Question about Invacare Pronto M51 Power Wheelchair
While charging the red and yellow light is on and the charger gets real warm. when I turn it on the light ay the joystick blinks green 5 0r 6 times and then red, No power, it don't do anything. Checked fuse at charger with ihm meter--Its Good--
  • 280 Answers
Sounds like you might have bad batteries. It is OK for a battery charger to get warm as it charges batteries, but getting hot indicates the charger is working too hard charging poor/old batteries. Do a load test on the batteries with a load tester or use a DVM at the charging port on the joystick. I can provide more specific information on how to do this. There are other more specific, easier checks looking for disconnected or loose battery connections, disconnected/broken cables, etc. The on board chargers for this model were very problematic with issues including drive inhibit and outright failures with the early black Soneil versions. The new CTE chargers are much more reliable. Hope this helps.
Scott
Posted on Oct 24, 2010
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 346 Answers
Hi,please rate me as in 1 to 4 thumbs up for my answer.im disabled myself & here cause i care.
Visit:Shoprider.com & download as a PDF File:troubleshooting_2007 SHOPRIDER.pdf. save to your Adobe Reader & print n save to a polythene sleeve folder for future.
If YOU CANT DOWNLOAD IT THERE,VISIT:WWW.ALLDATASHEET.COM & THERE IS WHAT IT SAYS [ALLDATA IN THE WORLD] & IT GETS UPDATED EVERY DAY.
The file is 36 pages long=1 to 5 on batteries & chargers.6 to 18 on scooters & 19 to 36 on wheelchairs.My opinion you know how to use a meter,so your able to learn.Take a pic of anything you do,what not sure about with ur mob.Then you can refer back to it.Have a nice day,hopefully you will solve your problem,Colin.
Posted on Oct 16, 2010
Charger seems to have both red and green lites flashing at the same time no sequence and both batteries connected read 4.0 VDC, are these chargers repariable or throw aways
Your manual is here. The section on charging states, that green blinking means your battery is fully charged but blinking red means that your charger is faulty. I would say repairable.
1. Plug the female connector of the AC power cord (supplied) to the AC receptacle on the charger and plug in the male connector on the AC power cord into the wall outlet.
2. The On/Off LED indicator is blinking RED, this is abnormal. Unplug AC power cord from the on-board battery charger and wall outlet. Charger may need to be replaced. Contact an Invacare dealer or qualified technician.
3. When the On/Off LED indicator light is Off, charger is Off.
4. When the Charge LED indicator light is YELLOW, the batteries are charging.
5. When the Charge LED indicator light is solid GREEN, the batteries are fully charged (as their condition will allow).
6. When charging is complete, unplug the male connector of the AC power cord from the wall outlet and then unplug the female connector of the AC power cord from the AC receptacle on the charger.
http://www.invacare.com/doc_files/1125085.pdf
Mar 24, 2016 | Invacare Pronto M51 Power Wheelchair
How to charge the batterry
the charger port is located under the front of the joystick. with the charger off plug the 3 pin connector into the charger port then turn the chrger on or plug it into the wall. You should see a red and a yellow light when the yellow light turns green the batteries are charged turn off the charger and remove the plug from the joystick See my tip on charging Hope this helps you
Jun 05, 2011 | NRS Hoveround MPV 4 - Hovaround Used...
I have replaced joystick, batteries, motors and the chair still losing lights will go about 1/4 mile and loses all green lights with in 1/2 mile loses all the yellow lights, drove on 1 flashing light for...
Janice check your charger it could not be charging the batteries. Now always charge your batteries overnight while you sleep When you get up lights on the charger should be red and green if they are red and yellow then the charger hasn't fully charged the batteries and overnight should be more than enough time to charge fully. This could indicate a bad battery remember new doesn't always mean good. Like they say always charge before use and this goes for new batteries too you need to charge new batteries nightly for 10-15 days before they start operating at 100%. If when you plug in the charger before bed and the lights are red and green then there is a problem with the charger or the batteries or the charger circuit Hope this helps you
May 23, 2011 | Spirit Activecare /wildcat Foldable Power...
On the Jazzy select what color for charging indicates fully charged, red, green?
scraig Lights on the joystick all lit up to the far right and the green light lit on the charger. Red indicates charging or blinking red indicates error in charger. Hope this helps
Nov 20, 2010 | Pride Mobility Products Jazzy Select
When I plug it in to charge the red and amber lights stay lit and the green flashes and if i move the joystick everything is backwards push forward goes backwards left is right. b4 when it was plugged in...
sounds like a charger inhibit problem. Whenever you charge your chair the charger inhibit shuts down the chair so it can't be moved while charging. If you are getting this then that function is not working. Lets try this if you know of someone who has a chair or scooter with an off-board charger see if you can borrow it. Plug the off-board charger into the charger port located under the front of the joystick (don't have the on-board charger plugged in) and then turn the charger on. turn the chair's power on and you hopefully will see the lights blinking again indicating a charger plugged in (charger inhibit) the lights on the charger should be red and yellow (yellow turning green when fully charged) If you still get the problem with the off-board charger then your problem is in the controller or power module and this requires a new one. If Medicare paid for your chair you can call Repair Xpress @ 1-877-81-3733 or Roadrunner Mobility @ 1-800-467-2668 to have them fix it for you and bill Medicare for most of the repair costs. Hope this helps you
Oct 31, 2010 | Invacare Pronto M51 Power Wheelchair
I've been charhing the battery for 48 hours and no charge! any answers?
Kw How old are the batteries and have they been sitting up for a long time? If this is the case the charger cannot pick up really low batteries and charging them for 48 hours won't help. Unfortunately you have to get 2 new batteries. Your chair requires 2 U1 batteries. Now if the batteries are fairly new and when you plug the charger into the joystick you should be getting a red light and a yellow light on the charger. When fully charged the yellow light turns green. If you have both lights and it never turns green bad batteries if no lights or just the power light bad charger, If you have a digital voltmeter you can set it on 200 volts dc and place the leads in the two outter charger plug holes on the joystick. It should read the battery voltage fully charged 25-27 volts HOPE THIS HELPS
Sep 06, 2010 | NRS Hoveround MPV 5 - Used Power...
I have a jazzy power chair and when you turn it on all the lights come on for about 3 seconds then they go off and all you have is the red lights. we live in alaska so nobody around here to take it to
John Do the red lights blink or steady? this indication on the joystick usually means low batteries. Now this could be caused by bad batteries or a bad charger. On the jazzy if you have an on-board charger the light on the charger will come on green when the batteries are fully charged. If you can look under the rear of the chair you will see the charger and can tell if the light is green with the charger still plugged in after charging overnite. If the light is not lit then you probably have a bad charger. If you have a digital volt meter put it on dc volts 200 volt scale and plug the leads into the two outter charger port holes located under the front of the joystick. Your battery level should read 24-26 volts after charging all nite and with the charger plugged in up to 30 volts if there is no change in the voltage from charger plugged in and not plugged in then the charger is bad. You can then look to purchase an off-board charger that plugs into the joystick charger port to charge your batteries. If your battery readings are lower than 21 volts even after trying the new charger then you will have to replace the batteries. You might try to find someone in the local area that has an off-board charger you could borrow to see if you can get the batteries to charge. This will help you find out if the batteries need replacing. Hope this helps
Aug 25, 2010 | Pride Jazzy 1103 Ultra Standard Power...
How do I know when the chair has charged? I see one red, two green, two yellow lights on.
If you have an off-board charger that plugs into the joystick there are two lights on the charger one red(power on) and the other yellow (turns green when fully charged). Plug it into the chair and if the light is green then you have fully charged the batteries. Now if you have the on-board charger the charger meter on the rear of the chair will resd zero when fully charged. Hope this helps ya
Aug 18, 2010 | Electric Jazzy 1115 Power Wheelchair
When turning power it makes a clicking sound but does not power up. battery charger has a red and green light on. When plugged in and turned on it flashes 8 times. I checked the power control connection,...
The chair will not move if the charger is plugged in. The flashes are normal with the charger plugged into the chair. The lights on the charger mean that the batteries have been fully charged. Red and yellow lights mean charging. After you unplug the charger from the chair (if off-baord charger, turn charger off or unplug from the wall) then unplug from joystick. after plug is removed from joystick press the on button and all the battery lights should be lit and when you move the joystick forward you will hear the electric bake release and the chair should move forward etc Hope this helps
Aug 10, 2010 | Pride Jazzy Select 6 Indoor Power...
How do i know when my invacare pronto m5 is fully charged?
With an M51, a full charge will be indicated by all three joystick indicator lights lit- red yellow green. The green far right LED is the full charge light. Also the charger has indicator lights that go from red/yellow to full green at full charge. Hope this helps
Jul 11, 2010 | Invacare Pronto M51 Power Wheelchair
Invacare Pronto M51 Power Wheelchair Logo
226 people viewed this question
Top Invacare Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
MobilityRepairSpecia...
Level 1 Expert
Are you an Invacare Health and Beauty Expert? Answer questions, earn points and help others
