Question about GE 25.0 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Black-on-Black
Freezer keeps freezing over then the entire unit stops working, what is this??
  • GE Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 17, 2010
My Frigidaire refrigerator works find; Freezer stays cold but doesn't freeze food or ice
Its defrost assembly parts issue or the compressor is getting waek indication.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 23, 2012 | Refrigerators
I have to push on my freezer door to keep the blower running
there is a loose connection at the rear of the freezer near or around the compressor unit , i strongly advise you to get a professional to look it.
Regards
Dec 16, 2012 | Haier Freezer HUF168PA 16.8 Cu. Ft....
My freezer leaks when not freezing
Drain tube
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer. If this repeatedly happens with yours, you may can prevent it by taking a bare copper wire and wrap it around a fin near the heater and put the other end a few inches down the drain. The heat convection may prevent it from freezing.
Mar 02, 2010 | Refrigerators
Kenmore elite refrigerator model 106.50504990 ice trough in freezer freezing up. Could this be the fan in the freezer is not working?
If the other parts of the unit are not cold, you may check out the fan. But this can be caused by build up of dirt or clogging of the freezer drain, trapping water and eventually freezing. Isolating the fridge and freezing the entire freezer. It could also be the thermistor or the one that tells the part that serves as the thermostat may have frozen up and is not giving accurate reading. If the unit is old, this may be a sign that the freon level is incorrect.
Nov 11, 2009 | Cameras
Eaton viking imperial fridge keeps making ice build upin grate in bottom of freezer how do i fix this problem
the return air ducts are freezing up, unplug unit and use a hairdryer to defrost the entire freezer compartment
this will take a couple of hours to completely thaw the ducts
the ducts are behind the rear panel in the bottom
Nov 02, 2009 | Refrigerators
The side by side freezer compartment water keeps freezing up in the bottom of the freezer - i took the back panel off and tried to melt the ice which has been accumulating and thus causing the water which...
Sep 23, 2009 | Jenn-Air JCD2389G Side by Side...
About every 2 months the defrost drain gets plugged
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help. Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Take a bare copper wire and wrap it around a fin near the heater and put the other end a few inches down the drain. The heat convection may prevent it from freezing.
Jul 01, 2009 | Whirlpool ET8WTKXK Top Freezer...
My GE side-by-side has 2 problems, maybe related?
i have a 29 sidexside Ge refrigerator. tonight when i was trying to get ice,it stopped working and after a few seconds,with a clock like sound it began to work again.but everytime i try to get ice it happens again.last year i chanege the board. what is the problem,can i fix it?
Jun 07, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
The fridge part of my fridge freezer keeps freezing everything,
Hello
I have the same problem and have talked to the manufacturer. They said to turn off the appliance for 24 hours then it should be good as new when you switch it back on. Obviously you'll have to find somewhere for your freezer contents. I'm going to try this myself tonight.
Fridge Reboot!
Jan 05, 2009 | Hoover HCA390FFK Bottom Freezer...
GE 25.0 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Black-on-Black Logo
64 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
