Question about Sony PlayStation Portable (PSP) Console
Game not loading
I have reset the default settings, removed the battery then replace it, and the games still says can read disc. Any solutions?
Press select button choose da umd iso mode and change the setting in m33 driver
Posted on Jun 03, 2008
Ps3 wont read disc
Hi
i have searched this problem and found the following.
http://community.eu.playstation.com/t5/PlayStation-3-Technical-Help/Discs-are-not-loading-in-my-PlayStation-3/m-p/12507592#M1779
or you try this,
  • First go to Settings> System Settings> Default settings. If the first solution does not work try the trick below.
  • Remove any disk from the drive and put the device in standby mode (Red LED). Press and hold the On/Off until you ger first beep, a second one and then a double beep.
  • If there's no double beep, repeat the process.
    • You should get a menu. Choose the 3rd option and follow the procedure.
Jun 27, 2013 | Sony PlayStation 3 Slim 160GB Blu-ray PS3...
PS3 - Game crash followed by disc read error
The update corrupted your hard drive that's why it's not loading any disc.Yes,Restoring the system will work but it will destroy all your saved game data.Updating the system will not remove the hard disk defect.There is only one solution,Reset it.
Jun 14, 2010 | Sony Playstation 3 (PS3) Console
My PS2 is not loading Grand Turirsmo 4!
If your PS2 works fine with most of the games and won’t play a few..Then you should try this trick to play them too on your PS2:
  1. Turn on your PS2 without inserting any disc.
  2. Menu screen will appear like:6e4cb56.jpg
  3. Press the (triangle) Button to enter Version Information Menu that looks like9d90dc8.jpg
  4. Highlight the Play Station Driver as above and again press (triangle).
  6. Highlight the Disc Speed as above and press X button,to enter Disc Speed Menu
  7. And set it from Standard to "Fast".
  8. After you set Disc Speed to Fast, Press and Hold Reset Button to turn off your console.
  9. Then again Press and Hold Reset Button till the Blue Light turns on.
  10. Remove the Reset Button and Press it again.
Be patient and wait till the game loads itself. If your lens is in good condition then it will play game in first go else try again till it PLAY your game. If still your Grand Turismo 4 DVD wont work then you must clean your PS2 lens.Watch following video to learn about cleaning lens:
Thank you and Good Luck!
Dec 16, 2009 | Sony PlayStation 2 (PS2) Console
Disc Read Error
If a dual layer disc is not functioning, there is a problem with your laser. This is a frequent issue with Playstation 2 consoles. As a laser starts to fail, the first type of disc to stop reading is the dual layer disc. Eventually regular DVDs will start skipping in the middle of the game and loading times will increase. Eventually it will stop reading DVDs as well. The solution is a replacement laser. You can find one at the following website for $30 including shipping:
http://store.richspsxparts.com/pl270sev12la1.html
Nov 17, 2009 | Activision Video Game Consoles & Games
PS3 Wont Play Game OR Blue Ray Disc
reset to the factory default then load ver 2.60(most current). If the system still does not read any discs the laser is bad.
Dec 05, 2008 | Sony Playstation 3 (PS3) Console
Playstation 3 - game not loading
This a new patch that has fried some of the system. I work for sony and this has become a big problen. it is done when both the american edition of GTA4 and COD 4 are played after each other due to limitation factors. This however is easily fixed by getting a screw driver and flickintg a reset switch that is in the CD tray. This is a genuine method and is what is done at the replacment sector in sony.
your sincerly
Josh Williams
Jan 06, 2008 | Video Game Consoles & Games
Games read but will not play
Try Reseting dufault settings through System settings...
Dec 27, 2007 | Sony PlayStation Portable (PSP) Console
PSP won't power on
When you play a new game for the first time, the psp checks for the firmware version of your psp. If a newer version is available, the disc will require you to update your psp. If you do not update the game cannot be played. If you update, you MUST charge the battery 1st. Then, you must have the charge plugged in and allow the update to run uninterrupted. If you remove the game or unplug the charger during the update the bios chip will be ruined and you now have little more than a "brick".
When this happens, the unit completely locks up and has to be replaced. Basically, it corrupts the operating system and there is no ability to restore default settings as a back-up.
Dec 20, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
49 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
