Question about Maytag Dishwashers
Some dishes have particles on them and mold is showing up aroung the drain area but all water has been draining out
  • 254 Answers
Try running a small bottle of apple cidar vinegar or a can of frozen OJ thru the dishwasher without dishes in it. the citric acid will breakup the deposits.
Posted on Oct 15, 2010
What causes mould in dishwashers , cleaned it yesterday mould was thick in it what's causing this
The mold is caused by food particles not getting fully pushed through the drain hose when the dishwasher drains. The drain hose is corrugated, and bits of food particles can sometimes collect on the ridges and in the valleys of the corrugation. Given the right circumstances, this can cause a gradual buildup inside the hose, just like cholesterol in our arteries. The presence of moisture and lack of sunlight in the hose allows mold to grow on these food particles. You will want to remove the grates at the bottom or back of your dishwasher (usually removing just a couple of screws will do it) and clean with bleach water (a cup of bleach in a gallon of water) as far down as you can reach. After you have done that, replace the grate, put the rest of the bleach water in the bottom of the dishwasher and run a regular cycle (no dishes, please!). Why not just put the bleach water in and run the cycle? Because that will kill the mold, but will not remove its build-up. You want to remove the build-up first, as far as you can reach---it's easier to remove when it's live. Then kill what's left in the drain.
If your problem was serious enough, you may want to replace your drain hose, too.
Oct 17, 2011 | Dishwashers
My Kenmore Elite dishwasher did not drain the water out of the bottom after the dishes were washed last night. Could I possibly have pushed a wrong button to keep it from draining, or do I have a problem?...
Yes , If the program controller has hung it would have skipped the drain cycle. So try to redo the cycle and see if the drain works, is not check the program controller and the drain valve/pump.- if there is food particles that have clogged and blocked.
Jul 26, 2011 | Kenmore Dishwashers
My dishwasher runs through the cycle but doesn't empty. It looks like rice in the bottom when you take the filter out. Could the pump be blocked & how can I repair it. Is it possible to **** out with a...
Unfortunately it is important that the dishes are rinsed before they are placed into the dishwasher as the primary job is to get your dishes sterilized and cleaned.
So please try and remote off as much of particles by showing the dishes to the wash tap or use a wiper to clean off the food particles.
In all machines there are drains to which the drain pump is fitted and there is a filter but if the dirt level is too much the filter and also the drain pump will be clogged.
You can remove the pump and back-flush using a good spray, clean the filter by removing and flushing with brushing.
Once this is cleaned the pump must work and drain the waste water.
Mar 11, 2011 | Baumatic 23 in. BDW5 Built-in Dishwasher
We had corner soap dishes installed in our newly remodeled shower stall. But the water does not drain off just sits. The soap dish does have a small dip in the outside rim. The contractor says it is...
I have the same problem with my stone corner soap dish. It used to drain ok but recently water just sits on the dish and mold grows. Unless we get a good solution, I plan to drill holes into the dish to let it drain.
Feb 12, 2011 | Daltile Bathroom Accessories Resin Soap...
Dirty cups and baby bottles after dishwasher has been run
Hi and welcome to FixYa I am Kelly. One of the biggest causes of the symptom you describe is that there is a partial blockage of the drain. The blockage areas are most often in the "Air Gap" A device that looks like an inverted 5 oz Dixie cup on the back of the sink with no cone shape. Food particles collect in the very top of that and slow down the drain process. Because of that the dishwasher doesn't completely drain between cycles. So what you get is recycled previous cycle water in the rinse.
Other places where blockages occur are at the garbage disposal side inlet hole. And the last place is under the wash arm tower / mini riser in the pump impeller outlet area. To clean under the lower wash arm riser it requires diassembly and a good memory of how everything came apart / goes back together when your done cleaning.
Apr 18, 2010 | Kenmore 24 in. 17032 Built-in Dishwasher
Food particles left on dishes and sides of dishwasher
Check how durty your drain area is and if the water sprayer is.
Apr 05, 2010 | Kenmore 16602 / 16604 / 16609 Built-in...
Kenmore elite dishwasher leaves food particles on dishes
If someone is putting dishes in the washer and obstructing the spray ams that would cause food to stay on dishes. After loading dishwasher and pushing in baskets make sure the spray arm doesnt hit any of the dishes causing them to not clean properly. If that doesnt work or is definately not your problem try removing the spray arm and seeing if it has food inside of it. Some times they get food build up in them and need to be flushed out.
May 12, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Food particles are on dishes after washing
Try adding bicarb of soda/baking soda and vinegar in the detergent dispenser. Bicarb fizzes off hardened particles and vinegar strips off grease and aids rinsing.
Jan 26, 2009 | Maytag 24 in. PDB1420 Built-in Dishwasher
My dishwasher leaves crumbs and food particles stuck to everything in the top rack
Usually this problem is due to the fact that the dirty particle filled water isn't fully draining and the unit is trying to rinse the dishes with fouled water thus baking any leftover food particles during the dry cycle.
Make sure that all of the water is draining from the dishwasher after all drain cycles.
Usually poor draining is due to a blockage or partial blockage in the drain line,also the blockage can be at the drain pump itself or where the drain connects to the under sink drain
Dec 20, 2008 | KitchenAid Superba Architect KBCA06XPBS...
Dischwasher will not drain
Does your dishwasher run during wash cycle? then,
Check drain hose by try this, loose the clip that hold your drain hose firmly from your dishwasher side, check carefully if no debris blocked the hose connector, water suppose to come out from that connector if it does, your drain hose was blocked with debris or mold and particles like coffee seeds etc.removed them connect the hose back run the dishwasher.
If that does not solve your problem check under your dishwasher, there's a timer activated drain solenoid that opens a drain valve to drain the wash water through a hose.
Replace it.
Jul 26, 2008 | Bosch Dishwashers
Dishwashers Logo
113 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
