Question about Samsung SyncMaster 913V 19" Flat Panel LCD Monitor
Image not displaying properly
I know this is an old monitor now, but my Samsung SyncMaster 913v TFT monitor always had this problem since I got it (off a friend, not retail). When set to it's native 1280x1024 resolution, the image would be larger than the screen. E.g. the icons on desktop would be 'going off the screen'. This is especially annoying when playing games because I cannot see the edges of screen, missing out on information such as gold count etc.
I have downloaded the driver from Samsung's website to no avail, anyone know how to fix this?
  • nizmo_man Jun 03, 2008
    Attached the monitor to a laptop, still no good. Guess I'll just have to put up with it
  • nizmo_man Jan 04, 2009
    Hey guys sorry for not replying, must've lost the notification email somehow until now.
    I did try to install drivers on both my PC and laptop, but still the monitor does the same thing. Guess it's a faulty unit, I did get it free so I'm not too fussed. Both laptop and desktop computers display fine on on other monitors, so I doubt it's the graphics cards.
    Thanks for the help anyway, glad there are people out there helping us noobs out in time of need
    Cheers
  • 31 Answers
Did you install the drivers for it? the drivers instruct the video card on how to properly 'talk' to the monitor. My parents' have a wide-screen monitor that does 1400x900 native. Before installing the proper drivers it would go beyond the edges and have distorted icons.
Posted on Jun 03, 2008
  • Erich Backhus
    Erich Backhus Jan 04, 2009
    jerry raises a good point. A computer I recently built included an integrated video chip that could not support certain aspects.Older cards and integrated chips simply didn't exist when some of the more odd, especially anything that's 16:10 (1680x1050), aspect ratios were introduced.
    Genius:
  • Samsung Master
  • 1,673 Answers
Before assuming it's the monitor, try it on another display card.
It is possible that there is a problem in the configuration of the display card, or a defect in the display card.
Is there a computer service place, or a monitor sevice center near to where you live. You can then take the monitor to have it properly checked for you.
Jerry G.
Samsung syncmaster 913v gives message ' not optimum mode"
The 913V has a native resolution of 1280x1024. If you use a higher resolution than that, you'll get slightly blurry text. If you use a lower resolution, then images will be slightly choppy around the edges.
To get rid of the message, set your resolution to 1280x1024.
In Windows XP, you do this by right-clicking on the background (desktop) and selecting "Properties" to bring up the display properties.
Select the tab marked "Settings" and look for a "Screen Resolution" slider. Move that slider to the right until it displays "1280x1024" and hit "OK"
Oct 03, 2010 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Samsung lcd 913v self test ok, no image when vga connected
This problem often occurs in samsung SyncMaster LCD monitors.
The solution is open your look for the LCD monitor power supply module (which have PCB connector to the AC power), on that board look for capacitors, now look for broken one which upper part is bloated, like the image below:
If you find a damaged capacitor as in the picture then you should replace it with the same value.
Jan 22, 2010 | Samsung SyncMaster 913V 19" LCD Monitor
Samsung SyncMaster 913V it's displaying red lines
Sometimes this happens when the pins on the vga connector are bent. You can either try to straighten them (very carefully with tweezers) - be sure to check both ends, or try a new cable.
Apr 06, 2009 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Samsung SyncMaster 913v picture rotated 90 degrees
Please press Ctrl-Alt and your arrow keys until the image is straight!
Mar 10, 2009 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Syncmaster 913v color problem
Appears to be something in the connection. Check the video cable and pins on the video connector. Also verify the color settings have not been changed on the monitor. There should be an area where you change the RGB levels.
Feb 14, 2009 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Re Samsung Monitor
TFT means Thin Film Trangister. You are using LCD (liquid crystal dispaly) this means in lcd monitor use trangister on/off to create a pixel. you should give your monitor to repair at workshop for this problem. i don't know any workshop which located in your city. and about the expence it's all around rs 600 to 1000.
ok
bye
ramesh
Nov 13, 2008 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Syncmaster 913v
hi
I am a technician-informatic. I have repaired about 60 Lcd Samsung monitors with thees problems - not optimal resolution mode and dark screen problem. So i decided to made manual how to repair lcd samsung monitors.The repair process is very easy and simple 10-30min. does not need a lot of experience in electronics and expensive instruments.
if you are interested check it.
Samsung monitor repair manual guide 710n,913v,510n more
or just enter number in search field: 220409788372
thank you
Oct 26, 2008 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Samsung SyncMaster 913V 19" Flat Panel LCD Monitor Logo
149 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
