My computer won't boot and it won't start with the media cd it doesn't load it it says Error-08-0A74-0000
3 Suggested Answers
  • 11800 Answers
SOURCE: I can not boot my
First of all your problem is caused by the hard disk - it has died and must be replaced. Second you are booting from the wrong disk Hiren's disk is a very specialized system analysis and recovery disk, it's not a Windows reinstall one. You should use the disks that came with your pc for that, after you replace the hard disk. Finally you should check the memory sticks, the low memory warning appears only when it way low, less than 256MB. If this is really how it is then you should buy more.
Posted on Aug 08, 2010
rsownbey
  • 11 Answers
SOURCE: Ibuypower won't boot
Unplug the computer, Hold down the power button for 5 seconds.
Plug the computer in. Power on the computer.
Call, text or email Shane 801.554.4142 / rsownbey@msn.com
Posted on Apr 27, 2013
Emachines E528 laptop won't start
Try to boot it from safety mode.
and try to restore your system first.
If the restoring is failed, boot safety mode again and back up your files.
If you can't boot your laptop from safety mode, use anti virus program CD like norton.
Mostly, your system is messed up by adwares, spywares, and virus.
If all things fail, you should check your HD.
Jun 18, 2013 | eMachines E525 D260 Motherboard...
Acer aspire d257 pxe-e61: media test failure, check cable error
Your computer tries to "boot" (start-up) from several devices:
* floppy-disk (if installed)
* disk-drive (if not "dead"),
* CD/DVD optical device (if "bootable" media has been loaded)
* PXE --> Pre-Execution Environment -- checks if there is a connection between the network-adapter on your computer to a "boot-server" on your local network -- it can load Windows from that "boot-server".
The "media-test failure" indicates that there is no network-cable attached to your computer *AND* the other-end of the network-cable is *NOT* connected to the "boot-server". So, you can that "error" message.
Is your disk-drive "dead" ????
Jan 24, 2013 | Compaq Presario-Notebook 700 Series, 2500...
Hitting F8 key repeatedly will not access Safe Mode option for my HP D530
If you getting this error then you won't be able to open computer in safe mood, Because this error message indicate that there is no proper bootable media selected or there is no OS in your Hard drive.
First thing you can do is go to BIOS and check what is your First boot device selected, if it is other then Hard drive then change it Hard drive and save setting and come out of it.
If there is any media, like Pen drive or any CD then remove it and start your computer.
If still you have same problem then I am afraid that your OS is Corrupted.
Aug 20, 2012 | HP Compaq d530 CMT Intel Desktop PC -...
Laptop won't start up
The error PXE-E61: Media test failure usually means the hard disk has failed or the hard disk needs re-seating or the disk controller is faulty. First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Aug 12, 2012 | Toshiba Computers & Internet
Laptop won'y start up has non-system disk or disk error
The error PXE-E61: Media test failure usually means the hard diskhas failed or the hard disk needs re-seating or the disk controller is faulty.First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
May 02, 2012 | HP Computers & Internet
How do I reboot my ASUS EEE PC 701SD 7" 0.9 GHz
To start the systemrecovery:
  1. Restart the computer.
  2. When the Computer logo appears on the screen, press the Alt and F10 keys repeatedly.
  3. If you are prompted with a Microsoft Windows boot screen, press the Enter key.
  4. After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
If the ability to reinstall from the previous method is not available orfails, recovery of the Operating System will need to be from Recovery Media. Ifyou do not have a set of Recovery Media, you may purchase the set onlinefrom the manufacturer.Note: If your computer does not havean internal optical disc drive, an external optical disc drive will be requiredin order to recover the Operating System using Recovery Media.
  2. When the computer logo appears on the screen, press the F12 key repeatedly to enter the computer's Boot Menu.
  3. Press the CD-ROM drive eject button and insert the disc labeled System CD.
  4. Close the CD-ROM tray.
  5. Refer to on screen instructions to select either CDROM or USB CDROM.
  6. The computer will boot from the Recovery Media
  7. When prompted for the Recovery CD, remove the System CD and insert the Recovery CD.
Note: Ifthere are multiple Recovery CDs, please insert the first of the Recovery CDs.
  1. After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
Oct 30, 2011 | ASUS Eee PC 701 Notebook
My Gateway notebook, model : 4535GZ doesn't see any drives upon boot-up. I went into setup and I don't know all the info to manually input the hard drive or CD drive. The hard drive is an Fujitsu,...
@bevrog
If you see the Fujitsu HDD model#: MHU2100AT. under BIOS setup, that means the HDD is there but the operating system is not loading up. Try the following:
1. Run System Recovery (turn the computer ON and press the F11 key simultaneously) - take note that this will erase everything and you'll start from scratch.
2. If you have a Recovery Discs, press F12 simultaneously upon boot-up and choose to boot from the CD/DVD drive
3. If a System Recovery Window came up (see image below), then proceed and wait until it restore Windows.
If you don't get an image similar to the screen above, and you get an error like PXE Error Media State Media Disconnected, or 0x000000E or "An I/O Error occured" - this is a sign that your HDD is already failing and needs to be replaced. If you're still under warranty, call gateway support at 1-800-846-2000.
Good luck.
Sep 07, 2011 | Gateway 4535GZ Notebook
Hey my mac won't eject a disc. i have tried a lot of stuff and nothing happened. when i restart it the disk spins and doesn't sound stuck and when i used disk utility it said there was an error...
Resolution Tip: Make sure the CD or DVD disc is not in use. Quit all applications that are using files on the disc.
  1. Press the Media Eject key at the top-right corner of the keyboard.
  2. If that doesn't work, drag the disc's icon to the Trash.
  3. If that doesn't work, restart the computer, then hold down the mouse button or trackpad button while the computer is starting up, until the disc is ejected.
    To restart, choose Restart from the Apple menu.
Aug 16, 2011 | Computers & Internet
My computer won't turn on properly. It keeps saying disk error press control alt delete. When I do it just says it again and again. It won't load and turn on.
First you should check if there is any disk on your cd room, if there is any disk you should remove the disk from the cd room, if there is no disk the possibility is your hard drive getting error
Press f2 or delete to enter your bios set up system
Look for boot menu
Set the first boot as a HDD and the second boot as cd room and disable the third boot
Save and Exit the setting
if your computer still won't load you need to reinstall your windows
insert windows cd and go to set up again by pressing f2 or delete button
Set the first boot as cd room then the second boot as HDD
Save and exit the setting again
When the message press any key to boot from cd appears you should press the space bar or another key
Then just follow the instruction of formatting
Jun 03, 2011 | Acer Computers & Internet
The computer doesn't start windows is like getting
you are going to need to reinstall windows or try to unplug any unnessesary usb attachments then try to restart
May 07, 2011 | Microsoft Computers & Internet
Computers & Internet Logo
David Payne
David Payne
