Question about Apple iPod touch
My ipod touck is locked and i forgott my passcode `
You must restore the Ipod. Plug it in, go to I-tunes and restore. This will DELETE everything on the Ipod, but it is the only way to unlock it that I know of. You can always reinstall/load everything back to the Ipod.
Posted on Oct 17, 2010
How do you reset passcode on ipod touch?
You will need to know the present Passcode to access your iPod Touch and change the Passcode.
1. Go to Settings
2. Go to General
3. Go to Passcode Lock
4. Select "Change Passcode"
5. Remember your new Passcode.
Jun 15, 2014 | Apple iPod touch
IPod is disabled, and I forgot my password / passcode.
The screen lock is available on the iPod Touch, as well as recent models of the iPod, and iPod nano, allowing you to set a 4-digit passcode to lock the screen. This is to prevent others from using your iPod, but it is not an impregnable security device. If you forget the passcode, you can quickly and simply unlock the iPod by connecting it to the computer you normally use to sync your iPod with iTunes.
Dec 08, 2013 | Apple iPad 64 GB WiFi
How to unlock an ipod
Apple's iPod touch, a portable music player with a touchscreen display, is powered by a built-in rechargeable battery that provides up to 40 hours of audio playback and up to seven hours of video playback when fully charged. To conserve power, the iPod touch locks by default after a minute of not being used. If you want to use your iPod touch after it locks, you will need to unlock it. You might need to type a password, depending on how you've configured the device.
Press the "Home" button, located below the screen, or press the silver "Sleep/Wake" switch located at the top of the device. Swipe a finger across the "Slide to Unlock" slider on the screen. The iPod touch unlocks. Press the "Home" button or press the "Sleep/Wake" switch when you have enabled passcode protection on your iPod, then swipe a finger across the "Slide to Unlock" slider on the screen. The "Enter a Passcode" message appears. Type in your passcode, and then tap "OK." The iPod touch unlocks. Forgot Your Password b> Connect the iPod Touch to your computer using the USB cable. Wait for iTunes to open and sync with your computer. Eject your iPod Touch from the computer by clicking the "Eject" icon beside the iPod's entry in the "Devices" section of iTunes. Disconnect your iPod Touch from the USB cable. Your iPod Touch will be turned on and will be unlocked. Tap the "General" menu on the iPod Touch. Tap "Passcode Lock," and then tap either "Turn Passcode Off" or "Change Passcode." If you tap "Change Passcode," you can then enter a new passcode.
Mar 04, 2013 | Apple iPod touch
How do i unlock my ipod touch
Hope it helps
Jan 23, 2013 | Apple iPod Touch Fifth-Generation
How to unlock it
How to Unlock an Apple iTouch
Although locking your iPod Touch prevents accidental touch commands, the feature also prevents you from accessing your media and applications while the device is locked, according to the Apple site. The lock code is the 4-digit code that was created when the passcode lock was first enabled, and displays a passcode menu prompt on the iPod Touch's screen when the "Home" or "Power" button is pressed and the unlock bar is slid across the screen.
Instructions
1 Push the "Home" button on the iPod Touch's screen, or push the "Power" button on top of the device to show the home screen.
2 Slide your finger on the iPod Touch's unlock bar.
3 Enter the 4-digit passcode using the on-screen keypad to unlock the device. If you cannot remember the passcode, plug the dock-connector cable into the iPod Touch and plug the other end into your computer's USB port. According to Apple, the iPod Touch will automatically unlock after it is connected to your computer.
Jan 07, 2012 | Apple iPod touch
How to disable a ipod touch
WARNING: DISABLING AN IPOD TOUCH WILL MAKE IT UNUSABLE UNLESS YOU PLUG IT BACK INTO ITUNES AND RESTORE IT.
If you want to know how to disable an iPod touch:
  1. Go to Settings> General > Passcode Lock >Turn Passcode Lock On > type in a passcode
  2. Now, hit the button at the top of your iPod.
  3. Try logging in with the WRONG passcode many times. This will disable the iPod touch.
Jan 29, 2011 | Apple iPod touch
Ipod touch 16gb, passcode forgotten screen reads disabled.
well you can conpleatly restore it by no luging it in and holding the power buton for 3 seconds then with out leting go of the power buton hold the home buton for 10 seconds then let go of the power buton and just hold the home buton for a further 30 seconds.....
after you have done this plug it in to your computer with iTunes allready running and a icon should say unresponcive ipod or somethin along those lines just click RESTORE
hope this helps
dale gough
Jul 21, 2009 | Apple iPod touch
I FORGOTT MY CODE TO MY IPOD NENO WHAT CAN I DO TO
from wikihow:
  1. Plug in your iPod.
  2. Wait for it to load completely.
  3. Open My Computer (or computer if on Vista). Make sure you can view hidden files.
  4. Go to iPod_control.
  5. Go to the folder named Device.
  6. If your iPod is locked, there will be a file _locked . Rename the file to _unlocked.
  7. Safely remove your iPod and it will be cleared.
Hopes this helps! ^_^ Please rate!
Jun 22, 2009 | Audio Players & Recorders
How to reset password on itouch
how can i reset my ipod touch when its disabled
Oct 12, 2008 | Apple iPod touch
Apple iPod touch Logo
Top Apple Audio Players & Recorders Experts
Sean Cole
Sean Cole
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
