Question about 2wire HomePortal 1800HG Router (1000400229000)
How do I telnet from one computer to another computer, where first computer is connected through wireless and second computer is connected through ethernet cable to "2 wire 2701hg-b gateaway"? Thank you very much in advance.
    Scholar:
  • 97 Answers
Make sure that the computer that you want to telnet to is running the telnet service, and that the firewall on that PC (if using XP/Vista/Win7 and it is switched on, or you have a third party software firewall installed) allows connections to the telnet server.
From the other computer you should be able to just run telnet [destination IP address] and press enter (may need to install telnet client on Windows 7)
Hope that helps
Posted on Oct 16, 2010
How do I telnet to linksys E900
Windows XP included a 'telnet' client.
With Windows Vista/7/8, you have to explicitly choose to install the 'telnet' client.
Then, you can use the 'telnet' command.
Dec 14, 2012 | Linksys E900 Wireless Router - IEEE...
Cant access router admin page
What URL are you using to get to the admin page?
It is possible the Arris has been configured to only allow wired connections to the admin page. You may need to connect an Ethernet cable between your computer and the modem.
If you are connected wirelessly, what is your default gateway? This should be the URL you're attempting to connect to for the admin page.
Nov 03, 2017 | Arris SURFboard SBG900 Wireless Router...
I want to factory reset my nortel AP 7220, how do I reset? What would be default IP after reset?
There is probably a reset button somewhere on the device, it is probably a small pinhole that you put a paper-clip into the reset.
If it has its own http web page, there is likely a reset to factory defualts option.
The ip of the computer connecting to it should not change.
On a computer connected to it, open cmd start>run then type in cmd, and type 'ipconfig'.
It will display details about your connection. Where it says 'default gateway' is the ip of the device.
You could try to put the ip in your browser and see if the device has a web page.
May 02, 2011 | Nortel Networks 7220 (NTE350BG) 802.11...
I can not connect using grabit the error 119 code can not connect after checking most other things out I think it's the router stopping conection of this programme can help me?
Hi ....
This error message appears if:
  • An error at the TCP or IP layer has occurred.
  • The other host has gone down.
  • The network between the gateway computer and the other host has gone down.
You can test these possible causes by attempting to telnet to port 25 of the smarthost and resending the message. This can usually be done by pressing SPACEBAR and typing "25" (without the quotation marks) after the IP address on the telnet command line.
If the error message appears frequently, check the network with a protocol analyzer to determine the exact problem.
Thanks ....
With regards .....
Priya
Sep 26, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
Computers connected to a router can communicate with each other but computers can not ping the router
Find the option on ther routers web interface to allow ping (or ICMP) echos/responses.
It's a security thing on routers and Windows firewalls so that potential hackers cannot verify the existence of your equipment.
Nov 20, 2009 | Linksys Wireless-G WRT54G Router
Where do i set the password to do telnet onto the APs
Microsoft's site goes into detail with telnet,
http://technet.microsoft.com/en-us/library/cc787407%28WS.10%29.aspx
Nov 18, 2009 | Extreme Networks Altitude 350-2 (15939)...
The system can not ping across the wireles bridge..what could be the problem?
Hi
check the firewall on the sytem and the firewall on the router and also make sure that u have used the correct way of pinging( 32 bit or 64 bit pinging). Also try to do telnet using the telnet command TELNET IP .....I hope this will sove your problem
Thank You
Please rate me as it will be just one CLICK
Don't find fault, find a remedy. - Henry Ford
Oct 23, 2009 | Linksys (WMP54GS) 802.11g/b Wireless...
Loopback failed - 127.0.0.1 blocked - web page test not possible
Please explain:
Does it work if you use http://localhost?
Does it work if you use http://127.0.0.1?
If the first one does not, but the second does, it is possible that the issue can fixed simply by selecting.
IE-->Tools-->Options--> Connection --> LAN Settings Check Bypass Proxy for local addresses
If you can't telnet into your computer, make sure you have the Telnet service running :
  1. Click Start, then Run, and type "services.msc" (without quotes) and click OK.
  2. Find the "Telnet" service, right-click and select Properties, select "Automatic" instead of "Disabled" in the startup type box.
  3. Click Apply.
  4. Right-click the "Telnet" service and select Start.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
May 19, 2009 | Zyxel Prestige 600WH Wireless Router...
Can't Access Netopia Admin Panel Via IE
Try this and see if it works for you. Telnet into the modem. Hyperterminal will work fine for this.
Type config, then hit the enter key.
Type set, then hit the enter key.
At this point look at your monitor. Does the bottom line look like this?:
autoConfig (on) [ off | on ]:
If so, type off. Then hold the enter key down for several seconds untill you get to lines that look like this:
Netopia-3000/xxxxxxxx (top)>>
Then type save and hit the enter key.
When the screen says that the configuration data has been saved, type exit and hit the enter key. Then type restart and hit the enter key. When the modem restarts close hyperterminal and access the Netopia using your web browser.
Apr 12, 2009 | Netopia Cayman 3347W-Ent Wireless Router
Connection problem using telnet and web...
Not a definite solution but there are two things you can try.
Firstly, disconnect all cables and power supply to the router and leave it switched off for a minimum of 10 - 15 mins.
Reconnect everything and wait until all the lights on the router stop flashing.
Finally, go to the wireless icon on the toolbar, rick click and select "repair". This will reset the wireless adaptor.
Good luck.
Mar 05, 2009 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
275 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
