Question about HP Color LaserJet 2600n Printer
My jobs are not printing
Hi & Thank You ! Her's my problem. My Hp 2600n Color Laserjet is not printing. It has all 4 brand new hp ink carts. & I wonder why when i right click & open it, it says test page has been sent, & that it is printing, but never prints & so i have to cancel then even deleting takes abit.... can u help a girl out thanks
    Master:
  • 638 Answers
  1. FIRST TRY TO CANCEL ALL THE PENDING DOCUMENTS WHICH YOU HAVE GIVEN BEFORE THEN TRY TO PRINT IF THIS DOES NOT WORK THEN TRY OTHER OPTION GIVEN BELOW.
  2. THERE MAY BE THE PROBLEM WITH USB DRIVERS IN UR PC .
  3. TO RECTIFY --- RIGHT CLICK THE MY COMPUTER ICON
  4. CLICK PROPERTIES AND THEN CLICK HARDWARE N GO TO DEVICE MANAGER
  5. UNINSTALL ALL USB PORTS AND THEN SCAN FOR HARD WARE CHANGES
  6. UR PC WILL DETECT UR PRINTER N ASK FOR PRINTER DRIVERS
  7. RELOAD DRIVERS N UR PC WILL COMMNICATE WITH UR PRINTER.
  8. FOR FURTHER ASSISTANCE FEEL FREE TO ASK AND WISH U SUCCESS -BYE
Posted on Jun 03, 2008
My HP Color LaserJet 2600n is printing with small black dots on the left side of the paper. The toner and ink was recently replaced. Is there a plausible reason for this? Thank you!
Could be toner build-up on the fuser sleeve. Pull out the fuser and check the rollers for spots.
Try running cleaning pages before replacing fuser.
Jul 28, 2011 | HP Color LaserJet 2600n Printer
Will not print blue? HP 2600
SPACILLY FOR HP PRINTERS DONT USE THE REFIL CART
this problem due to refill cart replace with new one ur problem will be resolved
Jul 01, 2010 | HP Color LaserJet 2600n Printer
Color ink cartridges empty, printer wont continue to print
select print black only from the print or page set-up.
Mar 30, 2009 | HP Color LaserJet 2600n Printer
Print colors
You might want to run a cleaning page through it. This uses up more ink that a typical print job, but it will allow you to clean the heads and force ink through them.
Feb 14, 2009 | HP PSC 2110 All-In-One InkJet Printer
HP 2600n will not except print jobs.
just reset the printer to factory settings , use the menu to find factory settings .
Feb 03, 2009 | HP Color LaserJet 2600n Printer
2600n prints greenish little reds
i have priner hp laser jet 2600n but it is printing very low any pic if i print it is come very low color i changed toner cart but still same problem.
Sep 03, 2008 | HP Color LaserJet 2600n Printer
Black blocked by magenta
One ovbious option would be to have a friend print it out.
I assume that is not an option.
Some printers just won't let you print if a single color is out. Yes, stupid. Try printing a blank page. If it fails, there is no other option but to replace the cartridge or print elsewhere.
If the blank page test works, this next option/test is worth a try...
Depending on the app you are using, you can specify the color breakdown of the colors you are using. In your case, it is possible that the text is set to a rich black (4-color) rather than just black.
If that is the case, to test this most quickly, make a new file, and create a new black (black2), set to 100 black, 0% other colors.
Type a wor and set it to print in that color and try to print it.
If that works, apply the same technique to your real document.
Hope it works. I've been stuck in the same situation, and some printers will just not let you print if a single color is out.
Good luck.
DigiChick
Jun 09, 2008 | HP Color LaserJet 2600n Printer
In printing a black shed all the paper
May 18, 2008 | HP Color LaserJet 2600n Printer
HP 2605dn laser - color fading
HP has a list of troubleshooting steps you can go through for the HP 2605dn when you experience print quality issues.
Two specific things I would try from that list are:
  1. Clean the electrostatic transfer belt.
  2. Clean the printer paper path.
Good Luck!
*If you find the solution helpful, please rate it!*
May 15, 2008 | HP Color LaserJet 2600n Printer
Hp 2600n color printing problem
are you using orgnial hp cartridge if not check that it may cause due to that. check the black sheet fro color spreading , if there is any color pls clean that.........
Thank you
Feb 19, 2008 | HP Color LaserJet 2600n Printer
HP Color LaserJet 2600n Printer Logo
Ben Johnson
