Question about Kenmore 95002 / 95004 Electric Kitchen Range
Receiving a display code of EO or E0 -F2- - Kenmore 95002 / 95004 Electric Kitchen Range
  • jack_mcguiga Oct 15, 2010
    I don't recognize the control element. Where is it located? I hope I gave the right model #. It could be 95804000. Difficult to read. The range is 9 or 10 yrs old.
  • Kenmore Master
  • 3,051 Answers
Hello there:
Any time you get the FO or even the EO or E2 error code it generally means the same thing your electronic range control is failing and will need to be replaced looks something like this one
Posted on Oct 15, 2010
  • 2 more comments
  • Michael Thomas
    Michael Thomas Oct 16, 2010
    also here is a few things to try press the cancel button for several seconds like 5 to 10 then release and see if the code is stil there if so unplug the oven for at least 1 hour to allow for the internal reset feature to reset it then try it again and still if this is unsuccessfull than you have no choice but to have the electronic contole assy changed ok
    Best regards Mike
  • Michael Thomas
    yes disconnect the power for 30 min then plug back in then press the cancel button for 3 to 5 seconds this is the reset feature on this oven
  • Michael Thomas
    the part that gave you the code is what i was referring to this is known as the erc (electronic range controle or can even be called the clock in some units see like i was saying yours may be just a bit different but it is the same thing
  • Michael Thomas
    Here is where to look for your model number
Kenmore electric stove model 95012102 displays EO-F2 the cooktop works.
that code is a bad touchpad.
F2 - E0 Shorted keypad (also called touch pad) 1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Read more: http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#Sears / Kenmore Fault Codes#ixzz1cHA0Nn50
Oct 30, 2011 | Kitchen Ranges
Receiving an E0 error code when trying to clean a Whirlpool Accubake oven
The EO error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The EO code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced .
Sep 18, 2011 | Ovens
My ranger digital pannel have a message EO F2, what ir means..?? the brand is Kitchenaid
Is it E0 F2 or F2-E0? If it is a 4 digit panel and it shows F2-E0, then it is a shorted keypad and you have to replace it. Sorry.
Sep 06, 2011 | Microwave Ovens
Display reads EO F2 Can't find what it means>
F2-E0 - Shorted Touch Pad (Keypad) - Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
Select the 'cancel' function and wait 60 seconds.
If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
Thanks for using FixYa - a 4 THUMBS rating and POSITIVE TESTIMONIAL is appreciated for answering your FREE question
Oct 05, 2010 | Kenmore 95822 / 95824 / 95829 Electric...
Display reads EO -F2- stove top works, oven will not
Sep 14, 2010 | KitchenAid KERA205P Electric Kitchen Range
Stove is beeping and displaying EO F2. Do reset but it keeps coming back. Also one element on the range top has burned out. Is it something a DIY can do.
Hi dear.According to your explanation,E0-F2 code meaning is: F2 - E0
I hope that helps to solve your issue.Thanks.
Sep 02, 2010 | Kitchen Ranges
Kitchen aid wall oven Model YKEBS2780B1 SHOWS
Hello,4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock(ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock(ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock(ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3
Thanks
May 26, 2010 | Ovens
I have a kenmore gas range and on the display is says EO F2
The "F2 - E0" error code means "Shorted keypad".
Remove power from the range, open the control panel and unplug the membrane switch ribbon from the control board.
Reconnect power to the range and observe for an hour.
If the error code reappear - replace the control board.
If not - replace the membrane switch.
If I get the model # I can help you pind the right parts.
Good Luck and please rate 4 thumbs for the free answer
Apr 17, 2010 | Kenmore 30 in. 32384 / 32385 / 32389 Gas...
My new Whirlpool oven Model number GBD 279 PVS02 error code EO F2
F2 E0 is a shorted keypad. Replace the keypad which is your entire touch pad. In rare cases your ERC or electronic range control can also be bad, unlikely though. Hopefully this is still under warrantee as the part alone is over 150.00. I recommend you have a technician replace this as most parts houses will not warrantee a electical part if a customer installs it. Good Luck, Appliance Specialists.
Dec 15, 2009 | Microwave Ovens
EO F2 on our Kenmore oven keeps coming up.
Remove power from the range, open the control panel and unplug the membrane switch ribbon from the control board.Reconnect power to the range and observe for an hour.If the error code reappear - replace the control board.If not - replace the membrane switch.
May 15, 2009 | Kenmore Ovens
Kenmore 95002 / 95004 Electric Kitchen Range Logo
483 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
