Question about Uniden DECT 6.0 Cordless Telephone Expansion Handset
Uniden phone stuck in search mode - Uniden DECT 6.0 Cordless Telephone Expansion Handset
My Uniden Dect 6.0 telephone system is going straight to answer bank and not ringing. I am unable to find the manual and would appreciate your help with this problem. Thankyou
Uniden phones have one of two options to keep the handsets from ringing. These can be toggled on and off with the phone system in standby.
Most likely, you have toggled the "Do Not Disturb" mode on your Uniden DECT phone. This mode will ensure that none of the handsets ring on the cordless phone. On models with an answering system, it is automatically turned on when this mode is in use. It will pick up after the preset number of rings. If you hadn't set the number of rings,
Disabling the DND depends on the phone model. On some, to disable the DND mode, press and hold the # key (below 9) for 3+ seconds. When you toggle the mode on, you can tell the system how long to silence the rings (1-9 hours or always on). If you do not press a digit, the always on option will be selected. If you press DND again, the mode starts. Otherwise, it becomes active after 5 seconds.
A few models have the DND button on the base. Again press and hold that button to deactivate the Do Not Disturb feature.
On other Uniden cordless phones, you can only silence one handset at a time. This silent mode is toggled on and off by holding the appropriate key. (This is usually the # or 9 key and will have a second symbol on the key.)
I will assume that you do not have a muted ringer on the phone handsets. If the mute is enabled, just press Volume + when the phone is not in use.
I hope this helps. If you need more specific directions, please add a comment with the phone model number. With that information, I may be able to find the manual as a PDF. One useful source of Uniden DECT phone manuals is https://www.uniden.com.au/uniden-search/ . Manuals Lib ( manualslib.com ) or Google are also good places to search for manuals.
Mar 01, 2018 | Uniden Lands Phones
How do I get my uniden dect 6.0 off of silent mode?
This works for the Uniden D1660 and similar dect 6.0 models:
On the lower right corner of the keypad, press the # [silent] key.
One press put it into 'silent mode', another press takes it out.
Oct 10, 2016 | Uniden DECT 6.0 Cordless Phone ID
How to turn on the silent mode on one phone
Enter the model of your Uniden DECT 6.0 phone into the search box at http://www.uniden.com/scat/dectphones_mnl to download a copy of the manual.
Jul 03, 2014 | Uniden DECT 6.0 Cordless Telephone...
Silent mode on how to take this off
Search your Uniden model number online and they will have instructions for your phone.
Feb 13, 2014 | Uniden Cordless Phone
Phone is stuck on SILENT MODE
Select the model of your Uniden cordless phone from the list beginning at http://www.uniden.com/owners-manuals/cordless-phones/scat/cordlessphones_mnl to download a copy of the manual.
Jan 13, 2014 | Uniden Cordless Phone
Uniden phone stuck at searching, not getting a dial tone
One thing to try is deregestering your phone and registering it with the base again.
Hole the # and 'End' key on the handset until the next menu appears (about 5 seconds). Select deregister phone (use the 'Menu' button). Do it again, but select "base unavailable". After that, set them in the base (not the handset charger) and they should register with the base.
This works on most Uniden model phones.
Jan 29, 2013 | Uniden DECT 6.0 Cordless Telephone...
My uniden dect 6.0 handset is stuck on silent mode. How do I turn it off?
Since you neglected to specify the model of your Uniden DECT 6.0 phone I can only suggest you select it from the list beginning here to download a copy of the manual.
Aug 12, 2012 | Uniden DECT 6.0 Cordless Telephone...
Uniden dect 6.0 _cordless phone. is stuck on silent mode ,lost the manuel need to know how to get it off ..phones wont ring
Select the model of your Uniden DECT 6.0 phone from the list beginning at
http://www.uniden.com/owners-manuals/dect-phones/scat/dectphones_mnl/
Sep 21, 2011 | Uniden DECT 6.0 Cordless Phone
I need help getting my phone off of silent mode. One of my kids put it on silent somehow and now I cannot get it to ring again.
I to am stuck in silent mode, voicemail won't work, the whole entire phone is jacked up, just because i had my phone number changed, are you kidding me?? Not ringing, not doing anything @ all, can someone tell me what to do? please thnx :)
Jun 02, 2011 | Uniden DECT 6.0 Cordless Telephone...
My 2 phones are stucks in a search mode and I don't know how to get out of this mode?
1. try the to switch off the phone and if this is not possible remove the battery, put it back and switch on the phone.
Jun 02, 2010 | Uniden DECT 6.0 Cordless Telephone...
Uniden DECT 6.0 Cordless Telephone Expansion Handset Logo
288 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
