Question about Sony Playstation 3 (PS3) Console
When I turn the PS3 on the green light goes on and then in a few seconds it turns to like yellow for like second and the flashes in red...
  • 104 Answers
If the yellow light comes on when you turn on your ps3 then you have yellow light of death. This is bad because it means your ps3 has over heated and the chips have lost connection with the board. So to be able to play it (3 options) you would have to get a new one (what i did), fix your ps3(VERY HARD) You have to have lots of tools but you can do this if you search around for a guide cause i do not know how to and its very hard (im sorry) or (Easy but COSTLY) sending it to sony for 150$ repair. Sony's repair is garented because i know for a fact that they have a big exspensive machine that does it for them but you will get a new hard drive which means lets start all over. Im sorry for your loss
Good Luck and Happy Gaming-Koscoe
Posted on Oct 16, 2010
I turn on my ps 3 and it goes green light then after about 3 seconds goes yellow then red.
when i turn ps3 on it flashes a yellow light then the green light comes on it dunt come up on screen and it wont turn off or eject disks
Dec 23, 2010 | Sony Playstation 3 (PS3) Console
After pressing the on button it turns green for 5 seconds then it flashes yellow/orange for a second then it flashes red.
Yellow Light of DeathThe "Yellow Light of Death" or YLOD is the common phrase people use to describe the following sequence when they try to turn on their PS3:
  • Press Power Button
  • Red Light Flashes Three Times
  • Yellow Light Flashes
  • Green Light Flashes
  • Beeps Three Times
  • Red Light Flashes
The sequence above may vary a bit but you do see the flashing yellow light (sometimes shows up as orange) that normally you would not see when operating your PS3. The YLOD is a general hardware fault that can mean a lot of things. However, one of the problems is cracked solder that leads the PS3 to think one of its internal chips is not connected or is broken somehow. Cracked solder can happen when the chips get too hot (RSX most likely) and leads the motherboard to start bending, which may crack the solder. Changing the power supply (lower the average wattage going to the chips to lower the heat) and better thermal compound (heat dissipates faster to the heatsink) may prevent this error from occurring. However, if your PS3 has already had the YLOD, then you can reflow your motherboard every few months to keep it working (but it is not a permanent fix as the YLOD usually comes back).
Oct 09, 2010 | Sony Playstation 3 (PS3) Console
Ps3 will not turn on properly
You are so lucky to be there. I share a guide for you - It make me like a pro to help my friends and many people. It is too expensive to send back to Sony repair if your machine is out of warranty!
I had solved the PS3 yellow / red lights flashing problems after bought this guide. It's Video and Guides are really catch your eyes and fixed many PS3 issues ! The author of the book is really kind and helpful to his customers. May be you can buy it and share what you have learned !
PS3 Yellow Lights Fixing Guide
May 30, 2010 | Sony Playstation 3 (PS3) Console
Ps3 does not turn ON
looks like the YLOD, you can search some fixes of refloating the solder with a heat gun or take it to a repair shop. lastly and most expensive is sending it into sony assuming its out of warranty if it is its 150 to fix it. If still under warranty then call them asap.
Apr 28, 2010 | Sony Playstation 3 (PS3) Console
My playstation has the light trun green yellow flashing red light
With your PS3 turned off, press and hold the Power button on the front of the PS3 for about 10 seconds (the system will beep as normal as it starts up but after 7-10 seconds it will beep again). The video settings should now be reverted. Doing this will also reset any theme settings. try this? seems to fix alot of issues.
Jan 22, 2010 | Sony PlayStation® 3 (80GB) Console
I have a philips dlp 55pl9773 has one red flashing led on the front when i do a hard reset tv boots up lamps lites led goes from flashing yellow to green for about ten seconds and then back to red flashing...
MY philips tv model number 55PL9773/17 WAS TURNING OFF THE SCREEN AND LEAVING THE AUDIO ON FOR ONE MINUTE. THEN THE YELLOW LIGHT STAYED ON. THEN THE LIGHT TURNED OFF. thEN I TURNED ON WITH THE REMOTE AND THE YELLOW LIGHT TURNED ON AND A FEW SECONDS LATER CHANGED TO THE GREEN LIGHT AND THE TV TURNED ON. AFTER A FEW MINUTES, BETWEEN 10 AND 30 IT DID THE SAME THING. NOW IT IS OFF WITH A BLINKING RED LIGHT PERMANENTLY ON. TO TURN IT OFF I HAVE TO UNPLUG IT FROM THE WALL. I REPLACE THE LAMP A FEW WEEKS AGO AND IT IS FINE.
Dec 01, 2009 | Philips 55PL9773 55" Rear Projection...
Try to turn on ps3 green light comes on for a second then yellow ligt starts flashing then goes to a flashing red light?
they yellow light means a system fail. i found a website that will fix it and in a short amount of time and save your data. www.videogame911.com
Oct 26, 2009 | Sony Playstation 3 (PS3) Console
PS3 light turns GREEN, w/ blinkin BLUE, to YELLOW, to flashin RED
it is fried and needs repairs if you break the seal by trying it yourself you void the warrany
Mar 15, 2009 | Sony Playstation 3 40GB System Console
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
