Question about Video Game Consoles & Games
Gamepad I have brought a gamepad of Quantum but it is not working ,it is having a USB port, when I put it in the port it doesnot works ,I also went to game controller but it says the device is not connected, kindly tell me the solution?
  • bhaskarcu Nov 16, 2008
    I have installed the drivers using the CD that came with this product. But still the gamepad doesn't work. A light glows on the gamepad when a button 'Analog' is switched, that means the power is getting passed in to gamepad. I don't know how to make this work? Can someone help me? Thanks. --Uday
  • Anonymous Dec 07, 2008
    my gamepad is working fine but its right & left joystics are not working
    if any one has a slution for this please mail me on reaperdonner@yahoo.com
Most likely you dont ahve the right drivers or are putting it in the wrong USB port.Try looking for drivers for it.Maybe your PSU Unit doesn't have enough power.
Posted on Jun 03, 2008
Testimonial: "the solution has really solved my problem"
Hi my quantum usb double vibration gamepad QHM 7468-2V was working till recently. but lately its not working. the dell laptop i am using is detecting it as a usb device but says it as a unknown...
Brother i have the same kind but its not vibrating, can u lease tell me what should i do.?. please mail me the drivers CD if u have it.. plzzz help me brother...
Dec 31, 2010 | Computers & Internet
IS QUANTUM USB GAMEPAD QHM 7468-2V COMPATIBLE WITH WINDOWS VISTA INSTALLED 2 YEARS AGO
plzzz brother help me, i have the same contrller and i have lost the driver CD... can u please mail me the driver CD on my email address.. see if u can Zip the copy of the CD and mail me on my email. access2avi@gmail.com
Sep 13, 2010 | IGN Entertainment (G60306A) Game Pad
My logitec dual action controllers fail intermittently
Yup, the USB connection is not secure. Its either your gamepad's wire or your PC's USB port itself. Try using other USB ports. If still the same problem you might have to buy a new gamepad.
Mar 13, 2010 | Logitech Dual Action Gamepad...
I have a Twin USB Vibration Gamepad i need the driver for Windows 7
there is no driver for windows 7 as sitek (the chinese manufacturer of the device that sells it as in "white box license" for others to print its logo on discontinued such a device since 2005. Mind you sitek.com itself has vanished and a new firm has taken over that address.
Thus end of story , problem on relaying on a small time manufacturor , however i do have the xp drivers and they do work , windows 7 would not accept them and insists that the generic driver it uses is up to date (which works fine except the vibration a.k.a force-feed-back wont work)
I am working on a new uproach on injecting the xp driver into windows 7 registry and if it works i'll let you know :)
Mar 05, 2010 | Genius G-12U Vibration, USB, PC gamepad....
Gamepad to usb adapters?
The adapter is out there. I happened upon one a while back, and got a nice joystick to work with it (win2k).
I can't seem to get my gamepad pro grip to work though. I think I may have bad controllers.
Jun 25, 2009 | Gravis GamePad Pro Game Pad
Problem with gamepad
For checking its full functionality follow the procedure. Go to: ->control panel ->game controllers There u can see USB GAME CONTROLLERS or some name. Select the controller & go to its properties. 1.) on the test tab check all the buttons 2.)On calibration tab check joystick - x/x 3.)on effect tab check the vibration .  Don't spoil the settings of program tab. If any problem persists contact me. pls vote me. thank you
Feb 03, 2009 | Video Game Consoles & Games
Gigaware controller on vista
You don't (and can't) disable DEP for the controller (a gamepad controller isn't an application, it's a device which uses a driver, Data Execution Protection applies to applications ie .exe files), it's the game or emulator you disable DEP for, so that you the game can run, completely free of security bindings, and then you would be able to go into the game configuration menu and select your gamepad, and calibrate it. Calibrating means the game detects you gamepad and applies the specific functions to each button.
One way to be sure is to disable DEP for everything, then install a game, and THEN plug in your gamepad. Then start the game/emulator and go to the configuration menu within the game/emulator and set up the gamepad calibration in there.
If it doesn't work, then you haven't installed the drivers for the gamepad properly, or haven't installed the correct driver.
Before doing any of that, you would have checked in Control Panel and Gamepad Controllers, double clicked the Gamepad in the list and pressed Calibrate, to enable generic gamepad functionality.
If you hadn't done that, do so now.
If it still doesn't work, then NOW disable the DEP (either all DEP or for the game/emulator you want to play). Unplug the Gamepad and load up a game. Then plug the game pad in. Set up the gamepad from within the game/emulator config menu, which differs from game to game, of course, but is more or less the same.
If it doesn't work.. re-install the correct driver for the gamepad.
Also make sure your operating system is fully updated and you're plugging the gamepad into a usb2.0 port. and have rebooted after installing the gamepad usb driver.
That's everything you need to know..
Good Luck!
Chris (ziraffa)
Dec 27, 2008 | Video Game Consoles & Games
LOGITECH PRECISION USB GAMEPAD
It may sometimes work without drivers, but its recommended that you download the drivers and have them installed. That way you can also program the buttons for various functions if you want...
Cheers!
Apr 14, 2008 | Logitech Precision USB Gamepad PC Game...
Video Game Consoles & Games Logo
529 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
