Question about Husqvarna Garden
I have a Husqvarna Model No. 6521RS Power-Propelled 21" Rotary Lawn Mower. At the end of the Drive Control Cable there is a spring. This spring broke so I had to order the part. I have received the part. however, I don't know where it attaches. Can you assist.
  • 37 Answers
SOURCE: BROKEN SPRING
Hi, check under your seat. at the frame there should be a bracket that the rod and spring goes thru and right to the pedal.
Posted on Nov 23, 2008
dgjtex
  • 405 Answers
SOURCE: I NEED BELT DIAGRAM FOR MY HUSQVARNA RIDING MOWER
http://www.usa.husqvarna.com/home.aspx try this out for your answers, I hope this helps you. MERRY CHRISTMAS!
Posted on Dec 23, 2008
  • 146 Answers
SOURCE: 609 yard machine tractor idler pulley spring broke
Here's a diagram, not a great copy, but it may help:
The spring hooks to the idler arm on the opposite end from where the pulley is mounted. The other end of the spring looks like it hooks to a raised tab on the deck, straight behind the left mower spindle. Hope this helps you, please rate my solution if so, thanks!
Posted on Jun 08, 2010
  • 640 Answers
SOURCE: Found large spring at end
There are 4 pulleys on your deck. Two for the blades, these are the big ones on the outsides. To the insides there are two, one on left side is an idler and the one on the right is a tenioning pulley that hooks to the blade engage lever throught the cable you found. Look on top of this pulley and see if it has a piece sticking up. If so the spring at the end of the cable attaches here. Slide it over. You also need to find the clip that goes through the little hole in the end that keeps it from sliding off. Make sure that the cable is properly routed and attached near the back of the deck. If it is still attached, good, if not you will have to find that pin also.
If this is helpful, please rate.
Posted on Jul 10, 2011
Testimonial: "I tracked down the problem,hooked up the cable, put the pin back in, got the blades to engage before I got your response.Thank you just the same."
  • 640 Answers
SOURCE: troy bilt self propelled 21
You should inspect the belt, this may mean that you have to remove a cover.
If really helpful, please rate.
Posted on Jul 12, 2011
Looking for repair manual for husqvarna 175cc 22 in self propelled rear wheel
Search by engine model #. If not engine problem search by mower model #+parts.
Jun 12, 2016 | Husqvarna Garden
I have a self propelled lawn mower and the the belt that propells the wheels is loose, do I need to replace it or is there a way to tighten the tension.
Cathy, there is a way to adjust belt tension on some models whether it is by the cable or a slotted bracket where the idler wheel is mounted, depends on make and model. If you have your manual check in it for belt adjustment. Could be stretched belt, stretched cable, worn/oil on pulley, seized tensioner, stretched/broken spring on tensioner,etc.
How to replace drive belt on Craftsman 22 Front wheel drive mower
How To Repair Troubleshoot Self Propelled Part Of Lawnmower HD
Fix Self Propelled Craftsman Push Mower
How to adjust drive belt on 6 75 Horsepower self propelled lawn mower...
May 23, 2016 | Garden
How do you replace a drive cable on a troy bilt push mower model 12av834q711
I am assuming you want to replace the drive cable on this mover.
You can view this in detail in this video
https://www.youtube.com/watch?v=PbwO2ygfS0k
If you need the manual you can download from this site
Manual Troybilt Rotary mower 12AV834Q711
If not then please send a comment clarifying which cable you are referring to.
Parts can be purchased from this site
http://www.searspartsdirect.com/partsdirect/part-model/Troybilt-Parts/Walk-behind-lawn-mower-Parts/Model-12AV834Q711/1307/1500600/P0601106/00002
Aug 12, 2014 | Troy Bilt 5.5hp Self Propelled Mower
MY CRAFTSMAN 6.75 HORSEPOWER 21" MULTI-CUT POWER PROPELLED ROTARY LAWN MOWER MODEL NO. 917.377972 WILL NOT START AND RUN . STARTS THEN QUITS HAVE TRIED EVERYTHING IT HAS BEEN A SHOP LAST TWO YEARS HE CAN...
If the carb is new, then make sure the fuel is fresh- LESS THAN 30 DAYS OLD!!! Is the plug good? Air filter OK? Good oil in the engine? Make sure that the shut off cable hasn't stretched. It may make contact and shut off the engine.
May 20, 2014 | Mtd 22" Yard Machine Push Mower
How to attach drive cable 406259 on husqvarna model 917.376820
This is hard to explain over a computer. I found a diagram of your make and model. I would try using a long end needle nose pliers to attach spring. I hope this helps. Good luck!
Dec 07, 2013 | Husqvarna 7021R 21-Inch 160cc Honda GCV160...
How do I install part no.183281 ( engine zone control cable ) onto a craftsman rotary lawn mower model no. 944.366362 ?
Hi Robert,
I'm not usually a Lawn Mower Expert, but I think I may have an answer for you. Assuming your craftsman rotary lawn mower is similar to this self propelled craftsman mower (they should have the same basic parts), this video should help!
Self-Propelled Craftsman Lawnmower Drive Cable Repair
Sep 05, 2013 | Garden
Cable broke on self propelled 7021r. Is this easy to replace?
Here's a diagram of the mower, I not familiar with the Husqvarna lawnmowers but have replaced many cables from other brands of mowers, should be simple with some basic tools.
http://www.partstree.com/parts/?lc=husqvarna&mn=7021+R+%2896143004600%29+%282009-01%29&dn=90_25_0003
Sep 04, 2011 | Husqvarna 21" Lawn Mower with Honda GCV160...
MTD front wheel drive self-propelled 21". Self-propelled does not work. Can it be fixed?
Yes it can be fixed. Try some basics first.
1) Check under belt drive cover for excess debris
2) Belt and Idler pulley condition
3) Control cable operation
a) rusted, frozen, broken, disconnected
Dec 03, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Garden Logo
151 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
