Question about Philips gemini TT-01 Turntable
Hi how do you remove platter on a Phillips AF 620 turntable? Cheers Tony
How to remove Platter on JVC L-A120 Turntable
Hi Jeff...
The platter on the JVC LA-10 does not come off as most turntable platters do. It is attached to the spindle with a Philips head screw.
Here are the steps:
Remove dust cover from turntable. Unscrew hinges and lift.
00.jpg" alt="Remove dustcover at hinges.">Remove dustcover at hinges.
  • Secure tonearm to prevent stylus damage.
    00.jpg" alt="Secure the tonearm.">Secure the tonearm.
  • Remove slipmat from platter.
    00.jpg" alt="Remove slipmat.">Remove slipmat.
  • Turn the turntable on its side and remove screws that hold the top to its base. Remove platter by unscrewing the bottom plate from the turntable. The spindle bearing is held in place with a Philips head screw. Loosen it and the platter will separate easily from the spindle.
    00.jpg" alt="Separate the spindle from the platter by loosening with a Philips head screwdriver.">Separate the spindle from the platter by loosening with a Philips head screwdriver.
  • Loop replacement band around the pulley cylinder in the motor. Replace platter and bottom plate. Tighten spindle screw. Test the new belt by turning the platter clockwise two or three rotations. Belt should fit snugly and turn with little resistance.
    00.jpg" alt="Test the replacement belt by turning the platter clockwise.">Test the replacement belt by turning the platter clockwise.
  • Feb 05, 2016 | JVC Audio Players & Recorders
    Why won't the turntable turn on panasonic NNA883W
    Hi, it is likely the belt has come off. Remove platter to check. Cheers john. Stylus City
    Jun 06, 2014 | Technics SL-1210 Turntable
    Fuse location of technics SL 1200M3 turntable
    Hi, you need to remove the platter and then unscrew the under platter cover to access fuses. Cheers john, Stylus City
    Apr 01, 2014 | Technics SL-1200M3D Turntable
    Turntable will not start.but the arm moves
    Hi, belt is likely off. Remove platter and check.Cheers john.
    Apr 08, 2013 | Audio Players & Recorders
    Power is on, turntable won't turn
    Hi, sounds like the belt was not refitted when the motor was replaced.
    To replace drive belt on a Crosley turntable.
    1. Remove the cir-clip holding the platter in place from the base of the centre spindle.
    2. Lift the platter off. You may need to use a flat blade or some similar tool to get under the platter in order to lift it up.
    3. NA.
    4. Place the belt around the platter pulley making sure it is sitting flat without any twists.
    5. Flip platter over the right way up
    6. You will see 3 rubber grommets in the platter surface. Remove 1. Through the hole insert a belt hook, crochet hook, kebab skewer, knitting needle type tool and slip it
    between the platter pulley and belt in readiness to fit over the motor pulley.
    Nov 15, 2011 | Crosley CR249TA Turntable
    I require a drive belt for a NEC P325E turntable. What size and type do I require, and where can I purchase one.
    Hi, I will be able to supply aa new drive belt for your turntable. To determine the length remove platter and on the underside is the platter pulley where the belt runs. If you tell me the diameter of the pulley I can work it out from there. Cheers John. Styluscity@gmail.com
    Jul 29, 2011 | Audio Players & Recorders
    Turntable has stoped.The belt has come off but still intact.Where doe's it go. Cheers
    The belt goes from the turntable's platter to a rotating cylinder that fits under the platter. There should be a hole in the platter to access this rotating cylinder.
    Apr 30, 2011 | Crosley CR249TA Turntable
    Technics sl 1210 will not start up
    did you ever open the turntable. It sounds like the on/off switch is bad. Remove the platter and screws with a phillips screw driver and just make sure the connections are in place. make sure you disconnect the power first. let me know what happens afterwards.
    May 24, 2008 | Technics SL-1210 Turntable
    Philips gemini  TT-01 Turntable Logo
    109 people viewed this question
    Top Philips Audio Players & Recorders Experts
    Gyula Lacz
     Grubhead
    Grubhead
    Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
