Question about SanDisk Cruzer Micro 8GB USB 2.0 Flash Drive
When I insert the flash drive into the USB port the computer tells me that it is not formatted. I try to format and it says that Windows could not format the flash drive.
  • Dale Niles Oct 15, 2010
    Which operating system are you running?
  • 125 Answers
I hve a solution but i dont know which window u r using....................for xp it wrk....or u also try in other window............ 1-contol panel 2- administrative tools 3- computer management 4- storage 5- disk management local 6- right click on ur pendrive. 7- then format . . . it will wrk
Posted on Oct 16, 2010
My transcend 4gb pendrive is not dectecting. any one suggest for this solution
Sometimes when a flashmemory stick or USB external hard drive fails because it was not removed fromthe USB port properly. If the device is removed byjust pulling it out of the USB port, it can cause the flash device to fail, youmust click on the Safely Remove Hardware icon on the Task Bar and select thedevice you wish to remove and only do so when instructed to do so When the flash memoryUSB hard drive device appears to malfunction it maybe possible to restoreit by reformatting it. Insert the flash or USB hard drive into the USB port then Click on Control Panel - AdministrativeTools - Computer Management - Disk Management. Then right click on Disk 1removable drive and click Format. After the flash drive has been formatted itwill indicate that it is Healthy. You need to format the flash or external drive. Format thedrive as primary drive and in FAT32. (FAT32 will allow data to be exchangedbetween MACs and PCs also between XP/Vista and earlier versions of Windows). Otherwise format the USB flash drive in NTFS.
Insert the flash or external hard drive into the USB port then Click on ControlPanel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flashdrive has been formatted it will indicate that it is Health
Apr 22, 2011 | Transcend (589307) Media
How to format usb that says it has 8mb capacity.
To Format Any Flash (USB) Drive
WARNING: This will permanently remove ALL data from your flash drive.
1) Insert the flash drive into a working usb port on your Windows PC.
2) Open "My Computer" in Windows XP or eariler OR "Computer" in Windows Vista/7
3) Right click on the Flash Drive (Usually labeled "Removable Disk")
4) Click "Format..."
5) Ensure that file system is "FAT32", Volume label is a name of your choosing, and that "Quick Format" is unchecked
6) Click "Start"
7) Windows will warn you that all data is about to be deleted. Click OK.
8) Once the format is complete, Windows will produce a pop-up window telling you so.
You now have a blank flash drive.
Apr 12, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I have an HP pen drive 4GB. From last one week it is not being detected in any system.
Feb 07, 2011 | Computers & Internet
I CANT FORMAT MY MEMORY CARD....I DONT KNOW HOW TO FIX IT.
  1. Open control panel.
  2. Open administrative tools.
  3. Open Computer management.
  4. In the left column click disk management.
  5. This populate all the disk present
  6. Locate your memory card
  7. Then you can delete the partition entire and build new one
  8. You can format with Fat Or FAT32 file system
  9. Do not perform quick format.
Another options are available to format via cmd
To do that
At the run Menu type:CMD
then a command promt window will open
Type format x: /fs:fat32
Note that x is volume label (memory card drive label may d, e or f)
ok
try this
Feb 25, 2010 | Sony 4GB Memory Stick PRO Duo Memory Card
My flash drive is inserted in a USB port. It says
Try to format the mp3 player.
Go through: Setting>Control Panel>Administrative Tools>Computer Management>Disk management>
Try to format it with fat files system.
hope this help you
Regards
uttam
Jan 13, 2010 | SanDisk 1GB Cruzer Titanium USB Flash...
I bought one pny pen drive of 2 GB after 4-5 mouths it gout courapted an when I try to explore/open and fromet a mesage is displyed by windows thati please insert disk drive in H:
Sometimes when a flash memory stick fails because it was not removed from the USB port properly. If the device is removed by just pulling it out of the USB port, it can cause the flash device to fail, you must click on the Safely Remove Hardware icon on the Task Bar and select the device you wish to remove and only do so when instructed to do so.
When the flash memory device appears to malfunction it maybe possible to restore it by reformatting it. Insert the flash drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that it is Healthy.
You need to format the external drive. Format the drive as primary drive and in FAT32. (FAT32 will allow data to be exchanged between MACs and PCs).
Insert the external hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Nov 14, 2009 | PNY Optima 2GB USB 2.0 Flash Drive - Dark...
PC is not detecting my Cruzer micro pendrive but
I have experienced this type of problem before. But what I did was to install an Avira Anti-virus on a system using windows xp and eventually it did open.
So you can try it as well or insert your flash into any another system that had a strong anti-virus which can enable you scan/format the drive.
Best of Luck
Nov 06, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
No access to USB drive when inserted (Windows). ''Malfunction'' error message.
Oct 30, 2009 | SanDisk 1GB Cruzer Titanium USB Flash...
I have a 2GB scandisk pendrive, I unable to format it, Whenever i tried to format it in command. Msg appered IOCTL call error. how can I format it. Pl help me
Try formatting the flash drive using this method.
Oct 22, 2009 | Transcend (589307) Media
Formatting (FAT) 2g drive left drive with only 735Mb. How do I format for the full 2g? Thanks
what device did you use to format your flash drive? is it a camera or PC?
now try to insert your flash drive in a usb port of a PC running windows vista since it has a better disk management tools. now format it from there using FAT32 file system to regain your disk space. you can also try windows xp
Oct 14, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
SanDisk Cruzer Micro 8GB USB 2.0 Flash Drive Logo
155 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Piyal Perera
Piyal Perera
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
