Removal/Installation.
Aug 07, 2009 | 2000 Jeep Grand Cherokee
Dryer heats a little than electrode goes off I watched the electrode get red than it ignited the gas and than went out
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
Jul 09, 2009 | Dryers
FURNACE RUNS UNTIL IT REACHES ITS DESIRED TEMP
Could be cracked or misaligned electrodes. Could be improperly gapped electrodes. Make sure transformer is making contact with the buss bars. Make sure transformer is secured down. Make sure your air setting is not to high, or else it will blow out the spark before ignition. Hope this helps
Apr 24, 2009 | SySTOR Systems (400S52) Burner
Kemore Gas oven - trouble igniting
Hi Deeg, there was a service flash regarding this problem. The bake burner and bake igniter have been modified to assure consistent oven ignition and performance. The number of ports on the burner have increased located at the electrode tip. The electrode shield has also been modified. This repair should be covered under warranty. The kit part number is 8190618 for your information. If your serial number ranges from RK01 through RR11, this is your problem. I would call Sears and request service. Catriver.
Sep 12, 2007 | Kenmore 30464 / 30465 / 30469 Gas Single...
Holland Grill Tradition (NG) Logo
50 people viewed this question
Top Holland Grill Grilling Experts
paulcarew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Holland Grill Grilling Expert? Answer questions, earn points and help others
