Question about Zebra 105SL Thermal Label Printer
I have a zebra zm400 prinetr givig me an error message (head element bad)
    Champion:
  • Zebra Expert
  • 285 Answers
Turn printer off, press PAUSE button, turn printer on and wait 5 seconds then release the button. The printer is going to print the test label, check if coming some withe lines across the print. try to clean the printhead and the rollar, if pressist, need to replace printhead.
Please check if the cable from the printhead is totaly plug-in
Posted on Nov 13, 2010
LA IMPRESORA ZEBRA ZM400 CUANDO SE ENCIENDE APARECE EN LA PANTALLA LCD, EL MENSAJE HEAT OPEN, COMO QUITARLO?
there is a possibility that you need to just the print head assembly, if when its at close position, the print head is far from the sensor.
With the print head is open, you will see 3 screw on the left, louse them and adjust all the print head mechanism, up and down some milliliters tie the screws again, close the printhead , try again and see if errors desapeer
Jul 24, 2014 | Zebra ZM400 Thermal Label Printer -...
How to solve this problem in zebra zm400 error condition paper out \
check the sensor under the paper, reload labels roll, labels are possible on top of sensor black plastic and not between. move gap sensor to midle of label with. check manual to know how to fit the labels thought the sensors and printhead.
Sep 17, 2013 | Zebra ZM400 Thermal Label Printer -...
Zebra printer drops network
i hadthe same issue with all my zm400's, but not my zm4 plus's. zebra gives you the run around when contact their technical support.
I tried every setting there was, ended up get rid of the zm400's, they are a piece of C#@P
Feb 03, 2012 | Zebra ZM400 Thermal Label Printer -...
There is an error message on ZM400 zebra printer,it shows "invalid head",and our colleagues said haven't touched printer,it happened suddently,what's going on?
This is a faulty printhead. And is due to a new feature in these printers which is to stop you from using a compatible head (I know it isn't, but there you are).
Jun 29, 2011 | Office Equipment & Supplies
The message "head open " printer idle v53.16.5z
Try taking the printer off pause. It should clear the error.
Mar 03, 2011 | Zebra ZM400 Thermal Label Printer -...
Error in position of the output for ZM400
this is usually caused by a pressure imbalance across the printhead. Check the printhead pressure adjust dials located on top of the printhead. You might find that the left side has more down pressure than the right side causing the ribbon to move to the right.
Hope that helps !
Apr 09, 2010 | Zebra 300DPI CUTTER [zm400-3001-1000t]...
Zebra zm400 turn printed info 180 degrees
Yu can rotate the print orientation in the Z Designer printer driver, in the OPTIONS tag tick the 180Deg box
Dec 17, 2009 | Zebra 300DPI CUTTER [zm400-3001-1000t]...
Error condition ribbon out in ZM400
In the printer setting-
Change the Print Method from - "Tharmal Transfer to Direct Thermal" and save it permanently
Aug 10, 2009 | Zebra 105SL Thermal Label Printer
ZM400 printer
Try going through the LCD menu and if it say "Direct Thermal" change it to "Thermal Transfer", Direct Thermal made means, no ribbon required, but it sounds like you do have ribbon in the printer, if so, try my recommendation. If it asks for a password, it's '1234'.
Oct 14, 2008 | Zebra 203DPI Printer
Zebra 105SL Thermal Label Printer Logo
568 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
