My pedal hi-hat on my td-6 drum kit volume is too low, almost unhearable. I tried to raise the volume but it changes with the Hi-hat itself which is okay. Is it the module or pedal which is troublesome. Salesman says it's normal to be so low. Thanks for your help.
  • 1,512 Answers
Hi yvnadeau
I just checked out some youtube footage here.
about 1:30, and 2.40, and 3:40 the dood does some time on the HH . Check it out, does your kit sound like this guys. No probs here with the hats. They sound well in the mix to me.
regards
robotek
www.myspace.com/gruntmachine
Posted on Jun 03, 2008
Dtxpress ii
Open pedal, check with Ohm Meter when you open/close it at the connector.
Fix.
Sep 27, 2017 | Yamaha Dtxpress Iv Special Electronic Drum...
Hi-hat is triggring sound while in the closed position. and splash can't be produced
Check the following on a VH-11 HiHat.... both cables connected correctly, top playing surface is clear of the inner ring on the lower sensor when in the fully up position, power the module OFF, keep sticks & foot well clear of the HiHat then power ON, finally check the calibration settings (I assume the 15 has that as my TD12 does) If still nogo check on the VDrums forum website....
Oct 23, 2013 | Roland V-drums Td-15kv V-tour Set...
Hi. I've got a problem with my hit hat controller with my Yamaha DTXPRESS III special. It is still opened, even if I strongly push on the pedal. But, when I half plug the jack in the hit hat controller it...
Sounds like the internal switch in your pedal.
Get an OHM meter, and check the continuity when you press and release pedal. Should change from Open to Short.
If not, take it to a Tech.
Nov 08, 2017 | Yamaha Dtxpress Iv Special Electronic Drum...
Alesis dm6 bass pedal
There's a tiny switch on the back of the module "kick type" try switching that
Sep 22, 2012 | Alesis DM6 Electronic Drum Set
Foot peddle does not work with drum set
What drum kit are you using? If you are playing Rock Band 3, you may want to check the drum options to see if the Enable Hi-Hat option is selected and change it. This can cause problems with the pedal.
Also make sure you have the pedal plugged fully into the kit and that the rest of the pas on the kit are working.
Mar 09, 2011 | Rock Band Video Game Consoles & Games
I have a problems with my HI-HAT control. When I put a pedal for HI HAT controler down, you can play HI HAT, but in the next 20 second the pedal not choke HI HAT cimbal...What can i do? Thanks
Verify that the pedal is the CORRECT type for what you are using it for.
Pedals came in MANY varieties. I would ask the store where you got the items about it.
Pedals can be switch type either normally open or closed, Variable resistance/volume control, pulse type like the kick drum pedals that generate a varying trigger pulse...
Jul 23, 2010 | Yamaha Dtxpress Iv Special Electronic Drum...
Hi Hat pedal not fuctioning
Obviously the hi hat trigger does not function properly, it either does not generate enough signal, or the signal doesn't come thru well, or the signal comes thru well but it doesn't trigger the sound unit properly.
This could be caused by:
- too low input sensitivity setting on the sound unit for the hi hat input
- a displaced or loosely fixed sensor (trigger) on the hi hat
- a partially damaged sensor
- a bad wire connection at the sensor
- a bad wire connection at the sensor connector
- a dirty contact on the sensor connector
- a dirty contact on the cable connector at either side of the cable
- a bad cable, a broken wire or poorly soldered wire in the cable connector at either side of the cable
- a dirty contact on the input connector of the sound unit
- a bad solder connection on the input connector of the sound unit (inside the unit)
- a bad solder contact on a component or a faulty component associated to that particular input in the sound unit (capacitors, resistors, diodes, transistors, ICs, etc.)
To rule out a damaged cable, just change it and see if the hi hat works ok with another cable, if it does, the cable was damaged.
If the sensors are interchangeable , try to swap the sensor with a sensor from another cymbal, see if the other sensor works well, if it doesn't, then the sensors are not the problem.
To see if there is a problem with the input on the sound unit, connect another cymbal to that input, if it works well, the input is not the problem, if it still doesn't work, check sensitivity/trigger level setting, check connector contacts for any dirt, check connector and component solder contacts inside the unit.
Also, try to connect the hi hat to another input on the sound unit, if it doesn't work well after that, there's a problem with your hi hat (sensor, wires, dirty connector on the sensor), if it works well instead, then there's a problem with the hi hat input on the sound unit (sensitivity/trigger level, dirty connector contacts, bad solder contacts, damaged components)
Another thing: try your hi hat connected as is, but have someone move the cable connectors while you play it.
If moving the cable connector at the sensor side results in a change of operation (it might start working well for an instant or so), you definitely have a problem with that connection (check for bad wires in sensor connector, cable connector and for dirt on both connectors' pins).
If moving the cable connector at the sound unit input side results in a change of operation, then there's a problem with that connection (check for bad solder points on the input connector inside the sound unit, check for bad wires in cable connector, check for dirt on both connectors' pins).
I hope you can fix it, otherwise just post me some feedback if anything seems unclear, i'll be glad to assist you.
regards
3rq8 (Triarcuate)
Aug 04, 2009 | Yamaha Dtxpress Iv Special Electronic Drum...
DTXpress III Special Yamaha Drum Kit - high hat won't sound closed
solution!! you go to "voice" hit the hihat pedal, then press "page" till you get to hhat ofset and bring the value to negative. approx -25. pressure that you applied to hhat pedal becomes less
Sep 19, 2008 | Yamaha Dtxpress Iv Special Electronic Drum...
49 people viewed this question
 Grubhead
Grubhead
