Question about Westwind Classic Hugger Polished Brass 52" Ceiling Fan
Replacing fan switch
I have a new switch for the ceiling fan the old one wasn't attached anymore.. the new switch has a black, blue and red wire... however the inside of the light is yello orange, black and purple.. what goes to what???
  • 6 more comments
  • rebel1297 Jun 03, 2008
    no.. the ceiling fan when you pulled the chain didn't work, when I took the light off I found that the pull switch for the ceiling fan was broken.. and since the thing wasn't intact all the wires were just laying in the open so I don't know where the wires go.
    no I do not
    no I do not
    there is nothing on any of the wires.. I think a guy made this thing!!! I re-put up the ceiling fan up no problem, but the switch that was defective/ broken has no marked wires on the inside of the light just the colored wires.. I was reading the other postings but I have no idea what goes to what and the instructions pretty much ****..
    Listen.. I gutted my own kitchen.. put in a new floor, dry wall, mudded the walls put in all my own appliances and cabinets, without the help of a guy.. so yes I do believe I know where the circuit breaker is.. I think I'll take it to Home Depot and have someone in electric slap it together for me... thanx for the help!!
  • iowahunter Nov 18, 2008
    got a new fran switch the old ones wires were disconnected so have no idea where they go ...its a three way switch
  • darrenc0207 Jan 25, 2009
    I have the same problem Black, purple,yellow and orange from the house and only black blue and red on the switch. I am not sure if I have the correct switch as the old one came out in pieces and was thrown out before I could match a new switch. I do know that the fan has a high, medium and low setting.
  • Glenn Rogers
    Glenn Rogers May 11, 2010
    Is this for the light assembly only?
    Regards,
    Worldvet
    Guru:
  • 859 Answers
Do you have a meter?
Worldvet
Posted on Jun 03, 2008
  • 1 more comment
  • Glenn Rogers
    Glenn Rogers Jun 03, 2008
    Are there any markings on the new switch such as L, C, G
    Worldvet
  • Glenn Rogers
    If you'll give me some time I'll look up the schematic. I believe I know what goes where but its always sensible to be accurate with electrical appliances. That's how we see it as experts. We don't have that listing by being rookies or wrong often.
    Do you at least know where and which circuit breaker controls the ceiling fan?
    And, lastly do you see a model number on the top plate of the fan or stamped inside the housing for the wiring.
    Worldvet
  • Glenn Rogers
    That would be sensible.
    Good Luck,
    Worldvet
Electrical/wiring for a pendant fixture
white - nuetral
black - zap the junk out of you positive
if you can test continuity then test for source power, check both black wires and the red. the white wire better be neutral
set your volt ohm meter to 200 VAC if you have a cheap dial one or if you have a nice auto range one, set it to AC volts and test. red to the three wires, black lead on white...
Dec 29, 2013 | Dryers
I did not make a diagram when replacing the light switch
Red from switch goes to two blacks, blue from switch goes to two blacks and the black wire goes thru top of light and attaches to blue fan light wire. If you want a good fan, look for blade pitch(13 degree or higher)Or CFM's above 5500 on high.
Oct 02, 2013 | Hampton Bay 24002 Ceiling Fan
Replacing a pull switch on an Encon fan. 4 wires. Didn't label wires before I pulled them out. Number on old switch is 1282M and 17292101 with A B C D labels. Can you tell me which wires go where? ...
I have just figured out the wiring to my Encon 5TD42WHC ceiling fan. (This is not to say your fan won't be different.) You can't use just any switch; the switches vary in operation. See the images attached. Good luck, and be careful working with AC voltages.
Dec 23, 2010 | Encon Industries (78018) Ceiling Fan
I have a black, white, red and a bare wire in the ceiling. the fan has black, white and blue wires. what goes with what
black goes to black. white goes to white. red goes to blue. there should also be a green wire attached to the fan near where the other wires come out, if you do it attaches to the bare wire
Aug 31, 2009 | Westinghouse Fans Indoor Ceiling Fans
How to wire a ceiling fan
What you need to do is take the plate off at the switch on the wall. There shoulld be black wires and white wires. Attach a resistant tester to the white wires, and connect a long wire to the other probe of the tester. then touch the long wire to one of the black wires at the ceiling. If you are lucky, you might get the right black one on the first try. If not, touch the other black one, and that should be the white wire. Have the electric off to test this. When you find which is the white, or common, read the instruction manual and see which of the brown or greenyellow is designated white. I think these colored wires are at the bottom where the lights connect. At the top of the fan should be a white, blue, black and green wire. The Black wire from the ceiling will attach to the hot black and blue for the lights of the fan. The black wire which you discover to be actually white from the switch should be connectied to the white wire of the fan at the top. The red wire sometimes is used to connect to the blue wire so that you have a switch at the wall for the light and one for the fan. That is an old way of wiring fans. Joe
Jun 27, 2009 | Hampton Bay 46056 Callaway II Ceiling Fan
Wiring/Replacing pull chain ceiling fan switch
Sounds like it to me that the netual is not there.
Mar 12, 2009 | Hampton Bay 24002 Ceiling Fan
Replacing old fan with Hunter 20763.
People find all kinds of creative ways to wire things. White wires are always supposed to be neutrals and therefore should always go with other white wires, and colored wires should always be hot and should always go with other colored wires. If you have a voltage tester you could test to see if in fact the blue wire is actually the hot and the white is actually the neutral. (test each wire to a ground). If the previous fan was wired backwards, it would not affect the operation of the fan or lights at all. But you'd probably want to make sure the new fan was wired properly. In that case connect the white from the fan to the neutral and the black and black/white to the hot.
Jan 30, 2009 | Hunter 52" Ceiling Fan With Light And...
Wall switches do not control fan
Some fans will not operate without the remote, however, I'm not sure if the Hampton Bay brand is one of these or not. Below is how you will bypass the remote if the fan will operate without the remote.
You can try disconnecting the receiver in the canopy of the van (the cover that fits snug to the ceiling) once you have shut off the power source remove the canopy and find the remote receiver.
Most likely it will be a rectangular box with white, black, and blue or red wires attached. Disconnect all wires from the receiver and lay it to the side.
Now reconnect the wires directly to the fan, white to white, black to black, if you have a red wire (or a second black wire) in the ceiling box connect it to the blue wire from the fan.
If you do not have a red wire (or second black wire) in the ceiling box, connect the black and blue wire from the fan to the single black wire in the ceiling box. This method will require you to pull the chain to operate the fan separately.
Dec 12, 2008 | Hampton Bay 52 In. White Redington...
Ceiling fan wiring
blue would be your earth.
black and white are phase and neutral.
for the wiring in your roof you need to call a local sparky. just ask which is which and connect them appropriately.
Sep 01, 2008 | Hampton Bay 24002 Ceiling Fan
Help with ceiling fan
black with black is for fan motor from swith red with red is for light fan from switch blue goes conect to black thats power for the remote white wuth white thats streat line is call comun or negative green withe green that streat conection for ground protection
Dec 26, 2007 | Hampton Bay 46175 Cameron II Plus Ceiling...
Westwind Classic Hugger Polished Brass 52" Ceiling Fan Logo
400 people viewed this question
Top Westwind Dryers Experts
Richard Roth
Richard Roth
Are you a Westwind Dryer Expert? Answer questions, earn points and help others
