Question about JVC Televison & Video
Sound on tv went out. model jvc hd-56g886. Checked mute buttons etc
    Top Expert:
  • JVC Master
  • 75,283 Answers
Hello
You just hold your ears very near to the speaker side, and swich on the tv. If you hear a "thumb"; sound, the output circutary of your tv has some trouble; provided picture is Ok. If there is no "thumb sound", the speaker of your tv must be suspected.
Normally output Ic may get damaged. This will happen to most of the telivisions.
Posted on Oct 16, 2010
I have a,jvc projection tv model # HD-56g886 it went to the green screen fora second, then I had sound , but no picture.
You will not be able to find the parts to repair this. Might as well replace it with a new LED flat screen.
Jul 24, 2017 | Televison & Video
JVC HD 56g886
It could be dust and or lint in the tv. The bulb has a fan to cool it and if it is plugged with lint can cause the bulb to overheat and fail. Lint or dust that gets on the bulb can also cause premature failure. Remove bulb and lean fan and intake screen thoroughly and check to make sure fan is operating. Then install new bulb. Hope this helps.
Dec 31, 2013 | JVC HD-56G886 56" Rear Projection HDTV
JVC HD-56G886 tuner stopped working
My (unfortunate) guess would be the Tuner received a static discharge when you were changing the antennas... this time of the year is bad for static - if you're in a "Winter" climate.
Receivers have a very sensitive FET or MMIC amplifier right inside from the antenna connection to make it better for picking up distant stations.
However, this same "sensitive" amplifier is also prone to being destroyed by even a small static discharge... especially if the tuner had its power turned ON.
Sad to say, it's likely toasted... :-(
(I hope I'm wrong... but you have already tried all other possible solutions)
Jan 12, 2013 | JVC HD-56G886 56" Rear Projection HDTV
You online and did you receive my email concerning no sound on JVC HD 56G886, Part Number: QAS0251-001 . Ed robinson at majorchordstm@sbcglobal.net?
The fault can be confirmed only after a proper audio test is done. The unit must be opened first so that the speakers can be checked for continuity. If this is okay then feed a audio into the audio in and select the video for the auxiliary input. If there is output then the output is good and working and the fault can be with the SIF- sound intermediate frequency section. You will need to inject audio frequency so as confirm the failed section.
Dec 07, 2011 | JVC HD-56G886 56" Rear Projection HDTV
Have jvc model HD56G886. heard a pop..picture went off...blue light over on/off switch blinks quikly. Lamp go bad?
lamp is burned out, reorder one online and install-cheap and easy, the lamp will come with instuctions
Jan 15, 2010 | JVC HD-56G886 56" Rear Projection HDTV
JVC HD DILA 56G886. replaced lamp and now it shuts down after 10
we found that it is an auto shut off system on the TV due to over heating. The lamp, if not cooled correctly shuts down. We added a mini fan in the back and it seems to work fine now.
Jan 25, 2009 | JVC HD-56G886 56" Rear Projection HDTV
JVC HD-56G886
Call your cable company, the lamp has nothing to do with the inputs, Maybe one of the connections is barely connected from moving the TV to replace the lamp.
May 06, 2008 | JVC HD-56G886 56" Rear Projection HDTV
My JVC tv Is in digital and i want it in Analog
Look to see if your remote has a button with A/D on it. That is the button to press to switch back and forth between the analog and digital tuners.
Mar 28, 2008 | JVC HD-56G886 56" Rear Projection HDTV
JVC HD-56G887 wont turn on
Your TVneeds to be serviced by a JVC authorized service center.
Mar 17, 2008 | JVC HD-56G886 56" Rear Projection HDTV
Televison & Video Logo
96 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
