Question about GE (PSS26MSRSS) Side by Side Refrigerator
GE Side By Side Stopped Working
I have a side by side GE-Artica. All the sudden it stopped cooling. the cool/warm numbers on the top of the fridge inside dont show up anymore. I took the thermostat off and it cools. The fridge runs just fine. Then i checked the thermostat with a digital multimeter and it seems to be fine. Shows that it has ohms. What could be the problem?
  • 54 Answers
Either a bad interface\display board or a bad main computer. I would try the main computer first.
Posted on Jul 03, 2008
GE frig not cooling, both refrig and freezer. started with ice/water dispenser not working.
WR55X10942 Main Control Board This sounds like motherboard failure. I am not sure what your model number is but that will be important should you have someone to help repair your refrigerator. These problems are common on the Artica Profile Models. I will be here to help you repair if you should choose, Thanks Sea Breeze
Apr 24, 2013 | GE Refrigerators
I have a ge refridgerator gss25k side by side. thefridge/freezer are not cooling. the bottom of the fridge freezes and the top is warm.
There is an air duct that connects the fridge to the freezer. A fan circulates air to cool the refrigerator.
The inside fan has stopped working or is blocked by ice.
Defrost the freezer. If the fridge starts to work properly then you have an auto defrost problem. If the fridge still does not work then there is a faulty fan.
A technician can help you there
Apr 03, 2011 | GE GSS25KGMBB / GSS25KGMWW / GSS25KGMCC...
GSS25KGMB CC side by side GE fridge not cool.
You should check first to see if the condenser coil is dirty ( condenser coil is the Fin type coil you see in front of the compressor ) You can clean this by just brushing it out with a brush .The relay is plugged directly onto the compressor
May 17, 2017 | GE GSS25KGMBB / GSS25KGMWW / GSS25KGMCC...
The main control board is going bad . This is the electronic board behind the 8 x 10 inch panel , on the back of the refrig . Your relay on the compressor is ok .
Feb 20, 2010 | GE Refrigerators
Making a clicking noise and not cooling
This could be a relay on the control board or the compressor is short cycling or both. You can use my assistance to help you resolve this or call a technician, this depends on you. I am very familiar with the Artica/Profile and know that if you can follow instructions and use a test meter we can get this fixed. I would like your complete model number so I can refer to the exact model you have. I will leave you contact information and a service manual and a web page to use with the diagnostics. This problem will not get better, Sea Breeze
Jan 26, 2010 | GE Profile Arctica Stainless Steel Top...
GE profile TFHW22R side-by-side fridge compressor issue
Most times replacing the start relay part=> WR07X1001 start capacitor=> WR62X80 and overload=> WR8X97 will resolve the problem. Click here to downlod the Service Manual=>PROFILE ARTICA SERVICE MANUAL CLICK HERE and go to this page to use he Tech Sheet> GE Artica Profile Technical Information If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, Thanks, Sea Breeze
Jan 26, 2010 | GE Refrigerators
Freezer is frozen fridge is warm
Your model is most likely the Profile Artica style. Most times the defrost heater is burned out behind the rear of the freezer wall. Manually defrost and look at the defrost heater to see if burned out. That model possibly has the glass covered defrost heater and will be easy to spot if burned out because the element is inside a glass tube, If you replace the defrost heater also replace the defrost thermostat, Please send me your model number located near floor of the fresh food compartment door seal and kick plate, Thanks Sea Breeze
Oct 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice dispenser will only dispense crushed ice
Ihave zannusi ZX99/5SI fridge freezer. Top-freezer compartment is not cooling. I have done as before, defrosted and cleaned both fridge and freezer but, with no luck. Freezer is working OK but top-fridge  is not cooling. Could you please help with advice in what to de next.
Thank you
May 12, 2009 | GE Monogram® ZISS420DMSS Side by Side...
GE PCG23NHMF side by side fridge freezer - stopped cooling
Although this machine is supposed to be frost-free (i.e. automatic defrost), there was a build up of frost. We manually defrosted the machine, then restarted it - the noise has stopped and the freezer and fridge are now working. However, this may be a temporary solution.
Jan 18, 2009 | GE GSS25LGM Side by Side Refrigerator
Does not stop cooling down
Door edges being warm is caused by what is called mullion heaters that operate to prevent humidity from condensing at these points.
Some refrigerators have an energy saver switch. Turn this switch if you have one to the energy saving position when the humidity is low. Is anything freezing in the refrigerator? If so setting the controls to a little higher setting may solve your problem.
May 03, 2008 | GE Profile¿ Arctica® Energy...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
103 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
