Question about Mitsubishi WS-55909 55" Rear Projection Television
Green blinking light problem too. on a Mitsubishi WS65869
I saw your post below and I think I have a green blinking light problem too. on a Mitsubishi WS65869. Do you have directions on how to replace these capacitors on the DM board?
You can email me at dorafred@sbcglobal.net
Thanks,
Fred
You need to replace the 1000uf capacitors on the DM board thats the classic symptom of the DM caps being bad the light continues to blink repeatedly. If you need more info on the repair let me know.
  • uacatralph Aug 31, 2008
    We had a power outage - set plugged into surge protector - now we have the blinking light!
  • Mitsubishi Master
  • 8,617 Answers
You can go to this link they have the kits with the high temp higher volt capacitors and complete detailed instructions on how to do the repair.
http://servicemanuals.vstore.ca/
Posted on Jun 03, 2008
Mitshubishi plasma tv ws65869 wont start green led on in a sec off
Not a Plasma by the model number listed.
When green power light comes on and goes off a few seconds later:
Press and hold on the front of the set both the Menu and Input (source) buttons at same time for at least five seconds and let both go.
Power light will blink a two digit error code like: 2 blinks, 2 blinks and a pause and repeat it several times.
If set has been unplugged it clears the errors and you must turn on and when power light goes out repeat.
Let me know error code found and I will help
Mar 11, 2012 | Mitsubishi Televison & Video
Mitsubishi WD-52525 with blinking green light problem
The #3 post worked for me. I first just did the capacitors and it did not work at first, but I got it reset. It worked for 2 months and lost power the other day in a storm and the blinking light came again and would not reset. I put in the switch and followed his directions and it work perfectly. Sweeet. The switch was easy. The capacitors were not hard, but very detail oriented. I work on copiers for a living, so I am used to taking things apart and back together. You must be able to solder and reassemble pretty well, or I would hire someone to do it.
Sep 16, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Have ws65869 tv
Replace the dm power board . Its inside the metal box on the left (looking at the back with the back removed). p/n 935C986002
Or if you can solder then replace the 7 electrolytic capacitors on the DM power board. value 1000uf16volt.
Jul 25, 2009 | Mitsubishi WS-65869 65" Rear Projection...
Mitsubishi wd52725 green blinking light
Haven't done anything as of yet. I saw many posts that stated it costs between 800 & 1500 to fix the problem with no guarantees on the repair or how long the repair would last. Still weighing my options.
Dec 29, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi WS55909 blinking green light
how long was it blinking. after a complete loss of power the green light will blink on power up as it is resetting itself. It says in the manual that it should take about a minute. Over the last two days I've have to reset it several time both by unplugging it and using the manual reset button and it has taken about five minutes for the blinking green light to clear.
Dec 09, 2008 | Mitsubishi WS-55909 55" Rear Projection...
Constant green blinking light Mitsubishi tv WS-65513
Unplugged my Sony for 36 hours from wall and it solved the problem
Oct 20, 2008 | Mitsubishi WS-65869 65" Rear Projection...
Blinking green light will not power up
My WS-55859, Did the same thing. Power went out, when it came back on the green light in front of TV would blink, but TV would not power on. Did some googling and saw multiple posts for "blinking Green light" or "Blinking Green light of death". Most of the posts pointed to replacing capacitors on DM Power board. I followed the direction and it worked great. Note the TV shop guy who did the soldering for me said the capacitors "looked fine" and they were not the problem. I couldn't tell the difference between a good or bad capacitor, so I asked him to swap them anyway. He did, I plugged the board back in, buttoned up the back of the TV. After 60 seconds Green light stopped and I started watching TV again... Here is the link to the best instructions I found (http://hdtvoice.com/voice/showthread.php?t=32186).
Aug 30, 2008 | Mitsubishi WS-55859 55" Rear Projection...
Help with green light blinking, HDTV integrated 1080
Check C81A2, C81A3, C81B3 and C81B4 (1000 uFD, 16V, 105C) on the DM PCB.
Check C8F19, C8F21, C8F22 and C8F27 (1000 uFD, 16V, 105C) on the FMT PCB.
If any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C).
May 19, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Mitsubishi ws65869 big screen tv
Does the LED power light come on? Have you checked the fuses?
Feb 03, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Please study the procedure at the following address.....
www.chrisandnat.com/projects/blinkingtv/blink.htm .....
use 1000mf 25v or 35v 105 degree capacitors to replace
original four 1000mf 16v..............if new ones are a little
too high,just lay them over on board........
Look it over..........let me know......................T.
Jan 07, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Open Questions:
Mitsubishi 55" big screen TV powers down after 70 secs We had a power outage in the neighborhood, after which our Mitsubishi 1080 HDTV WS-55909 only had a blinking green light on the front (no variation or pattern), even after the set was powered down. Upon reading online, it appeared the DM module capacitors were the likely culprit, so I sourced (7)1000 microfarad capacitors and replaced them, then reassembled the TV. This was the first time I'd soldered on a circuit board, so of course a lot of things might have gone wrong. However, after that the TV now powers up, but I only have a blue screen and cannot get the remote to work except to power the TV on and off (tried changing batteries in remote, reprogramming remote per setup manual, etc). Further, the TV powers off after 1 min and 15-20 seconds. I then tried to see if I could get any of the attached devices to work on their own with no other devices on except the TV. Each of them yielded a blue screen (X-Box, VCR/DVD recorder, Wii, cable) except the DVD player -- which displayed a great picture! The problem is the DVD will play 1 min 15 seconds then the TV will shut down and the green light will blink steadily (no pattern) for 60 seconds, then power down. And this only works if the DVD is on before the TV is turned on, and since the remote doesn't work I have to press "play" on the DVD player. The DVD is hooked to Component Input 2 so that input appears to be working fine. The VCR/DVD recorder is attached to Component Input 1. When I had it powered up and turned on the TV, I got a blue screen. However, when I left the VCR/DVD on and then turned on the DVD, there were jagged lines on the TV for 3-5 seconds, then the TV made a popping sound and shut off. When I then turned on the TV (i.e., with both the VCR/DVD and the DVD on first), the DVD worked but could not switch to the VCR/DVD without the TV turning off. I also tried switching the cabling for the DVD to Component Input 1, but the DVD no longer worked. When I tried the VCR/DVD on Component Input 2, it still only yielded a blue screen. So is Component Input 1 bad? And why would the TV work with the DVD in Component Input 2 but not the VCR/DVD? Obviously I have multiple problems here. The first one to deal with is the TV shutting off after 1.25 minutes. I am unable to see where I can get an error code when the blinking light just blinks quickly without any pattern, and neither the front panel controls nor the remote control work. Perhaps most of my inputs on the rear of the TV don't work now except Component Input 2 but I don't know how to test this. So I made a little headway with the capacitor replacements, but not sure what I can do at this point. Any suggestions? I've seen references for other Mitsubishi big screens that shut down like this, and the fix was related to the output power module, but not sure if it applies the the WS-55909. Thanks in advance for any help you can provide. estout7
Jun 28, 2012 | Mitsubishi WS-55909 55" Rear Projection...
See all Mitsubishi WS-55909 55" Rear Projection Television Questions
Mitsubishi WS-55909 55" Rear Projection Television Logo
229 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
