Question about ASUS P4S533 Motherboard
Aus p4s533-mx my motherboard is weird it dont boot? if i remove the battery for 10 mins it will boot into bios and so soon i change the setting in bios and save it, it won't boot i have to remove the battery again i have a pentium 2.4 and ddr 256 pc2100 any help pls
  • ake svenjeby
    ake svenjeby Jun 03, 2008
    i change the cpu speed to 2.4 and dont touch nothin else
    Problem Solver:
  • 13 Answers
What setting are you changing?
Posted on Jun 03, 2008
  • Rasmick
    Rasmick Jun 03, 2008
    What is the CPU speed before you change it ......there are a lot of guides for Overclocking isn't just a matter of changing some settings.....
    the above a guide that might help ....
    also read this article on your P4S533-MX
    Remember overclocking is more of an art then anything else.....
    Heat and power load increases are your biggest concerns
    It is better to have an old computer to practice on then your every day user ....also some MB //processors are easier to OC then others....
    It is all a matter of increasing this a little and see if it is stable then trying a little more
    If it is running at say 2.2 then leave it there as 2.4 won't make a huge difference ...also update the MB at ASUS site with all the latest Drivers and such
Asus P4S533-MX Bios problem
The average life span of a cmos battery is about five years.
The Asus P4S533-MX mother board hit the market in 2002/2003. Suggest you pull the bios battery and check its current voltage. It should read 3 volts DC. Double check the bios jumper. The jumper should be across pins 1 and 2 (This is Normal default setting). Open you're manual to page 1-15 for more information about the bios jumper. (CLRTC1). When in the bios you should set the time and date to current date and time. Save and exit the bios. When you boot your system and the bios auto loads it's self automatically usually its due from a wrong setting within the bios or its not maintaining its voltage. Consider the price of a new battery. See the link provided;
If you need the manual or drivers try the link provided;
Happy holidays!
Dec 31, 2009 | ASUS P4S533 Motherboard
Asus k8s mx not boots but fan rotates and without
Long beeps are saying 'no RAM'. Any beeps with RAM in place? Remove BIOS battery (silver) for 10 mins to return to factory defaults.
Sep 12, 2009 | VIA Asus K8V-MX K8M800 Chipset 800MHz FSB...
please check the system memory (RAM)
remove them and carefully clean in mouth with a clean A4 white sheet
or change the memory if possible...... and if problem still occur, please check the system processor too...
to check if the processor is functioning, remove the heat sink on the processor and boot the machine placing your finger on the processor chip.
it burns your finger after a short sec. BUT this should be done in a controlled way and after the memory had been tested for
May 10, 2009 | ASUS P4S533-MX Motherboard
P4s533 mainboard
Reset BIOS back to default
1) remove M/board battery for 5 to 10 minutes
while booting press the DEL or F2 or ctrl+esc
or check lower part of screen during boot will tell you hoe to fet into BIOS
Once BIOS reset to default boot computer if OK.
you can change BIOS to suite CPU etc
Oct 29, 2008 | ASUS P4S533-MX Motherboard
My computer does not boot from the ide section on the board but when u remove
I need more info. When did this problem occur? Was it working properly before? Did you change anything in your CMOS/ BIOS settings?
Oct 07, 2008 | ASUS P4S533-MX Motherboard
Does it have a built-in system beep buzzer? or else you need to connect one. The system beep has a code and will tell you if your video is not connected or your memory is not detected.
Try to make it boot even until the bios screen. Check your video card or your monitor connector. A single beep is a good sign that your motherboard has no problems. hope this helps
Sep 25, 2008 | ASUS P4S533 Motherboard
I changed RAM settings in BIOS, now I can't boot
try jumpers ok move to 2 and 3 for few sec then back on 1 and 2 pins on mobo ok thx nick take ram out do one at time defult to auto in bios thx nick
Feb 06, 2008 | ASUS P4S533-MX Motherboard
I changed RAM settings in BIOS, now I can't boot - need to clean CMOS
well its quite have set the wrong latency for rams.
I suggest you put a latency around 3
reset the bios and check the know that you must have all the rams from the computer to the same all the timings or latency.
good luck..
bye bye
ASUS P4S533 Motherboard Logo
102 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
