Question about Dishwashers
I found a black rubber band in my GE GSD2230z00ww Potscrubber dishwasher. Now it drains completely, but does not thoroughly clean the dishes. Have cleaned the air tube and the grate, but neither seem to fix the issue. Please help and let me know where this 3" or so black seal goes. Thank you.
2 Suggested Answers
SOURCE: I have the GE 206c1513p001
I have the exact same problem!!! Found 2 loose rubber bands, the bottom doesn't drain completely, and the dishes are left either dirty with a white film on them. Please help!
Posted on Dec 02, 2010
GE potscrubber 940 isnt cleaning properly. Glasses cloudy, some dishes still dirty. Is there a filter that can be checked?
You need to add some vinegar. Depending on your water as much as 4-5 cups per load. I have had a Potscrubber for close to 10 years and discovered that they clean beautifully as long as you don't skip the vinegar.
Mar 01, 2011 | Dishwashers
I have the GE 206c1513p001 Potscrubber and recently found a black seal or rubber band in the dishwasher. Since then, it has been making a continuous clicking noise when it is run and does not clean the...
Oct 06, 2010 | GE Dishwashers
Hello, my 1992 GE potscrubber 630 is not cleaning well at the moment. Could vinegar or a little bleach help if it something is clogged with hardwater or food particles. thx.
My GE Potscrubber 630 dishwasher leaves a white film on all of the dishes. Is there a filter that can be cleaned out?
Aug 07, 2010 | GE Dishwashers
Is water suppose to stay in the sump pump of a ge potscrubber dishwasher. The water drains except in the very bottom where I guess the pump is. There is lots of mildew and I have lots of grit on my...
Yes water does stay in the sump all the time. This is normal.
Try running a cycle with a cup of Vinegar or Baking Soda in the dishwasher.
Also check to make sure that your drain line (under the sink) is higher than the sink drain and not allowing some sink drain seepage back into the dishwasher.
Jun 20, 2010 | GE 24 in. GSD2230Z Built-in Dishwasher
Not cleaning and leaving a white film on dishes
with dishwasher empty pour in two cups of white vinegar and then run the longest hottest cycle.
this will thoroughly clean the dishwasher. Then start rinsinig the dishes before u put them in and also use the potscrubber cycle all the time as this is the hottest water. J.
Jun 20, 2010 | Whirlpool 24 in. ADP6940 Dishwasher
Does not cleans dishes
Hi
Thanks for using FixYa. First of all please check the Water temperature by using a thermometer inside the dishwasher to measure the water temp. It should be as close to 125 degree F to 140 degree F as possible. Now try using the temperature boost feature if your dishwasher is equipped with this cycle feature and check if this will help your wash ability issues.
Now check the Powder soap by making sure that you store your soap in a dry environment and it is not stale and clumping together. Possibly try a different detergent like a liquid or gel. Also, make sure the dishes are loaded properly, or dishwasher is not overloaded.
To check the proper filling dishwasher will fill with water up to and around the heating element. If water is more below the heating element, you may have low water pressure or a problem with the fill valve. Try & listen if it sounds like it is spraying the water around with enough pressure.
For low water pressure, try to clean the screen at the entrance of the fill valve, sometimes the fill valve can fail and not allow the proper water into the dishwasher and may need to be replaced. And, check the spray arm and pump cover for splits or leaks. Also make sure that the water is draining and is not accumulated in the dishwasher, if it is in dishwasher then check for clogged drain hoses and drain pump.
Low water fills are a very common trouble maker with today's dishwasher.
Please do rate this solution and revert for further assistance.
Thanks
Rylee
Dec 11, 2009 | GE Dishwashers
GE Potscrubber 950 not cleaning very well takes at least twice and there is still food on most of the dishes
Clean out recirculating drain on inside of unit and try running bleach, maybe a 1/2 through a full cylce.
Aug 26, 2009 | Dishwashers
GE Profile Dishwasher (5 years old); Leaving residue on dishes
In my case the counter mounted breather for the drain tube was being restricted ... finally to the point it would not drain the tub at all. I disassembled the above counter drain assembly and cleaned it out as it wass completely blocked and things work very well again. I would suggest this foirst as it is an easy task and is done 'above the counter'.
I then ran 2 cups of CLR with wash cycle ... no dishes to clean out the rest of the washer as on dissaembly of the internals to diagnose they were and very scummed up with a hard white crusty substance that was completely blocking some of the drain sump performations.
Dec 09, 2008 | GE 24 in. Profile PDW7800 Built-in...
Dishes are not clean; lots of soap residue
Try the combo liguidgel powder packets and wash on the potscrubber plus setting. We saw a drastic improvement with this setting. I have just about gotten out of the habit of thorough pre-washing, but I do rinse heavily soiled items.
Aug 20, 2008 | Siemens 24 in. SL84A305UC Built-in...
Dishwashers Logo
63 people viewed this question
Top Dishwashers Experts
Owen Barnes
