Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Runs 5 to 10 minutes and the engine starts rolling like it is staving for fuel new plug,fuel filter clened carbuertor I opened the fuel line at the filter drained fuel it ran good then did the same thing
  • 110 Answers
Check the fuel cap vent. If it is clogged no air can get in the fuel tank to replace the fuel being used eventually forming a vacuum in the tank and no more fuel flowing out.
Posted on Oct 24, 2010
Could my fuel filter cause my car to start then shut off suzuki grand Vitara 1999 v6 4×4
Yes, a very clogged fuel filter could cause that. A fuel pump going bad could cause that as well.
Jun 29, 2016 | Suzuki Cars & Trucks
Engine starts. Why does it only run a few minutes, then stop?
a few things may cause this. it sounds like it is starving for fuel. the spark plug may be breaking down when it gets hot. try a new spark plug. if the fuel and fuel lines are in bad shape, old, soft or hard. the fuel don't smell right. fuel filter plugged up. the carburetor may need to be cleaned and a rebuild kit as they are cheap. if it is 30 years old. be sure the fuel lines, filter and carburetor are in good shape. hope this gives you an idea on where to start. good luck
Mar 14, 2016 | Garden
Mower starts and then stops starving for fuel
bad move cleaning that way .the carbs they be funny little things .try closing the needle valves all the way then open 3/4 to 1 full turn and try .
Jan 30, 2015 | Garden
remove the fuel tap (if it has one ) from the tank and clean the gauze filter. Check for blockage in the fuel line up to the needle and seat. remove the bowl and the main jet and blow it out
Jan 30, 2015 | Miscellaneous
I have a 96 sub, starts perfect, idles perfect, even takes off okay, but feels fuel staved at 30 mph, then spuddles, if i turn it off for 30 seconds it runs fine for 5 miles then repeats.....
sounds like you could have a air leak in the fuel line or you could just swap out your fuel filter for new but i would check for air leak in fuel line first. when i say air leak i mean that there is a hole in ur fuel line some where and what happens is that is sucks air into the system so the engine in turns starts to splutter under load you may also find fuel residue around the area where there is a leak, check this first if all is ok change out the fuel filter
Mar 03, 2012 | 1996 Chevrolet Suburban
I have a 300 kawaski 4x4 atv and when i start it starts leaking fuel out of the carbuertor.
If it's the one I'm thinking of -it has a vacuum operated shutoff valve on the tank. So your leaky -read stuck- needle and seat only leak when the engine is turning over.
Pull the carb loose and roll over and remove the float bowl. drop the float pin and remove the float and needle. Find the vacuum line to the fuel valve and **** it open to flush out the needle and seat. When the fuel runs clean, put the needle and float back on and open the fuel valve again. If the upside down carbs holds back the fuel- it's fixed and you can put it back together.
May 26, 2011 | 1998 kawasaki KLX 300
Cub 1550 with kohler courage. Runs fine and then loses power, runs erratic and starts to backfire. Cleaned carb and fuel pump and ran fine for 30 minutes and then problem started again. When this occurs,...
Replace fuel filter after cleaning tank thouroughly, to clean tank remove fuel line at carb. Drain all fuel then leave line loose until you flush tank with carb. Cleaner then blow out tank with compressed air. Now install new fuel filter and check your fuel can for trash and water better yet just add fresh fuel.
Aug 12, 2017 | Garden
Will not run under load, seems to be starving for fuel. When I leave it for a minute or two, I can start it and work with it for a minute or so then it sees to over rev before cutting out. If I start it...
Check the fuel filter in the tank for plugging. Check the fuel lines for kinks, rotting, or splits. Check the muffler and air cleaner for plugging. Make sure all the screws and mounting nuts are tight on the carburetor. When these things look ok, then turn the H needle jet CCW about 1/2 turn, start the engine and let it warm up. Open the throttle fully--the engine should be 4-stroking now. Proper adjustment is when the engine will 4-stroke, but immediately 2-stroke when cutting. You may need to turn the H needle somewhat CW to achieve that condition. Hope this helps!
Apr 16, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Hi i have a 1987 dt 125 lc and the engin run s then stops
if plug is wet or sooty check air filter and replace if it is dirty,also check that choke is opening fully.If plug is fouled you may need another one,
Mar 19, 2009 | 2000 Yamaha DT 125 R
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
98 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
