Question about HP Compaq nx6110 PC Laptop
Hp 6110 when boot up it says A disk error occured
    President:
  • 2,571 Answers
Have you left a usb drive attached, or a disc in the DVD drive?
If not, your windows installation may be damaged.
You may be able to fix it if its just the boot loader damaged.
Google "fix mbr" for advice on fixing this type of problem
Posted on Oct 15, 2010
My compaq nx 6110 gives me a 1782 disk controller failure message and will not boot can anyone help?
A disk controller failure can occur because of a few things:
A.) IDE or SATA controller failure.
or
B.) Hard drive failure.
Since this is a laptop, your most inexpensive troubleshooting and fix for this would be to test another ATA 5 hard drive in the machine. If you can successfully re-install Windows on it, the ATA/IDE controller is most likely fine and the issue is just with your hard drive.
Hard drives are easily replaced... controllers are not and would require a new motherboard.
Please let me know if I can assist you further.
Regards,
KYTechnology
Mar 04, 2011 | HP Compaq nx6110 PC Laptop
Hp labtop non system disk error
Hi, this error most often occurs when you try to boot your computer up with either a flash drive (USB drive) or a CD/DVD already in the computer. The system checks these drives first for operating systems before the hard drive, and when it doesn't find your operating system it displays that error. Remove the disk or flash drive and try to boot your computer again, and the error should go away.
Jan 21, 2011 | HP Computers & Internet
Dell mini inspiron 910. On boot " a disk read error occurred press CTRL+ALT+DEL to restart " when I do that the same message appears please help me.
I think you have a hard disk error.
Use your recovery disk, or better still Windows Installation disc, and start the boot up using the menu to select "repair system". That will save you the trouble of having to reinstall all of your software and settings.
If it won't work, a format of drive C will fix your errors but you will have to restore all of your dadt.
Hope this helps.
Oct 25, 2010 | HP Mini 1000 Netbook
My Hp probook 4510s cannot boot it gives error of PXE failure after startup screen it says media cable check error.
Your computer tries to "boot" from several devices:
* floppy disk
* CD/DVD drive
* internal disk-drive
* USB memory-stick
* over the network, if it can find a "boot-server" on the local network.
So, the 'PXE failure' and 'check cable' errors occur either because there is no cable connected to the network-port, or because there is no "boot-server" on your network.
Enter BIOS setup, and check the "order" of possible boot-devices,
to ensure that the "network-boot" device is set to the _lowest_ priority.
What this could mean is that the computer *TRIED* to boot from the disk-drive, but *FAILED* to do so, i.e., you have a problem with the disk-drive in your computer. Ouch!
Aug 28, 2010 | HP 4510S C2D226 156 4GB 320GB DVDR BT CAM...
Mistake number 421*
According to HP, this error code means that a handshaking (connection) error occurred at some point in the process from the sending fax machine. They suggest to try the fax at a different time when telephone line conditions have improved, or that in some cases the error can occur if the other fax machine is using a fax format incompatible with the HP fax.
Dec 16, 2009 | HP OfficeJet 6110 All-In-One InkJet...
How do I fix an "error 442" on the fax part of my hp 6110 all-in-one
Per HP:
Definition
An error occurred during transmission after one or more partial pages were sent. The sending machine was unable to restart the control channel connection(handshake) before sending more data. This error typically occurs when the receiving fax disconnects after receiving part of a page. It can also be caused if the receiving fax is using a fax format incompatible with the HP fax (usually during color faxing).
Solution
Try the fax at a different time when telephone line conditions have improved.
Apr 19, 2009 | HP OfficeJet 6110 All-In-One InkJet...
For solving blue screen error
HP Notebook PCs - "Windows Unsafe or Sudden Shutdown" Blue Screen Error Occurs During Startup or Boot
Description
Windows XP may not start and the following error message may appear on a blue screen:
This error occurs after Windows was not shutdown using a safe method. The notebook may have been turned off without clicking Shut Down or briefly pressing the computers Power button. The power may have been suddenly disconnected from the computer or the Power button may have been held for more than 5 seconds.
An unsafe shutdown can damage some of the Windows system files, preventing the computer from starting properly.
Solution
If the error occurs allow the operating system to complete a check of the hard disk. Windows will prompt your to run CHKDSK. CHKDSK scans the hard drive for damaged files and repairs the files if necessary. The scan may take up to an hour depending on the size of the hard drive and the number of damaged files. The computer will restart when the scan is complete and Windows should start normally.
If Windows will not start or the computer will not boot after the scan is complete see: HP Notebook PCs - Troubleshooting a Startup or No Boot Problem (In English)
use the link to know how to use recovery option with hp laptop
http://h10025.www1.hp.com/ewfrf/wc/fastFaqLiteDocument?lc=en&cc=us&dlc=en&product=18703&docname=c00608578#
_____________________________________________________
Thanks and Regard
dilipbagdi
Technical Associate
May 18, 2008 | HP Pavilion dv9000z Notebook
Nx 6110 boot up issue
None of the above. Sorry. All those "solutions" are "shooting in the dark". There is a definitive method of determining the problem here, without guesswork.
The "HP screen" you speak of is an "advertising mask" governed by the "quiet boot" option in BIOS.
This HP screen is shown INSTEAD of showing you exactly what BIOS is "doing" at that moment: First, a ROM checksum to verify BIOS is OK, then a quick system check of the most basic components, and if that goes well, the next thing it does is count AND check the RAM. Finally, after all that is done, it will look for a hard drive and query that drive for cylinder or LBA size, then look at MBR for sector zero, to find an operating system.
So here is what you must do to SEE all that taking place:
1. Make sure the system is TOTALLY cold (off, not in any ACPI state). Do this by pressing and holding the power button for 10 seconds, then release.
2. Remove Battery and the PSU (AC power supply)
3. Insert the PSU connector (only) this will also eliminate any battery problems. Batteries with dead cells can pull out so much current that you get slow boot/running performance. More on this later.
4. Now, start the computer, and keep pressing ESC key, quickly. It may start beeping. Stop and wait then.
5. Next, you will see a BLACK screen instead of HP screen. There will be some white text that scrolls. First the BIOS type and version. Next, RAM will be counted, and last, a HD will be reported. Last (or if any of the above have a problem) any errors will be reported. Some BIOS will specify the error, others will report it as "code XXX". Send me (post) this info, and I will analyze the problem.
NOTE: you can hit the PAUSE key at any time, to read the info, if it runs too fast for you. Then press PAUSE key again, to resume the BIOS data post process. Once you have reported back with any errors (as in step 5 above), we can also do this same thing with Windows, to "see" the black screen/errors reported as the PC boots.
Jan 22, 2008 | HP Compaq nx6110 PC Laptop
HP Compaq nx6110 PC Laptop Logo
71 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
