Question about Bionaire BDQ24 Quietech Dehumidifier
Unit running normally but no water being collected
  • 10,515 Answers
The coils in the dehumidifier are probably plugged up they may look clean on the outside but they are probably full of dust and other debris. You will need to get a coil cleaner or some kind no rinse degrease to use on the coil as I don't think it would be wise to try and spray water in it. The coil that is plugged would be the one toward the front of the machine that has the fins that are real tight and close together the round one on the back should be easy to clean with compressed air.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 15, 2010
How do i fix it so that it will collect water?
1st ck that your humidistat is set correcly and unit cycles the compressor on/off correctly ,Not just the cirulation fan running all the time , next ck your filters , clogged up filters wont allow air to pull thru unit , also are you sure room has enough moisture in it to pull water from, Most units wont draw a percievable amount of water out of air thats got less than 52%rh , as most homes target a 70%rH as normal
Dec 18, 2014 | Dehumidifiers
The unit still makes a running noise but seems to collect no water. this unit is about 4 years old but stopped collecting water about 2 years after purchase
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Aug 30, 2011 | Whirlpool Gold AD70USS 70 Pint Per Day...
Unit appears to operate normally, but does not produce water
heatman101
Apr 18, 2011 | Whirlpool Dehumidifiers
It is not producing water, it runs but no water is collecting in pan.
First, make sure the humidistat isn't set too high by adjusting it to the lowest humidity setting and running it again.
Next, test the dehumidifier by placing it in a closed bathroom with a hot shower running. If you don't see water collecting in the unit after several minutes, turn the unit off and clean all dehumidifier filters and coils. If, after adjusting the settings and cleaning the unit, you still don't see water collecting, you may have a refrigeration issue.
This situation will have to be addressed by a qualified technician.
Take care.
Aug 19, 2010 | Whirlpool AD25BBK Dehumidifier
It runs it just doesn't collect any water. Not even a drip.
First, make sure the humidistat isn't set too high by adjusting it to the lowest humidity setting and running it again. Next, test the dehumidifier by placing it in a closed bathroom with a hot shower running. If you don't see water collecting in the unit after several minutes, turn the unit off and clean all dehumidifier filters and coils. If, after adjusting the settings and cleaning the unit, you still don't see water collecting, you may have a refrigeration issue. This situation will have to be addressed by a qualified technician.
Take care.
Aug 15, 2010 | Whirlpool AD25BBR Dehumidifier
My dehumidifier is running but not collecting any water. I have cleaned the filter and it still wont collect water. Is it broken?
Good luck.
Aug 15, 2010 | LG Dehumidifiers
Unit not collecting water
Good luck.
May 15, 2010 | Soleus CFM-40 Dehumidifier
Haier dehumidifier will turn on but does not collect water.
hello. If your dehumidifier doesn't seem to run often but the humidity in the room is high, try adjusting the humidistat control on the dehumidifier to a dryer setting. If the dehumidifier seems to run constantly, but there's little or no water in the container, there may be a problem in the refrigeration system. Try cleaning the unit. If that doesn't work, you can't repair the refrigeration system yourself, you need a qualified appliance repair technician to do that.
Apr 14, 2010 | Haier HD656E Dehumidifier
Oil inside the water collection res
the compressor runs in oil. suspect you have a quite bad leak and loss all the gas - hence no water collection and the compressor oil is being pumped out thro the leak
Jun 26, 2008 | Whirlpool AD25BBK Dehumidifier
Unit Runs (fan and condenser) but no water?
By condenser I assume you mean the compressor is running. Is there ice forming on the front coil?
Jan 08, 2008 | Comfort-Aire BHD-651 Dehumidifier
Bionaire BDQ24 Quietech Dehumidifier Logo
118 people viewed this question
Top Bionaire Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Bionaire Dehumidifier Expert? Answer questions, earn points and help others
