Question about Sony Bluetooth Wireless Headphones - Black
One of the headphones does not produce sound - Sony Bluetooth Wireless Headphones - Black
The headphone socket
When you move the headphone plug around and the sound cuts in and out that usually means that the terminals in the jack have corrosion on them. You can usually clean the jack with contact cleaner that is sold in home improvement stores.
Here's a video showing how to clean the headphone jack on a phone but the process is the same for any device that uses a headphone.
Apr 01, 2015 | Electro Brand Nostalgic Stereo CD Music...
The speakers no long produce sound after using the headphone jack,,disconnected jack , still no sound
When you plug in the headphones, the jack itself routes the signal away from the speakers. When you unplug the headphones, the jack has contacts that close again, routing signal to the speakers. If the jack contacts are dirty, they won't close correctly. I suspect were you to clean the contacts, you'd solve the problem.
Feb 25, 2015 | RCA Rt2760 Home Theater Receiver
One headphone is not working. no sound is coming.
pull the plgu of your headset partially from the jack play around it until the other headphone produces sound if this happens it mieans that the Audio port your using is either malfunctioning or you can try youy headset with an MP3 player or any audio device that uses a headset to find out if it is the headset that is damaged
Jun 05, 2010 | Bose QuietComfort 3 Acoustic Noise...
Audio from laptop speakers is fine, headphones are not.
Do these headphones work OK in another machine??
If not they are faulty / If so then sound port may be faulty.
'Ensure it is enabled in BIOS. press DEL key when booting and look for similar.
Mar 23, 2010 | Dell Vostro 1510 Laptop
Why does my Motorola S9 only play out of the left ear when connected to my laptop? It connects to the pc fine and the most updated software. Do I need to buy a stereo dongle?
Go to the mediaplayer setting and adjust the volume bar... if it is not in centre then move it ti centre bcoz it will produce sound only in that ear where the bar is set... In middle it produces sound in both ears...
Sep 20, 2009 | Motorola Mobility S9 Headphones
Labtec headphone how to get it to work.
Sometimes you need to "burn in" your headphones. Used headphones usually produce a better sound than new ones. Simply let it play some music continuously. I usually burn in my headphones with some AM/FM static.
After a while, the sound should improve.
Feb 10, 2008 | Labtec 342 Headset
Stopped consistently producing sound
Try plugging and unplugging a pair of headphones. The headphone jack in these receivers are flaky and sometimes think there are headphones hooked up even when there isn't. Full repair would require the headphone jack to be replaced. If you don't use headphones at all, you can take the top cover off and unplug the cable going to the headphone jack board and eliminate the problem that was as well.
Mar 01, 2017 | Denon AVR-1603 Receiver
Sony Bluetooth Wireless Headphones - Black Logo
21 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
