Question about Canon PIXMA MX310 All-In-One Printer
I put in a new black cartridge but stupidly forgot to take off the brown protective tape so I got the 5 stored faxes coming out with nothing on them! Can I access those faxes please?
    Master:
    Sergeant:
  • 381 Answers
Yep should be able to. look into the memory using the function provided
Posted on Oct 15, 2010
When fax comes through paper is blank. I've tried 2 different cartridges
Replace the print cartridge
When you notice that the print becomes light or ink low or when install new ink
cartridge appears in the display, replace the print cartridge. The part number for
replacement cartridges is HP 701.
1. Take out a cartridge from its packaging and carefully remove the tape covering the
printhead.
Hold the cartridge by the colored top or black areas only. Do not touch the copper
area.
2. Press the Access Cartridge button on the control panel.
The cartridge carrier moves to the install position.
1 Access Cartridge
CARE AND
MAINTENANCE
CARE AND
MAINTENANCE
CARE AND
MAINTENANCE
CARE AND
MAINTENANCE
CARE AND
MAINTENANCE
CARE AND
MAINTENANCE
CARE AND
MAINTENANCE
Care and maintenance 45
3. Open the control panel and cartridge compartment cover (it will click and remain
open).
4. Push the cartridge down and remove it.
5. To load the cartridge insert the cartridge as shown below. When the cartridge is
pushed to the back of the cartridge carrier, push the top of the cartridge until it clicks
into place.
If the cartridge moves loosely in the carrier, it has not clicked into place. Repeat this
step.
1 Control panel
2 Cartridge compartment
cover
46 Care and maintenance
Clear jammed documents and paper
6. Close the cartridge compartment cover and control panel.
7. Press Start/Enter.
8. Press 1 for new cartridge, or 2 for the old one.
• When you put in a new cartridge, you must choose 1:New
• When you put in a used cartridge, choose 2:Used. This helps you to check the
correct amount of ink you have left.
TIP: If you mix up several used cartridges, it is not possible to check the correct amount
of remaining ink. Once you have put in a new cartridge, use it until it is completely
exhausted.
Nov 11, 2011 | HP 640 Inkjet Fax Machine
My ptouch isn't printing; after creating a label, when i press print, the tape comes out but nothing is on it.
Try a different tape. Usually, when the ink and label get screwed up it's time to trash it and start over, but you might just inspect the cartridge to make sure they are joining properly. If another tape works, there's your answer. If not, well 1180's aren't very expensive and our Brother store (Staples) has a sale on them every other week. Another heads up. If you have a Meijer's store nearby, they are stupid. They're selling black on white 12mm TZ tapes for $9.99. Go and buy them all :-)
Carl
Apr 21, 2011 | Brother P-Touch 1180 Label Printer
HP6988 printer skips lines and only prints bottom half of black lines. Installed new black cartridge, printed test page. Still no change.
Most deskjets include a maintenance section. Open this printer in PRINTERS on Control Panel (assuming Windows). right click on the printer and select properties. You will have to look for the maintenance section. There you should find an option to "clean heads". You may need to do this several times if never done before. After each cleaning, print a test pattern. Hope this helps.
Mar 31, 2011 | HP DeskJet 6988 Printer
I've just replaced the black ink cartridge for my Epson Stylus TX100, ink level is ok as the indicator shows. But i get blank prints for black, other colors are fine. What's wrong with the black ink...
There is nothing wrong with the black ink. Just run the head cleaning for better printing.
1. Go to printer and faxes
2. Right click your printer ( Epson Stylus Multifunction Printer/ Copier/ Scanner InkJet)
3. Click printing preferences
4. Click Maintenance Tab
5. Click Head Cleaning
6. Run head cleaning for 5 times then try printing.
Nov 15, 2010 | Epson Stylus Multifunction Inkjet Printer/...
New color ink cartridge does not print red. reason?
Here is my advice:
Step one: Run the clean print cartridges utility
1.
Press the Setup button.
2.
Press the down arrow key.
3.
Select Clean Print Cartridge and then press OK . The device prints a test page.
4.
Examine the test page. If the print quality of the page is good, stop here. If the print quality is bad, go on to the next step for further cleaning.
5.
Open the Printer Toolbox . There are two ways to do this:
Open HP Solution Center , select the Settings menu, then the Print Settings submenu, and finally the Printer Toolbox .
Open Printers and Faxes in the Windows Control Panel , then right-click your printer icon and choose Properties . Click Printing Preferences . Click the Features tab, then click the Printer Services button.
6.
The Printer Toolbox opens. On the Device Services tab, click Clean the Print Cartridges , then follow the on-screen instructions. Up to three levels of cleaning are available. Discard or recycle the page that prints.
Step two: Replace the problem cartridge (you probably have a defective cartridge)
If a cartridge replacement was not tried previously to solve this problem, replace the problem cartridge now
Cause and prevention
Color mix is usually caused by a material touching the nozzles. Ink can wick along the material and travel from nozzle to nozzle. When different colors of ink mix in this way, the result is muddy, inaccurate colors.
Missing colors occur when the cartridge nozzles dry out, or when a color is exhausted because of specific printing demands.
Do not remove the protective tape from a new print cartridge until just before you install it. Once you remove the tape, do not reapply it.
After you have removed the protective tape, do not allow anything to touch the nozzles.
Print at least once a month to keep the print cartridges in good working order.
Always turn the printer off by pressing the button on the printer control panel, rather than by unplugging the printer. Turning the printer off properly allows it to protect the cartridges.
If you are removing a cartridge from the printer temporarily (for instance, removing the black cartridge in order to install the photo cartridge), put it in a cartridge protector.
If you do not have a cartridge protector and need to remove a cartridge temporarily, put it in an airtight plastic tub. Make sure nothing touches the nozzles. Do not use a plastic bag. If you intend to store print cartridges in a tub for a long period of time, place color cartridges with the nozzles down, and black cartridges with the nozzles up. Please post your feedback and Vote if the problem resolved as per your satisfaction.
Jul 17, 2010 | HP PSC 2410 All-In-One InkJet Printer
New ink cartridges. Printer won't print and does not show the new cartridges.
1.
2.
3.
4.
5.
6.
Nov 25, 2009 | Epson Stylus Multifunction Inkjet Printer/...
I have replaced the toner cartridge in my newer ML-2510 printer. The quality is terrible. It looks like they forgot to fill the new toner cartridge. I did take out the cartridge thinking that I forgot...
Congratulations! You just bought an empty toner cartridge! I would return it if you can and get your money back. I recommend buying cartridges from a store so you can go complain to them if they pull something like this.
Oct 15, 2009 | Samsung ML-2510 Laser Printer
My kodak esp 5 all in one printer will not turn on after i change the ink cartridge
Be sure that you have removed any protective plastic from the cartridges. It usually looks like colored invisible tape. If you check and find that you have removed all protective plastic and it still does not turn on then put your old cartridges back in. If it turns on with your old cartridges then the cartridges are defective. If it does not come on, and you have checked all connections then unfortunately yur printer will need service. After working in an office supply store I know that defective cartridges are common especially refilled cartridges(store brand). Don't assume that because they are new thay will work :)
Aug 21, 2009 | Office Equipment & Supplies
My brand new ESP 5 will not print red letter on a
It seems to be a problem with the colour ink cartridge ,did you remove the protective tape that came with it?
you should return the colour cartridge and get it replaced or buy another one.
If that doesn't solve it then return the printer since it's under warranty.
Jun 15, 2009 | Kodak ESP 5 Printer
CANT FAX
Replacing An Ink Cartridge Use the following procedure to replace empty ink cartridges or when an ink cartridge error appears.
  1. Confirm that the printer is powered on
  2. Lift the Scanning Unit (Printer Cover) with both hands, and pull the Scanning Unit Support down into place (A).
    Note: After confirming that the scanning unit support is fixed into position, release your hands.
  3. Press down on the semi-circular tab located on the top of the cartridge to release the cartridge and then remove it.
    Note: Handle the ink cartridges carefully to avoid staining clothes and surrounding work area.
    *Optional cartridges PG-40 and CL-41 shown in examples
  4. Remove and replace each cartridge individually. Or, remove the second cartridge after the first has been removed.
  5. Take out a new cartridge from its casing and gently remove the orange protective tape in the direction of the arrow.
    Note: - Do not attempt to reattach the protective tape once you have removed it.
    - Do not touch the gold electrical contacts or the print head nozzles after removing the protective tape.
  6. Insert the ink cartridge into the ink cartridge holder.- Black: the left slot- Color: the right slot*
    *One black cartridge and one color cartridge must be installed in the machine in order for the printer to operate. It does not matter if the capacities (Standard or High) do not match.
  7. Push up on the front of the cartridge until it locks into place. (A click sound will be heard when the cartridge is locked in place.)
  8. Confirm that the ink cartridges are installed properly.
    <1> The ink cartridge is not installed properly.
    <2> The ink cartridge is installed properly.
  9. Fold the scanning unit support and close the scanning unit (printer cover).
  10. Wait until the preparatory operation is complete; it takes about one to two minutes.
Mar 28, 2008 | Canon MX300 Office All-In-One Printer
Canon PIXMA MX310 All-In-One Printer Logo
23 people viewed this question
old marine
old marine
