Question about Electrolux Vacuums
I have an Ecectrolux Epic canister vacuum. As soon as it starts sucking, the vacuum cuts off. I put a new filter and bag in, but it doesn't seem to help. If I open the front where the bag goes, take the bag out and depress the safety button the vacuum will run. Need some help or direction. Thank you
  • 694 Answers
Try this.
Disconnect hose. Turn machine on and place hand over intake. If it shuts off immediately, first try turning dial on top of machine so largest dot matches up with arrow. Turn on and place hand over intake again. If it still shuts off immediately, the "control valve assembly" is worn or broken and needs replaced. Don't try this yourself.
Take your complete machine to the nearest authorized Aerus Electrolux shop, or call and ask someone to pick it up. There's no extra fee for this, or delivery upon repair.
The repair/replacement should include a complete cleaning of your vacuum in the labor, but ask the service manager to be sure.
The shop nearest you can be found by typing your zip code into the indicated space on the site listed below.
http://www.aerushome.com/storelocator/
Posted on Oct 15, 2010
How to fix
The machine may be over heating.Check the hose and power head for a block.Or,put in a new bag and suck in a few pieces of tissue to coat the lining of the bag....Chris
Aug 01, 2014 | Electrolux Epic 6500 Vacuum
Kenmore 116.22612 will not suck...only blows out. Checked for all clogs, put in new bag, cut away all long hairs circling the rotator brush and let it cool off. Now what?
All things being equal, it would be helpful to know what has happened since the last time it was used? and how long ago that was? One thing to check, there must be a bag in the unit or it will not have much, if any, suction. However, other than that there's no good reason for this action.
Oct 21, 2013 | Electrolux EL7020A Oxygen 3 Ultra Canister...
I have the electrolux epic 6500 sr. when i
As hooton8 stated i have the electrolux epic 6500 sr. as well and when i attempt to vacuum i turn it on and it turns off after about 3 seconds. new bag nothing stuck in tube. I turned dial to the right all the way. Works when hose is not connected..hose is clear.
Dec 05, 2009 | Electrolux Epic 6500 Vacuum
What size/model bags do I need for my Electrolux Epic 6500 SR vacuum?
You need an Electrolux Cannister bag to fit pre 2001 Series cannisters. You can fin them at a VAC Service center or thru AERUS Electrolux. Buy only a 4 ply bag, nothing thinner.
Sep 08, 2009 | Electrolux Epic 6500 Vacuum
I have a Electrolux Epic 6500 SR canister vacum cleaner. It is nine years old and for the past few weeks it has started shutting off for no apparent reason.The symbol for bag change lights up and it cuts...
Your machine is probably clogged, look through the wands, look in the bottom attachment, to see if there is anything stuck there. You can also drop a marble through the hose itself to see if anything is stuck there as well. To unclog the hose try holding the attachment end of the hose were you would normally plug the hose in. ( the goal is to **** the clog out the way it came in).
Aug 18, 2009 | Electrolux Harmony Canister Vacuum -...
Vacuum won't stay on
When you open the canister you eill see a little rubber hole that senses when your bag is full. This must be clogged. If you have another vac try to vacume all the dusr from this hole and any other opening inside the vacume that you can reach. I hope this helps. Don't forget to rate this answer.
Feb 07, 2009 | Electrolux Epic 6500 Vacuum
Filter queen spitting more than sucking
Usually this means that you have a clog, either in the hose, wands, or by the brush roll in the power head.
May 05, 2008 | Filter Queen Majestic Canister Vacuum
Electrolux Epic 6500 SR series
Ok i found a solution for my Electrolux Epic 6000 which had the exact same symptoms as you describe. I fixed it by disabling the "bag full sensitivity adjustor" (BFSA for short, for the lack of a better term). For that i opened the case, removed the hose that was preventing me from opening complety the casing, unscrewed the transaparent BFSA mechanism.
Here's the walkthrough:
- Open the case: Open the top part of the vacuum (where the bag is)
- Remove the 2 side rubber by sliding them from the back to the front of the vaccuum
- Remove the "plastic cap" at the end of the vacuum (you can slightly lift the vacuum top part to make it easier)
- Now unplug a small air hose to be able to open the case completely.
- Find the BFSA device and unscrew it.
- Now give your vacuum a try... it worked for me.
Nov 27, 2007 | Electrolux Epic 6500 Vacuum
Vacuums Logo
66 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
