Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
How to program code on wireless keypad after resetting car transmitters
    President:
  • 3,197 Answers
Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to the keypad and key in any 4 digit code you like and press enter.
Posted on Oct 16, 2010
2003 crown vic keyfob only works with ignition in run position .keyless entry and door locks work fine.even tried new keyfob.no change
The keyless entry system consists of the following components:
  • driver door module (DDM)
  • keyless entry transmitter
  • keyless entry keypad
The driver door module (DDM) receives inputs from the digital transmission range (TR) sensor, ignition switch, brake switch, window/door lock switches, lighting control module (LCM), keyless entry keypad switch and remote transmitter. The DDM outputs consists of keyless entry keypad switch illumination, power door lock actuators, luggage compartment release solenoid, horn relay, and lighting control module (LCM).
  • Battery junction box (BJB) fuses:
    • circuit breaker 7 (20A)
  • Central junction box (CJB)
    • 4 (10A)
    • 6 (15A)
    • 8 (25A)
    • 13 (5A)
  • Keyless entry keypad switch
  • Power door lock actuator
  • Luggage compartment release switch
  • Luggage compartment release solenoid
  • Connectors or connections
  • Wiring harness
  • If fuse's good have checked for DTC'S - diagnostic trouble codes .
  • B1526 Keyless Entry Circuit Short to Ground DDM Go To Pinpoint Test E . B1553 Decklid Release Circuit Short to Battery DDM Go To Pinpoint Test B . B1751 Park/Neutral Switch Circuit Short to Battery DDM Go To Pinpoint Test K . B2425 Remote Keyless Entry Out of Synchronization DDM Go To Pinpoint Test L Need a professional grade scan tool to check fro these codes . Not a code reader for OBD2 codes .
  • The doors do not lock/unlock using the remote transmitter
  • Remote transmitter not programmed.
  • Remote transmitter.
  • DDM.
  • Go To Pinpoint Test F .
Did you program the new key fob ?
Remote Transmitter Programming NOTE: All remote transmitters are programmable and must be set at the same time.
  1. Turn the key from OFF to RUN four times within three seconds, ending in RUN. The locks will then lock and unlock, confirming program mode has been entered.
  1. Press any button on each remote transmitter to be programmed. The doors will lock and unlock to confirm that each remote transmitter has been programmed.
  1. If additonal remote transmitters are to be programmed, repeat Step 3 within 7.5 seconds or steps 2 and 3 if more than 7.5 seconds have elapsed.
  1. To exit program mode, turn the ignition to START or wait 7.5 seconds.
  1. NOTE: Failure to wait at least 20 seconds will cause programming failures. Wait at least 20 seconds after turning the key to OFF or after the last remote transmitter has been programmed to activate a remote transmitter for testing or verification
Feb 19, 2017 | Cars & Trucks
Tip
Genie Intellicode Remote Transmitter Programming Instructions
USE ONLY WITH SERIES II ELECTRONICS.<br /> Older Transmitters and Receivers will not work with these new electronics. There are no Security Code Switches inside the Door Operators, Transmitters and Receivers.<br /> <br /> <br /> To Program Receiver <br /> Step 2-1 Locate the Learn Code Button and Radio Signal Indicator on the Power Head Receiver of your Door Operator.<br /> <br /> Step 2-2 Press a Transmitter Button once within 30 seconds.<br /> <br /> Step 2-3 Press and release the Learn Code Button<br /> &bull; The Radio Signal Indicator will blink approximately 2 times per second.<br /> &bull; The Radio Signal Indicator stays lit - SOLID.<br /> <br /> Step 2-4 Press the same Transmitter Button within 30 seconds.<br /> &bull; Radio Signal Indicator will go out.<br /> <br /> NOTE: If a second Transmitter Code is not confirmed within 30 seconds or if a different Transmitter Code is sent, the Radio Signal Indicator will blink approximately 4 times per second, then programming will stop. If programming stops, repeat Steps 2-2 through 2-4.<br /> <br /> Step 2-5 Repeat Steps 2-2 through Step 2-4 for each Transmitter, Wireless Keypad or other access device to be learned.<br /> <br /> NOTE: A maximum of 7 Transmitter, Wireless Keypad and other access device Codes can be stored into Receiver Memory at one time. If a Transmitter becomes lost or if you want to delete a Transmitter, Wireless Keypad or other access device, proceed to ERASING ALL RECEIVER MEMORY.<br /> <br /> <span style="font-weight: bold;">Multi-Button Transmitters</span><br /> <br /> NOTE: Only ONE button of a Multi-Button Transmitter can be programmed into a single Receiver. The other buttons are to control other Door Operators.<br /> <br /> NOTE: If you are replacing a lost or stolen Transmitter:(1) Erase ALL Transmitter Codes from the Receiver memory. (2) Reprogram the Receiver with the remaining Transmitters Codes.<br /> <br /> <span style="font-weight: bold;">Erasing All Receiver Memory</span><br /> <br /> Step 4-1 Press and HOLD the Learn Code Button for 10 seconds or until Radio Signal Indicator goes out.<br /> <br /> <span style="font-weight: bold;">ALL Transmitter Codes are erased from Receiver memory.</span><br style="font-weight: bold;" /> <br /> Step 4-2 Reprogram the Receiver with the remaining Transmitter Codes (Repeat Steps 2-2 through 2-4).<br /> <br /> <span style="font-weight: bold;">Step 5-1 Battery replacement</span><br /> &bull; Slide Battery Cover off of Transmitter back.<br /> &bull; Replace with new batteries.<br /> &bull; Slide Battery Cover back on.<br /> <span style="font-weight: bold;"><br /> Step 5-2 Visor Clip installation</span><br /> &bull; Slide Visor Clip into back of transmitter until it snaps into<br /> place.
on Jun 21, 2011 | Genie Company IntelliCode GICT390-1BL...
I have a Sears (Chamberlain) Liftmaster. I had to buy a new remote transmitter and it learned the code from the motor. However, now, the keypad transmitter won't work. I have done all the...
Make sure you are using the correct procedure to program the keypad.
Nov 29, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+: How do you reset your car transmitters...
To program your transmitters locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and hold this button for 6 seconds and it will erase all transmitters from memory. Note please: none of them will now work. Now hold down the button on one of the remotes and then press and immediately release the smart/learn button. Do this for each remote.
May 17, 2010 | Sears Craftsman LiftMaster Chamberlain...
How do you clear and re-enter a new code for wall mounted remote
To change the code you need to locate the smart/learn button which is near where all those white wires go. Press and immediately release it and then walk over to your keypad and key in any 4 digit code you like and press enter.
See if this works for your car.
  1. Clear out anything previously programmed into the in-car system from the factory by holding down on the 2-outside buttons simultaneously, until the in-car LED starts flashing rapidly. This may take up to a minute (in most cases, the key should be on auxillary, and/or the car door must be shut).
  2. Decide which button you want to make to be your in-car garage door transmitter. Hold your transmitter up near the selected button, pressing both the garage door remote and the selected in-car transmitter button simultaneously. Hold down on the buttons until the in-car, LED light flashes rapidly. This sets the in-car remote transmitter to be your garage door openers make transmitter, but you are not done. You now need to make this in-car transmitter your personal transmitter.
3. Go to the Learn Button on your garage door opener. The button is usually next to the area where the floppy antenna is connected to the motor head. With Genie it is most often behind the light lens, and an indicator light flashes red when pressed. With Sears or Liftmaster (Chamberlain) it is near, or part of, the terminal screw board, and is a red, green or purple square button with a green, amber or purple indicator light. Press this learn button momentarily. The indicator light will turn on and blink if Genie or otherwise stay lit. For Genie systems, go back to the in-car transmitter button you programmed and press this button 3 or 4 times, or until the door starts moving. This should set your in-car transmitter to your garage door opener. For Liftmaster, Sears, or Linear Megacode press and hold the in-car button you programmed until the garage opener light flashes. Your in-car is now programmed to operate your door.
Feb 02, 2010 | Sears Craftsman LiftMaster Chamberlain...
I don't know the keypad code...we just moved into the house. How do I reset it?
To program the keypad, first unplug the garage door opener from the electrical outlet. Next, remove the nameplate from the console that the keypad plugs into and locate the program/operate switch. Flip the switch to program. Next, enter your desired four-digit PIN number into the keypad. Slide the switch back to operate, and plug the garage door opener back in. The keypad should be programmed.
Nov 19, 2009 | liftmaster Chamberlain Garage Door Opener...
Need to change keypad code, but lost instruction manual
The key code transmitter for your unit should be 53776 multi key panel:
you must have access to the operator to reset. The programming keys are as noted below:
1. Open the Touch C.ode Transmitter cover to access the keypad.
Decide on a 4-digit code number using numbers from
0 to 9. You can use a number more than once. (For
example, 4, 0, 4, 1).
2o Press the 'SR' code button on the opener panel. The
indicator light atongside the push button will turn ON.
3_ STAND AWAY FROM THE DOOR. Press the selected code
numbers on the keypad and then press the ENTER key.
The indicator light on the opener panel wiil turn OFF and
the door witl begin to move, The opener receiver has been ._
programmed with your code selection. (_
NOTE 1" If the indicator light turns OFF before the code _ . "_ _'
digits and ENTER key are pressed, repeat Steps 2 and 3. _._t,_-_ J t_
NOTE 2' During programming, be sure the,k/_ca_i_n push :---'-"_"
button (if your opener has that feature) is OFF and the
Infrared Sensor (if you have installed that accessory) is
free of obstruction. THE DOOR WILL NOT MOVE AND THE
INDICATOR LIGHT WILL NOT TURN OFF in either case.
To change your code at any time, repeat Steps 1, 2 and 3.
Hope this helps
Apr 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
1999 lincoln con
SECTION 501-14B: Keyless Entry/Computer Operated Locks 1999 Town Car Workshop Manual GENERAL PROCEDURES Programming —Keyless Entry Keypad Code
  1. Enter the permanent factory keyless entry keypad code.
  1. Press the 1/2 button within five seconds to activate the programming mode. Holding the 1/2 button for more than two seconds will erase all stored customer codes. The existing codes do not need to be erased to program new codes.
  1. Enter the new five-digit keyless entry keypad code.
  1. To associate the new code with personality positions 1, 2 or 3, press the 1/2 button within 5 seconds of entering the 5th digit of the new code for position 1 or 3/4 button for position 2 or 5/6 for position 3. The door locks will lock and unlock confirming the new code is programmed.
  1. If another code is to be programmed, begin entering the code within 5 seconds of the last button pressed.
  1. After all new keyless entry codes are programmed:
    • Press keyless entry keypad buttons 7/8 and 9/0 at the same time to exit the program mode.
    • Wait for 5 seconds; the driver door module (DDM) will exit the program mode automatically.
Programming —Transmitter
  1. Cycle the ignition from OFF to RUN four times within three seconds. The locks will then lock and unlock, confirming program mode has been entered.
  1. NOTE: When the first keyless entry remote transmitter is programmed, all other keyless entry remote transmitters are erased.
    Press any button on the transmitter to be programmed.
  1. If additional keyless entry remote transmitters are to be programmed, repeat step 2 within 7.5 seconds.
Programming —Remote Memory Activation NOTE: This procedure must be completed within 5 seconds.
  1. Press the SET button on the driver door panel.
  1. Press any button on the keyless entry remote transmitter to be associated with a memory setting.
  1. Press the 1 or 2 memory button on the driver door panel.
Programming —Autolock and Horn Chirp
  1. NOTE: This procedure must be completed within 30 seconds.
    Turn the ignition switch to RUN.
  1. Press the UNLOCK button three times.
  1. Turn the ignition switch to OFF.
  1. Turn the ignition switch to RUN. The doors will lock and unlock to confirm entry into program mode.
  1. Press the UNLOCK button once to toggle the Autolock feature on or off, or twice to toggle the Horn Chirp function on or off. The horn will chirp to confirm toggling of the Autolock feature.
  1. Exit program mode by turning the ignition to OFF, START, or wait 7.5 seconds.
Apr 07, 2009 | 1999 Lincoln Town Car
Change the code on a garage door transmitter?
There is a "learn" button on the garage door opener unit itself that you press before entering a code on the outside transmitter. This allows the receiver to learn a new code. The button is on the rear end of the housing near the terminals where the inside operation pushbutton connects.
Here's a link to programming instructions for a compatible unit by another manufacturer:
http://www.usdoorcontrol.com/instructions/liftmaster/keypads-66LM.pdf
Nov 23, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
77 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
