Question about Fasco Bradford White Hot Water Heater Exhaust Draft Inducer Blower # 239-42133-00
My hot water heater exhaust blower seems to run quite often, even though hot water consumption is not great. How often should the blower operate?
  • 760 Answers
Your blower should run from before the heater lights until after it has shut off. Even if you're not using water, it will cool, and the heater will have to light to maintain temperature.
Posted on Oct 16, 2010
Why is the water running out of my water heater slowly?
If you take your pipe off the hot side of the water heater, there is a check valve in the pipe that is stubbed up. They vary in style, usually it is like a marble and it gets stuck. It is easier to replace the stub with a brass nipple and put the dielectric fitting back on it.
Dec 19, 2014 | Fasco Bradford White Hot Water Heater...
I have a paloma ptg2-42pvn tank less water heater. I recently installed the remote as the unit quit making hot water. I wanted to see if it was producing a code. The remote is flashing 76 repeatedly. I...
Bad remote control. Bad wire to remote control. Bad PC board.
Copy following link for resources, including older service manual and error codes and rheem chat for ordering replacement motherboard for your tankless computer.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
If tankless computer is 5 years old, then compare that to your 5-year old cell phone or 5-year old laptop, and ask if the chipware still functions or can be repaired to function back to factory fresh expectation.
Later today, install tank type water heater and solve all tankless computer problems with one ez step. Have hot water for shower same day with less maintenance and fewer long-term problems and expense.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Gene
h
Aug 24, 2013 | Water Heaters
Bradford-white water heater wont heat water.the blower motor hums but wont blow.also,pilot light wont light,is this just a safety feature?
Water heater is not identified and gas valve is not known.
Review options below:
1) Add a comment and describe what gas control valve is on the water heater, and model number from label on side of unit. Include what you have tried so far.
2) Try unplugging water heater and see if water heater resets.
Disconnect blower from gas valve, then plug blower in to see it it operates.
This will eliminate or include blower as suspect.
3) Open following link to download service and product manuals to help troubleshoot exact model.
http://www.bradfordwhite.com/documentation/residential/gas.asp
4) Open following link to identify gas valve.
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html#intelli
Oct 04, 2011 | Fasco Bradford White Hot Water Heater...
The blower is running constantly, trys to ignite gas burner,no hot water
the Thermos coupling has gone bad, call the manufacture and talk to customer support.
Apr 26, 2010 | Fasco Bradford White Water Hot Heater...
My hot water tank won't start, i can hear humming sound from the blower, but blower doesn't run, ant it does no heat.
If the blower will not run, then the unit will not fire up due to a safety hazard. If it is a capacitor start motor, then you may have to replace the capacitor, otherwise you will have to install a new blower motor. Hope this helps
Apr 03, 2010 | Fasco Bradford White Hot Water Heater...
Please help! Our draft inducer on our gas water
You are OKAY!!!
If the inducer connot run the gas valve will not turn on.
You will be fine till morning the way you are.
Just be sitting down when they tell you the price of a new inducer...
Heatman101
Jan 20, 2010 | Fasco GSW Hot Water Heater Exhaust Draft...
Bosch AQ125BNG Burner goes out even though the
Often, this is the result of a restriction of exhaust gases. This type of hot water heater must be adequately vented, (per installation specs). I found this out after taking a number of cold showers. :^( Two years later, and still counting, no more problems. :^)
Jul 11, 2009 | Bosch Water Heaters
Noisy water heater blower
It may just need a new pump coupling. Fairly inexpensive. I don't think you need to replace the whole burner.
Feb 14, 2009 | Fasco Bradford White Hot Water Heater...
Fasco Bradford White Hot Water Heater Exhaust Draft Inducer Blower # 239-42133-00 Logo
589 people viewed this question
Top Fasco Water Heaters Experts
Charles T Nevin
Charles T Nevin
Gil Shultz
Are you a Fasco Water Heater Expert? Answer questions, earn points and help others
