Question about Samsung RFG237AARS Bottom Freezer French Door Refrigerator
Samsung refrigerator inside led light not working
Back of freezer has frost and freezer wont cool to proper temp. icemaker etc also not working
Did you leave the freezer door open for a period of time while the refrigerator was running? Unplug and defrost the freezer manually with a hair dryer until all frost is removed inside and in back of the freezer. Reapply power and see if it will then cool/freeze properly. Let me know the results
APPLIANCE 911
Jan 10, 2016 | Samsung RH29H9000SR RH29H9000SR 36"...
How to stop the flashing (strobing) lights inside both the fridge and freezer?
I had the same problem but instead of throwing a couple hundred dollars away I decided to let my lights stay on all the time inside the fridge. All I did was pop the filter switch out so it wouldn't trigger when the door was closed. No more flickering and the hole doesn't irritate me like the rave party inside my fridge did????
Apr 01, 2015 | Whirlpool WRS325FDAM 25.4 cu. ft. Side by...
How long should led light last inside a ge refrigerator
The average life of a LED is like 10,000 hours, sounds more like a problem with the switch. How handy are you with a VOM? If your not handy, then you may want to call in an appliance repair man or a electrician.
Jul 20, 2014 | GE Profile PSW26P Stainless Steel Side by...
Changed filter on samsung rf4287hars refrigerator. filter icon on LED is still red
Hold Alarm for 3 seconds and this should reset the filter light. Good luck!
Jul 04, 2014 | Samsung RF4287HARS French Door...
Flashing green light on control panel
Samsung refrigerator RS2530bwp
Cause: Power outage
Symptoms:
- One LED light flashing on console (in the Power Freeze section)
- Not running (not cooling, but inside lights work, ice maker not working, ice crusher doesn't work, water wont dispense)
Solution:
Press and hold for at least 10 seconds
Ice type button + Filter Reset button
Console should light up.
This is not documented *anywhere* on the web (until now). Best of luck
Aug 12, 2012 | Samsung RS2530BWP (25 cu ft) Side by Side...
Samsung model RS2556SH, refrigerator
Refrigerator temperaure gauge keeps blinking and fridge is only cooling to 35 degrees
Mar 13, 2009 | Samsung RS2556 Side by Side Refrigerator
I have a samsung RS21DCNS fridge but i have jus had apower cut for 10mins and now the fridge is not working. the lights are coming on inside but there is nothing on the contol panel and none of the buttons...
unitl you either cleanr the code or repair the fault that is what you see.the fault is the ice maker sensor is not reading correctly. check the plug connections for the sensor. if you would like you can contact me and i will help you with this problem.
Jan 17, 2009 | Samsung RS2630SH Side by Side Refrigerator
Samsung HLN467W Flashing "LAMP" LED
remove the lamp and visually check if inside looks broken.if visually do not see any thing wrong,check if you have 300 volts dc supply on the ballast which starts the lamp.if you do then the ballast may be defective.if you do not then the power supply should be checked.
the lamp should always be tried first especially if is older than two years.
note - be aware about the switch at the door lamp.the door should be closed,otherwise tv will not work.if you remove the back cover,make sure to bypass the switch temporarely so you could work on the set.
Sep 03, 2008 | Samsung HLN467W 46" Rear Projection HDTV
Samsung RFG237AARS Bottom Freezer French Door Refrigerator Logo
253 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
