Question about Antec AR300 300-Watt Power Supply
Power supply won't come on, no output of any voltage. LED power indicater on motherboard is on.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 63 Answers
First question: is it a new power supply or existing one?
Then we can progress to some disagnosis.
Posted on Dec 25, 2014
5 Suggested Answers
ginko
  • 19396 Answers
SOURCE: DELL POWER SUPPLY TYPE PS-5201-5D REV.F
230 Watts.
Here are specs and replacement:
230W ATX Power Supply - PS-5201-5D - HP-233SNF ...You can also replace it with a compatible 300 W psu.
Posted on May 27, 2008
  • 6 Answers
SOURCE: Blinking power supply LED
Your power supply is fried. I had the same problem with my Bestec ATX 250 power supply. I fixed the problem by installing the StatTech model: ATXPOWER250. It was easy to install and works well. It is almost identical to the original but more quiet. I got it for $29 at MicroCenter.com. Also at online Newegg.com, Radioshack.com, Provantage.com, June 20,2009
Posted on Jun 20, 2009
  • 468 Answers
SOURCE: get a light on the motherboard and sometime the
Her you have standard voltages for ATX power supply
Posted on Oct 12, 2009
  • 1027 Answers
SOURCE: Computer does not power up. How do I check for
Check the power switch on the power supply itself.
Posted on Feb 11, 2010
Have dell Inspiron 546 minitower. Been acting up lately where it won't power up. The LED light on PSU below voltage switch is green. Light on MB is orange. No power or indication at all on front...
PSU's put out several different voltages if the 12Vs isn't working it won't power the motherboard. Some outputs may still be functioning therefore you may see some lights on and even some fans running. Replace the PSU.
Jun 29, 2013 | Computers & Internet
Lg 47lk520 reset
tried first to disconnect the supply connector going to the inverter board for back light just to ensure if their is no shorted component here. and then turn the power on again if the light stay then the inverter board was the cause why won't power on. by the way did you make a voltage checking at the power supply board does it have correct output voltages 5v,12-16v and the 24v.
Sep 18, 2012 | Televison & Video
Power light is blinking and the tv won't power up.
In that case the problem of your television is the power supply.The power supply have low voltage output so that the board of your TV cannot drive,so that the TV wont turn on.The power supply have leak capacitor that may cause of abnormal voltage.The output voltage of the power supply is +5V, +12V, and +24V.So the power supply is the problem its need to repair.Thanks
Aug 24, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
Does not switch on led light flashes 10 times
Power supply problem.There is to low output voltage in the power supply cause of leak capacitor.Replace all leak capacitor to make the normal output voltage of the power supply..Thanks..
Aug 24, 2011 | Televison & Video
" power on " indicater
Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then - The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty. Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard. This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Aug 11, 2011 | Computers & Internet
I have sony J21mn11. problem not power on only red lit led only.i check all the components on the power supply area and horiz. output D1878 all are good. there is power IC STR S6707 on power supply area. i...
If you have a digital tester or analog try to check the voltage reading from the power supply if high or low or no supply.Check first following voltage location and section. * Check the AC voltage from ac cord to fuse and before the bridge type diode. * Check the DC voltage after the bridge type diode.if normal voltage. * Then check the voltage into the filter capacitor to regulator ic.the power ic.If theres a input voltage in the power ic,check the output voltage going to harizontal output.If no output the problem is you power output.You need to replace it.
Jul 12, 2011 | Sony Televison & Video
Hp pc m7640n won't turn on and power supply light is out
OK, this can be a hard thing to fix. Most of the time, the power supply is the first thing to go on a PC. However, when you stated that the motherboards LED came on after you unpluged the PS from the motherboard, it leads me to believe that the motherboard is the issue but the power supply might be outputting higher voltages and the motherboard might be shutting down. Since the power supply is cheaper then most motherboards, I would recommend getting a new one. Check ebay for a new power supply. It should be about $20 with shipping. If the same thing happens, then you need a new motherboard...
May 30, 2009 | HP Pavilion m7640n PC Desktop
I tried several different cards but no luck. Cards work ok on other computers.
5V Stand-By Indicator LED
The power supply will always supply a 5V standby voltage to your
motherboard so that it can power on via for example Wake On Lan
technology. This LED shows that your power supply is supplying
this standby voltage to your motherboard.n :D
You may need to replace your power supply, if the LED is flashing, it's not supplying the power the motherboard needs.
[JP-25]
1 2 3 4 5 6 7 8 9
10 11 12 13 14 15 16 17 18
1] Power Led (+)
2] --
3] Power Led (-)
4] --
5] --
6] Speaker (+)
7] --
8] --
9] Speaker (-)
10] Reset switch
11] Reset switch
12] N/A
13] Power Switch
14] Power Switch
15] ACPI Led (+)
16] ACPI Led (-)
17] HDD Led (+)
18] HDD Led (-)
For future reference you can download your motherboard manual here:
(PDF) Soyo K7VKP2
May 09, 2009 | Computers & Internet
Emachine t6532 motherboard issue???
Is your new SUP has the same specs with the old SUP? like voltage output, WATTS etc....
Usually motherboards have a led light in it that will light up when its connected on SUP.
regarding the wire placements for power and led connectors, you can view it in your users manual.
Feb 05, 2009 | E-Machines eMachines Desktop PC
Motherboard fried?
the problem is your power supply, since the power supply have differrent output voltage there is 12volts, 3volts and so on. the 12volts output voltage is not giving enough power. you can determine this by detaching the 20pins from your motherboard coming from the power supply then power-on the power supply then use a jumper wire insulated but scraped both ends (conductor visible) then connect it to the green connector and the grey connector if the fan of the power supply doen't rotate then you 12volts output voltage is busted.
Oct 22, 2007 | EliteGroup 915P-A Motherboard
Antec AR300 300-Watt Power Supply Logo
283 people viewed this question
Top Antec Computers & Internet Experts
Steven Wander
Steven Wander
Dimitar Todorov
Julie Endres
Are you an Antec Computer and Internet Expert? Answer questions, earn points and help others
