Question about Audiovox Richmond 6G40-36F 6-Year Tall Gas Water Heater
Flammable sensor is lit and won't go off. I replaced the sensor how do i reset the controller?
  • 760 Answers
Certain water gas water heater models feature electronic controls with a flammable vapor sensor installed on the bottom portion of the water heater unit. This sensor is designed to shut off your water heater system to prevent fires in case flammable vapors are present within the area. If your flammable vapor sensor caused your water heater to shut down, check the area immediately for leaking gas or other flammable products. Common household chemicals such as bleach can also trip the safety system as well as unsuccessful burner ignition attempts. I'm not sure what control your unit has, but on a White Rodgers here's how it goes.
White Rodgers Intelli-Vent PowerVent Control Equipped Models
  1. Step 1 Turn the water heater's blower switch off and disconnect the power cord for the water heater (refer to your particular model's operation guide for the exact location of the blower switch). Disconnect the Molex connector attached to the bottom of the control pad (the left most connector with five pins).
  2. Step 2 Turn on your multi-meter and set it to read resistance or "ohms". Connect one of the multi-meter's probes to the number two pin and the other probe to the number three pin of the Molex connector (middle black wires). If the reading on your multi-meter reads below 9k or above 45k ohms, the flammable vapor sensor is faulty and in need of replacement; you cannot reset the system until this issue is resolved.
  3. Step 3 Reconnect the Molex connector to the bottom of the control pad, reconnect the water heater's power if and turn the blower switch to the "ON" position. Press both the left and right buttons on the control pad at the same time. Wait for the green light on the control pad to blink and press the following buttons in sequence: Left, Right, Left, Left, Right, Left, Right, Right (you will need to perform these actions within 30 seconds of reconnecting the power cord to the water heater in order to be successful
Posted on Oct 16, 2010
  • Greg Nelson Sep 30, 2012
    This worked great , Thanks !
Reset lock out due to fvd
You can reset some models.... depending on gas control valve and FVIR design.
Some newer models you replace the sensor located on outside of tank.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
http://waterheatertimer.org/How-flammable-vapor-sensor-works-Therm-O-Disc-25VS.pdf
Gene
Jun 04, 2014 | Rheem 40 Gallon FVR NATGAS Low WATER...
50 gallon **** power vent LP with flammable vapor sensor problems can you bypassing
You can't bypass a flammable vapour sensor. it works on resistance not continuity. You can try moving the sensor outside for a while and it may reset itself...meaning that the resistance may fall back within range. You are best to have the sensor replaced by a qualified technician who can also verify that you do not have an underlying issue such as a gas leak which is causing the sensor to trip.
May 10, 2014 | RHEEM 50 Gallon FVR NATGAS Water Heater...
Hot water heater womt light, flammable vapor sensor code
Most likely: Combustion chamber got too hot because air intake is clogged with dust, causing less air to flow upward through vent pipe ... the slowed flow of air caused combustion chamber to overheat.
What brand and model water heater?
Look at label on side of unit and add comment.
Otherwise call service tech to repair/ replace water heater and clean arrestor screen (air intake) and replace or reset parts as needed, depending on model number and brand water heater.
AO Smith, Bradford white, and Rheem are main manufacturers.
Each has slightly different repair protocol, and each gas control valve can also be different. So more information is needed.
Identify gas control valve:
Rheem TRD/ FVIR glass vial
http://waterheatertimer.org/How-to-repair-Rheem-FVIR.html
How to remove combustion parts to inspect for Rheem glass vial and clean arrestor screen located under combustion chamber:
http://waterheatertimer.org/How-to-replace-thermocouple.html
Sep 30, 2012 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
Detecting gas and won't light
Open following link for troubleshoot error codes showing 7 flashes on Honeywell gas control valve is system lockout due to flammable vapor:
http://waterheatertimer.org/pdf/Honeywell-gas-control_error-Damper-series.pdf
The FV system in Rheem can be tripped by presence of flammable vapors such as gasoline or paint fumes etc, or it can be tripped if water heater was dropped, or mis-manufactured, or if gas control valve is defective, or if water heater is not getting adequate fresh air, or there is inadequate venting of combustion by-product.
When combustion chamber overheats, then glass vial breaks and damper shuts off air supply to water heater and it will not light.
Open following link for possible help fixing the problem:
Jun 13, 2012 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Is there a reset button for a 6G50NVH-FV-02 hot water heater
Depends on gas control valve, and if cause is overheating high-limit event or FVIR flammable vapor event.
Turn off water heater when using flammable vapors, clean burner parts to prevent overheating.
1) GSW Residential power vent gas water heater with FVIR system:
Some models have intelli-vent gas contol
Others have robershaw gas control with auto-reset
2) Parts manual shows #15 'auto-reset' high limit switch on the blower
http://www.gswpartsonline.com/model/27484
http://www.gswpartsonline.com/schematic/137/view
3) Possible manual:
http://www.gsw-wh.com/pdfs/GPD135NInstall.pdf
Shows resettable lockout page 15
Water temperature must be 120 degree F or lower for reset. Unplug power cord, and then plug back in and wait 15 minutes or 60 minutes depending on gas control valve.
Some intelli-vent controls must be replaced when 195 degree high limit event locks out the water heater.
If high-limit lockout repeats, then gas control must be replaced.
Also clean burner parts, air intake, and make sure flame is clear blue. and not yellow-or-orange.
4) Intelli-vent service manual might apply to your water heater:
http://waterheatertimer.org/pdf/Intellivent-service-manual.pdf
If FVIR flammable vapor event locked out heater, then unplug heater and plug back in.
Immediately press two temperature buttons. Wait for green light to blink. Release buttons.
Page 34 in troubleshoot chart.
5) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Aug 31, 2011 | Fasco GSW Hot Water Heater Exhaust Draft...
My water heater say i have flammable vapors present and is locked out how can i reset it or fix it there are no vapors present
Contact Rheem
http://www.rheem.com/Contact.aspx
1 800 432 8373
Locate product information on label on side of tank.
Typical manuals say if lockout occurs, then refer to gas valve codes and/or troubleshoot section:
http://globalimageserver.com/fetchDocument.aspx?id=a92c7d0e-8a95-48ba-8810-cd714f33d47a
http://globalimageserver.com/fetchDocument.aspx?id=80b1d50e-695f-49ac-9aae-3e9489ef1e5a
For example the manual says:
1. Verify no gasoline or flammable
vapors are present
2. Reset control using ON/OFF switch
on the gas control valve
3. Replace the flammable vapor sensor
http://waterheatertimer.org/images/Wiper-FVSensor-100.jpg
http://waterheatertimer.org/pdf/Rheem-Parts-Guide.pdf
http://waterheatertimer.org/pdf/Rheem-parts-list.pdf
Aug 11, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
I have a GPVH 40 100 AO smith hot water heater.The FV (flammable vapor) sensor has been setoff from us painting the floor yesterday. How do I reset the unit?
AO smith manuals
http://www.hotwater.com/lit/im/r-gas.html
GPVH series manual
http://www.hotwater.com/lit/im/res_gas/315465-000.pdf
You can search the manual for FV
The FV sensor shorted because it detected flammable gas
Quote manual:
Flammable liquids (such as
gasoline, solvents, propane (LP or butane, etc.) and other substances
(such as adhesives, etc.) emit flammable vapors which can be ignited
by a gas water heater's hot surface igniter or main burner. The
resulting flashback and fire can cause death or serious burns to anyone
in the area. This water is equipped with a FV sensor for detecting the
presence of flammable vapors, see Figure 3. When the sensor detects
those vapors, the unit will shut down and not operate. Should this
happen, please refer to the troubleshooting guide on pages 28-30.
Troubleshoot step 14-15 says
replace the FV sensor
call tech assistance number that shows on water heater
AO Smith will refer you to a plumber
I don't believe homeowner can buy these parts due to Federal regulations
The shorted FV sensor probably saved you a flash-over
The cost of 2nd degree burns from a flash-over would be astronomical.
Fortunately you're ok, and the other folk in the room are ok.
In the old days.
Two guys I knew, winter 1978 Chicago, were laying VA tile using the black mastic.
They were killed and the house burned down because of the water heater.
Main office marked the event with a memo saying they still owed money on their account.
The only company with a re-settable FVIR that I'm aware right now is Bradford White
http://www.thetankatwaterheaterrescue.com/forums/forum3/2679.html
http://411plumb.com/bradford-white-defender-water-heater-review
Bradford White Defender FVIR is resettable without buying parts.
Oct 24, 2010 | Water Heaters
Basement was flooded when washer inlet hose burst. Approx 6 in of water in the area where the water heater stands. Complaint of no hot water, no pilot flame. Attempt to light pilot successful but pilot...
Certain Rheem water gas water heater models feature electronic controls with a flammable vapor sensor installed on the bottom portion of the water heater unit. This sensor is designed to shut off your water heater system to prevent fires in case flammable vapors are present within the area. If your flammable vapor sensor caused your water heater to shut down, check the area immediately for leaking gas or other flammable products. Common household chemicals such as bleach can also trip the safety system as well as unsuccessful burner ignition attempts.
Oct 01, 2010 | Rheem Water Heaters
Hosed basement floor. soaked flamable vapor sensor. Removed and dried sensor. control now in lockout. How do you get control out of lockout???
  3. Step 3 Reconnect the Molex connector to the bottom of the control pad, reconnect the water heater's power if and turn the blower switch to the "ON" position. Press both the left and right buttons on the control pad at the same time. Wait for the green light on the control pad to blink and press the following buttons in sequence: Left, Right, Left, Left, Right, Left, Right, Right (you will need to perform these actions within 30 seconds of reconnecting the power cord to the water heater in order to be successful).
Jul 23, 2010 | Rheem Water Heaters
Audiovox Richmond 6G40-36F 6-Year Tall Gas Water Heater Logo
1,283 people viewed this question
Top Audiovox Water Heaters Experts
Paul Carew
jdthefixer
Richard Lindsey ...
Are you an Audiovox Water Heater Expert? Answer questions, earn points and help others
