Question about SanDisk Sansa m250 MP3 Player
My player would come up with a message, 'load main image failed. Switch to recovery mode'
Every time i turn the player on, i get this message appearing, 'load main image failed. Switch to recovery mode'
  • 8,596 Answers
Get the Sansa Recovery Tool from the sandisk website, and go from there.
JIC:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Jun 07, 2008
Sansa 260 R load main image failed message
The Sansa e260 Rhapsody could be recovered by resetting the player.
How to reset the player :
1. Player switched on.
2. Press and hold the power button for approximately 30 seconds.
3. Put the player back on.
When the fault is not resolved a firmware update / reinstallation needs to be made. There are 2 steps needed for getting new firmware on the player.
Step 1: switching the player into recovery mode / MSC mode
1. Turn off the player.
2. Slide the Hold/Lock switch on top of the player so an orange color is showing.
3. Press and hold the REC button and connect the device to the computer.
4. A message will appear on the device display screen confirming the connection and a memory partition will be viewable in My Computer.
5. Release the REC button.
Step 2: Update the firmware ( updating firmware always in MSC mode, see Step 1 )
Use next link for updating the firmware:
http://kb.sandisk.com/app/answers/detail/a_id/306
The Sansa updater installation on the computer should be the easiest way to update firmware.
Need more help ? Just post a comment.
Dec 17, 2009 | SanDisk Sansa e260 MP3 Player
Sansa e200 load main image failed
i'm thinking that it has too much info on it, so it ets stuck when you turn it on.
Jul 31, 2008 | SanDisk Sansa e260 MP3 Player
Load main image failed Switch to Recovery mode
Use the Sansa Recovery Tool on the Sandisk website
Jun 01, 2008 | SanDisk Sansa e250 MP3 Player
My sansa e250 ask me this
Solution:
1. Put Lock on.
2. Push and Hold Both Rec and Power buttons while the power is off.
Then message should show saying: " Welcome to Recovery Mode"
Mar 17, 2008 | SanDisk Sansa e250 MP3 Player
Load main image failed, Switch to recovery mode"
If it still plugs in and works properly, you can try to format it or try to update its firmware with the firmware updater that you can download from sandisk.com and then click on download.
Jan 23, 2008 | SanDisk Sansa e250 MP3 Player
go to sandisk and go to support there you can find support the recovery software. hope it helps
Jun 16, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa m250 MP3 Player Logo
22 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
