Question about AudioControl Epicenter Audio Control Digital Bass Maximizer
Diagram of epicenter installation - AudioControl Epicenter Audio Control Digital Bass Maximizer
How does an earthquake alarm work?
An earthquake alarm provides an early warning by detecting an earthquake's soundwaves before the shear wave hits your area. The alarm will detect a quake that is even many miles away! A loud alarm will then go off.
May 07, 2013 | Home
Hi i trying to figure out how to wire up my rca's i have a pionner deck in on the back of it it has front output,rear output,sub output ,and also a audio output .now im trying to up it to a clarion eq that...
The "Front output" from the Pioneer deck would connect to the "Main In" on the Clarion EQ. I'm assuming that your Clarion EQ can only deal with one input, and will send the adjusted (equalized) signal out both of the outputs.
The "Front output" from the Clarion EQ should go to the "Front Input" on the 4 channel amp.
The "Rear output" from the Clarion EQ should go to the "Rear Input" on the 4 channel amp.
The "Sub output" from the Pioneer deck would connect to the Left/Right Input on the Epicenter. The Left/Right Output on the Epicenter would need a Y-splitter for each side, so that you could connect each amp separately. One suggestion would be to use one sub amp for both subs.
Feb 18, 2011 | Clarion Car Audio & Video
Knob on my epicenter doesn't work
the older epicenter knobs are pull then turn. and push in to turn epic off
May 22, 2010 | AudioControl Epicenter Audio Control...
Audiocontrol
The Audio Control unit is a considerably better built unit. PC boards are millitary spec. Thick and hearty! will not self destruct like alot of chinese stuff... The epicenter is a phenominal piece of electronics for anyone who loves bass as well as Rock. older recordings lack the intensity in the lower end response by comparason to todays "pop" music. A suggestion though, if you listen to Rap, this unit will cause your sub to over excurt and wear out quickly if not blow. I can't really speak to the Soundstream unit. I was a Soundstram Dealer when it was still a US company. All that's left of the original product is the name. Hope this helps
Jun 02, 2009 | AudioControl Overdrive-grey 2 Ch Line...
I have (2)10"kicker L7's 4ohm dvc.i am using a rockford punch 150 25 to life series. it's rated 960rms.with a alpine 250 v-power for infinity componets and 6/9's. i also have an epiceneter-150 that has spl...
first off kicker l7 10s require more power than your giving them. give them 600rms each.upgrade to a ho alternator . this place in dallas texas makes great alternators. 972-557-5768 maniac electric motors.i think the epic center is designed for music with out bass. if u upgrade the big three it will make a big difrence. do not use a yellow top batery under your hood use a redtop . deep cycling will cause the alternator to full field and burn up the regulater. auto zone only puts a 3 second load on the alternator thay cannot tell if its going bad. start your car and leave every thang off and check your alternator voltage. if it droppes below what the batery volage says when the car is off. usualy 12.4 volts is what a batery says and if u got a system running and your alternator is droppping below this 12.4 reding u are killing the alternator. the alternator is designed to run the car only with a few extra after marker accesories . so if u have a amp with 2 40 amp fuses in it. it should take around 80 amps to work the amp corectly. also rms is based off of 14.4VOLTS
Apr 02, 2009 | Kicker Solo-Baric L7 S12L7 Car Subwoofer
Car Audio & Video Logo
322 people viewed this question
Top AudioControl Car Audio & Video Experts
xxxxxx xxx
Are you an AudioControl Car Audio and Video Expert? Answer questions, earn points and help others
