Question about Refrigerators
I have frost free hotpoint future,the fridge seems to be working but the freezer isnt at the minute, the food is not freezing and the fan does not seem to be working! it has no suction on doors either, my guarantee is finished and im at my wits end as i cannot afford to buy a brand new freezer, please can you help? thanks Carly.
  • Refrigerators Master
  • 43,501 Answers
Defrost timer/control is sticking...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101.
Posted on Oct 17, 2010
I have a hotpoint freezer fza34 The red high temp
it could be that your fridge,freezer setting is not turned up high enough to keep the freezer cold enough.turn it up to setting number 5 at least and if that dont do it u could have a faulty thermostat.have it checked by a engineer.
Oct 30, 2013 | Freezers
My freezer isnt working correctly ,isnt freezing the food and the fan only kicks in now and again and there is ice at the back of the freezer .can you help
It seems that the efficiency of the fridge has dropped as there is frost forming within the system due to a possible failure in the control circuit or the auto defrost timer.
It can also be related to a failure of the circulation fan or the thermostat.
Shut off fridge for about 6 hours and if it cools then the defrost timer must be checked along with the heaters.
Aug 02, 2011 | Beko TLDA662
Frosting up badly despite having just been defrosted
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for cold control and air deflector As you know, the deflector directs the freezer air toward the front of the frig and the rear of the cold control.
Hope this helpout.....
Aug 08, 2010 | Hotpoint 4.87 cu. ft. / 138 liter Upright...
Hi i have a hotpoint mistral plus fridge freezer, the freezer working fine however the fridge not getting cold, i have checked in back and the fan not working, have checked the fuse that is fine. 1) Does...
hi is this the frost free version ??? if it is which i think it is it could be a fault with temp module{frost free have electronic modules to control the system rather than a old fashioned bog standard thermostat inside the fridge} the fans should be controlled by the module in case of frost free models it could be the module which is playing up
Jul 23, 2009 | Refrigerators
Refrigerator is freezing everything top to bottom wondering if there is an air filter that I could clean as we have had some drywall done recently and thought maybe something is restricting air flow.
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
  36. Some help for an Amana refrigerator fan motor that will not run
  37. Will my freezer or refrigerator work ok in my garage?
  38. Whirlpool built refrigerator defrost timer installation help
  39. Water line "Y" hose for icemaker broken helps
Apr 01, 2009 | GE Profile PSW26P Stainless Steel Side by...
Fridge freezer not working after power cut
if its a ge i would say itsyour main board not compressor boards about 200
Mar 19, 2009 | Refrigerators
We have a bosch air flow fridge freezer
It's stopped completely
It's not cool
Cooling is poor
It's noisy
It leaks
The freezer compartment is icing up
The food in the refrigerator freezes
There's water dripping inside the refrigerator
The refrigerator never cycles off
The ice maker has a problem
There's an ice- or water-dispensing problem
Mar 14, 2009 | Bosch Refrigerators
Freezer side works fridge side doesnt
    click on the required option.
Feb 20, 2009 | Kenmore Refrigerators
Food is defrosting in my hotpoint frost free fridge/freezer
Can you hear the compressor running? Is the fan inside the freezer running? It could be that a wire connection has come loose during the move. Was the fridge laid on it's side during the move? If so you probably have compressor oil restricting the refrigerant system. If compressor and fan are running you will probably need a qualified refrigeration tech to check it out.
Oct 03, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
Refrigerators Logo
169 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
