Question about Canon PIXMA MP600 all-In-One InkJet Printer
I had a paper jam Problem with the PIXMA? iP6009D All-In-One InkJet Printer I had a paper jam and removed paper. I still get "paper jam remove paper from paper eject" but there absolutely is no paper left in my Canon Pixma printer. Could the jam sensor have been damaged and if so how much is cost to replace? Hello, I will advice you Press and hold the "Resume" button on the printer. Press and hold the "Power" button while holding down "Resume." Release the "Resume" button. Press "Resume" twice. The indicator light will turn amber followed by green. Release the "Power" button. Press the "Resume" button four times. Press the "Power" button. The printer is now reset, and your printer should work fine. Margaret: Unfortunately didn't work. I tried 10 times. Wit variations. I assume I start with power on then press resume, hold then press power then release resume. Press resume twice. Light is green then turns back to orange. Release power button (does this turn it on or off? I did both ways) When press resume 4 times I assume power is on but I tried both ways. Get same message "paper ejection slot. Paper jam. Clear paper jam and press resume" I have thoroughly checked and there is no paper. Any more advice
  • Margaret Rogers Oct 15, 2010
    I thoroughly checked and there is no paper left in the printer - any other ideas? If the senser got damaged do you know if it is expensive to replace?
    Master:
    Sergeant:
  • 381 Answers
There might be some paper stuck in the rollers or which is blocking the sensor hence the msg. just give it a good check
Posted on Oct 15, 2010
SOURCE:
Paper jammed
Put off the machine and gradually remove the paper. If any piece of the paper is cut in the process, it must be removed else the printer would continue reading paper jam. Thanks.
Jun 28, 2012 | Canon PIXMA MP600 all-In-One InkJet...
[email protected] have 6 orange flashes to one green on a pixma ip5000 whaty is going on?
Hi
Please check your Printer Cartridge and check any paper jam is there, paper jam is there please remove the paper. and restart your printer.
Good Luck
May 11, 2011 | Canon PIXMA iP5000 InkJet Photo Printer
My Canon Pixma MP160 won't work :( It says there's paper jammed in the printer and it needs to be removed but there isn't anything there. . . HELP!!
Previously when you had tried to printing any paper the printer has adopted paper jammed error but at this time you have not turned off the system.The printer has configured paper jammed whenever you are trying to print.
It represents that it want to restart the system.
Unplug the printer and reconnect to your system.
Oct 16, 2010 | Canon PIXMA MP160 All-In-One InkJet...
PAPER JAM PROBLEM
remove power (turn off) machine, and open just to show the roller, and manually turn the roller just guide paper out.
Mar 24, 2010 | Canon PIXMA MX700 All-In-One InkJet...
Canon PIXMA Mp150 paper jam, how can I get the cover off to remove the jam?
open printer scaner liake as change printer cartridge open jum paper
Aug 28, 2009 | Canon PIXMA MP150 All-In-One InkJet...
How can fix the jammed paper situation?
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
toi-i-17
Jul 30, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Paper iam
open the printer back cover and remove paper from it
May 23, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Pixma mp750
it seems the lever for the paper jam is having problem you have to open the printer and check for any broken or dislodge part.
Aug 18, 2008 | Canon PIXMA MP750 All-In-One InkJet...
Mp160,error code e3
hi,
587
May 19, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Pixma mp830
see if you can open a back door on the feed side. sounds like a paper is not feeding properly inside and must be removed.
Would be nice to know the model, make.
Jan 07, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA MP600 all-In-One InkJet Printer Logo
147 people viewed this question
Clive
Clive
old marine
old marine
Ekse
